[geos-devel] automake problems
Paul Ramsey
pramsey at refractions.net
Mon Aug 18 15:13:26 EDT 2003
For redhat, I ended up deleting the stock versions of automake and
autoconf and compiling from source. Worked much better after that.
Paul
Todd Vollmer wrote:
> I have the most recent cvs update. I am having problems with the
> compile. It starts upon running autogen.sh. Here is the error
> Linux RH 7.2 (2.4.19)
> gcc 2.96
> >Running aclocal
> >Running automake
> >source/geom/Makefile.am:6: Libtool library used but `LIBTOOL' is
> undefined
> >source/geom/Makefile.am:6: The usual way to define `LIBTOOL' is to add
> `AC_PROG_LIBTOOL'
> >source/geom/Makefile.am:6: to `configure.in' and run `aclocal' and
> `autoconf' again.
> >Running autoconf
> >configure.in:16: error: possibly undefined macro: AC_LIBTOOL_DLOPEN
> > If this token and others are legitimate, please use
> m4_pattern_allow.
> > See the Autoconf documentation.
> >configure.in:17: error: possibly undefined macro: AC_PROG_LIBTOOL
> >Now you are ready to run './configure'
> running automake by hand I get.
> aclocal (GNU automake) 1.7.6
> >automake: reading /usr/local/share/automake-1.7/am/configure.am
> >automake: reading /usr/local/share/automake-1.7/am/ltlib.am
> undefined
> `AC_PROG_LIBTOOL'
> `autoconf' again.
> >automake: reading /usr/local/share/automake-1.7/am/ltlibrary.am
> I see that AC_PROG_LIBTOOL is defined in configure.in. Any body have any
> clues? My first post here so please forgive any transgressions. If I
> ignore the errors and proceed to configure/build I get:
> >Making all in source
> >make[1]: Entering directory `/home/tvollmer/Src/geos/source'
> >Making all in geom
> >make[2]: Entering directory `/home/tvollmer/Src/geos/source/geom'
> >make[2]: *** No rule to make target `BasicCoordinateList.lo', needed
> by `libgeos.la'. Stop.
> >make[2]: Leaving directory `/home/tvollmer/Src/geos/source/geom'
> >make[1]: *** [all-recursive] Error 1
> >make[1]: Leaving directory `/home/tvollmer/Src/geos/source'
> >make: *** [all-recursive] Error 1
> Todd Vollmer (tvollmer at digitalglobe.com)
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
