[geos-devel] automake problems
Todd Vollmer
tvollmer at digitalglobe.com
Mon Aug 18 14:59:01 EDT 2003
I have the most recent cvs update. I am having problems with the compile. It
starts upon running autogen.sh. Here is the error
Linux RH 7.2 (2.4.19)
gcc 2.96
>Running aclocal
>Running automake
>source/geom/Makefile.am:6: Libtool library used but `LIBTOOL' is undefined
>source/geom/Makefile.am:6: The usual way to define `LIBTOOL' is to add
`AC_PROG_LIBTOOL'
>source/geom/Makefile.am:6: to `configure.in' and run `aclocal' and
`autoconf' again.
>Running autoconf
>configure.in:16: error: possibly undefined macro: AC_LIBTOOL_DLOPEN
> If this token and others are legitimate, please use m4_pattern_allow.
> See the Autoconf documentation.
>configure.in:17: error: possibly undefined macro: AC_PROG_LIBTOOL
>Now you are ready to run './configure'
running automake by hand I get.
aclocal (GNU automake) 1.7.6
>automake: reading /usr/local/share/automake-1.7/am/configure.am
>automake: reading /usr/local/share/automake-1.7/am/ltlib.am
`AC_PROG_LIBTOOL'
`autoconf' again.
>automake: reading /usr/local/share/automake-1.7/am/ltlibrary.am
I see that AC_PROG_LIBTOOL is defined in configure.in. Any body have any
clues? My first post here so please forgive any transgressions. If I ignore
the errors and proceed to configure/build I get:
>Making all in source
>make[1]: Entering directory `/home/tvollmer/Src/geos/source'
>Making all in geom
>make[2]: Entering directory `/home/tvollmer/Src/geos/source/geom'
>make[2]: *** No rule to make target `BasicCoordinateList.lo', needed by
`libgeos.la'. Stop.
>make[2]: Leaving directory `/home/tvollmer/Src/geos/source/geom'
>make[1]: *** [all-recursive] Error 1
>make[1]: Leaving directory `/home/tvollmer/Src/geos/source'
>make: *** [all-recursive] Error 1
Todd Vollmer (tvollmer at digitalglobe.com)
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20030818/402bd797/attachment.html
