[geos-devel] latest geos cvs breaks on make
Heitzso
heitzso at growthmodels.com
Sat Aug 16 20:43:07 EDT 2003
Thanks for the heads-up. I'm not used to pulling
from CVS and working in a pre-./configure environment.
Running the autogen.sh script first on a clean
(fresh from cvs) tree I get further, but make still
crashes during compile of:
Coordinate.cpp
on line 6. Error is unable to convert the
coordinate(nan, nan, nan) to geos::Cordinate&
Hope this is of use.
Line 199 had a trivial complaint re missing newline
at end of file.
Heitzso
Norman Vine wrote:
> Heitzso writes:
>>(note this is after deleting references to examples tree
>>from configure and configure.in)
>>./configure
>>make
>>fails with the following message:
>>source/geom/Makefile.am:
>> required file './depcomp' not found
>>Am I missing something or is the cvs tree unstable
>>at the moment?
> Since you are working with developer files and not a 'release'
> you are expected to unerstand the gnu autotool system :-)
> i.e
> aclocal, automake libtool and friends
> Probably easiest to just run the included autogen.sh script
> which should just do the right things for you
> For some background info see
> http://sources.redhat.com/autobook/
> and thread starting here
> http://postgis.refractions.net/pipermail/postgis-users/2003-August/002852.html
> HTH
> Norman
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
