[geos-devel] latest geos cvs breaks on make
Paul Ramsey
pramsey at refractions.net
Sun Aug 17 14:44:43 EDT 2003
I have committed the patch, with some changes:
The references in source/Makefile.am to directories with no Makefile.am
themselves have been removed.
The top level Makefile.am has had the reference to the 'except' directory
removed.
I have also committed some file removals to hopefully address Norman's troubles
with cvs diff. Incidentally, I find unified diffs (-u) way way easier to read
through.
geos now compiles cleanly for me and runs the usual test suites.
Paul
Quoting Norman Vine <nhv at cape.com>:
> Attached find changes I made to the current CVS
> inorder to compile with gcc 3.2 Cygwin
> Note this diff has been *heavily* hacked by me from what CVS diff
> returned in that files that are *usually* not in CVS but generated by
> autogen.sh are in the CVS. This is a PITA for development as
> CVS diff does not work as expected.
> Could we please get the CVS to represent only those files
> left after doing a 'make maintainer-clean'
> HTH
> Norman
