[geos-devel] GEOS robustness question
Kevin Wiebe
Kevin.Wiebe at safe.com
Mon Jun 23 19:08:36 EDT 2003
> Paul is right, in that the crosses() predicate reports
> whether two lines strings properly cross or not.
> In fact, all the named predicates are implemented in terms
> of the basic relate() method, which evaluates them all in
> the same way. You will find that the implementation is
> fully robust, by virtue of using a robust line segment
> intersection test and carefully coding to evaluate all
> possible ways geometrys can interact. This is documented
> in the JTS materials.
> Martin Davis, Senior Technical Architect
> Vivid Solutions Inc.
> Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> Phone: (250) 385 6040 Fax: (250) 385 6046
> EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
Martin, your answer has taught me to ask a more intelligent question.
It appears obvious that the upper level calls on Geometry objects do not have a direct correspondence to underlying "core" algorithms. I guess what I am looking for is some part of the core code, probably in the "algorithm" directory, where the lowest level computations are being done.
I may have to study many complex structures to understand how things are done, but I'm prepared. I hope.
I think the previous "lines crossing" question was a bit too vague. I'm not trying to hunt down a single algorithm; I am just looking for the core algorithms that do this "type" of thing.
Instead, maybe I can ask for the sections of code that would distinguish between a line that "meets" a polygon (stays outside, but touches the border) and a line that "cuts through" a polygon (part of the line inside, and part outside). For argument's sake, let's say all the vertices on the line are outside the polygon.
Pointers to a file, a method, a line of code :), or a general walk through how this decision is done, internally, would be helpful.
-Kevin-
Kevin Wiebe Safe Software Inc. email:kevinAtsafe.com
Senior Surrey, BC, CANADA phone: (604) 501-9985
Developer http://www.safe.com fax: (604) 501-9965
