[geos-devel] PostGIS Exception Catching
Paul Ramsey pramsey at refractions.net
Mon Jun 2 12:33:25 EDT 2003
Well, since the underlying GEOS code is throwing an exception which
probably contains a little descriptive text, perhaps parrotting the GEOS
information would be a good first step.
David Blasby wrote:
> Paul Ramsey wrote:
>> Dave,
>> Now that we're catching exceptions (I just compiled the CVS postgis
>> and geos, no problems, straight install) we should make the return
>> text on the pgsql error more instructive.
>> pramsey=# select relate(g,g) from validtest ;
>> ERROR:  GEOS relate() threw an error!
>> pramsey=#
> Its easy to change - what do you want it to say?
> dave
