[geos-devel] Is it possible to build current CVS version
ofgeosbyMinGW
Norman Vine
nhv at cape.com
Thu Aug 21 11:46:30 EDT 2003
Hisaji Ono
> Thank you for your kind response, Mr. Vine.
> > Hisaji Ono writes:
> > The list's archive is your friend
> > http://geos.refractions.net/pipermail/geos-devel/2003-August/000537.html
> I could build current cvs files by Cygwin, but not by MinGW with
> "-mno-cygwin " option in Cygwin.
> Any modifications require for building current geos for MinGW?
> Could you give me any advice?
I do not use Cygwin with the -mno-cygwin switch, I have a 'separate'
but complete MingW installation which I run from within a Cygwin Shell
Most find that MSys is a little easier to use but I haven't tried it
Both MingW and MSys are available from http://www.mingw.org
This thread might help
http://www.cygwin.com/ml/cygwin/2003-02/msg01463.html
HTH
Norman
