[geos-devel] latest geos cvs breaks on make
Heitzso heitzso at growthmodels.com
Mon Aug 18 11:44:11 EDT 2003
I changed over to gcc 3.3 from gcc 2.95 on my
debian-testing system and then updated geos
tree from cvs.
The 'make build' (after autogen.sh, ./configure, etc.)
is running fine now.
Would it be useful for me to rebuild with 2.95
to see if that's what broke my 'make build' earlier?
If it was the version of gcc that breaks geos
it would be useful to doc that, and I'm willing
to run the test if that's a possibility.  Someone
let me know.
Heitzso
> Paul Ramsey writes:
>>I have also committed some file removals to hopefully address Norman's troubles
>>with cvs diff. Incidentally, I find unified diffs (-u) way way easier to read
>>through.
> Thanks Paul,  I will use diff -u in the future
> FYI - GEOS compiles cleanly for me with Cygwin gcc 3.2
> and MingW32 gcc 3.3.1
> If anyone has a P4 with gcc 3.3.x installed I would be interested
> in hearing about timing results between the default CXXFLAGS
> and
> CXXFLAGS="-msse2 -O3 -march=pentium4 -fomit-frame-pointer -mfpmath=sse"
> Note an executable compiled with these flags will only run on a P4 or greater
> Cheers
> Norman
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
