[geos-devel] Also Failing
David Blasby
dblasby at refractions.net
Mon Aug 18 13:55:13 EDT 2003
Yuri,
The crashes paul is speaking of are being caused by executing commands like:
delete geom;
This was reported before - it had to do with:
a. create a geometry factory
b. create geom1 from the factory
c. create geom2 from the factory
d. delete geom1;
e. geom2 now has an deleted precisionModel.
f. delete geom2; -- segfaults
I believe you were going to make the Geometry's precisionModel be a full
vesion (not a pointer). ie.
typedef Geometry {...
PrecisionModel precisionModel; //not a pointer
instead of:
PrecisionModel *precisionModel; //pointer
dave
