[geos-devel] GEOS robustness question
Martin Davis
mbdavis at VividSolutions.com
Mon Jun 23 19:09:34 EDT 2003
Kevin, I'm afraid I don't have the time right now to provide a detailed explanation. If you start browsing the relate classes you'll find the code you're looking for. Best to look at JTS, I think - the algorithms are the same and the syntax is clearer. Get an IDE which helps you drill down through the code.
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 Fax: (250) 385 6046
EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
> -----Original Message-----
> From: Kevin Wiebe [mailto:Kevin.Wiebe at safe.com]
> Sent: Monday, June 23, 2003 4:09 PM
> To: geos-devel at geos.refractions.net
> Subject: [geos-devel] GEOS robustness question
> > Paul is right, in that the crosses() predicate reports
> > whether two lines strings properly cross or not.
> > In fact, all the named predicates are implemented in terms
> > of the basic relate() method, which evaluates them all in
> > the same way. You will find that the implementation is
> > fully robust, by virtue of using a robust line segment
> > intersection test and carefully coding to evaluate all
> > possible ways geometrys can interact. This is documented
> > in the JTS materials.
> Martin, your answer has taught me to ask a more intelligent question.
> It appears obvious that the upper level calls on Geometry
> objects do not have a direct correspondence to underlying
> "core" algorithms. I guess what I am looking for is some
> part of the core code, probably in the "algorithm" directory,
> where the lowest level computations are being done.
> I may have to study many complex structures to understand how
> things are done, but I'm prepared. I hope.
> I think the previous "lines crossing" question was a bit too
> vague. I'm not trying to hunt down a single algorithm; I am
> just looking for the core algorithms that do this "type" of thing.
> Instead, maybe I can ask for the sections of code that would
> distinguish between a line that "meets" a polygon (stays
> outside, but touches the border) and a line that "cuts
> through" a polygon (part of the line inside, and part
> outside). For argument's sake, let's say all the vertices on
> the line are outside the polygon.
> Pointers to a file, a method, a line of code :), or a general
> walk through how this decision is done, internally, would be helpful.
> -Kevin-
> Kevin Wiebe Safe Software Inc. email:kevinAtsafe.com
> Senior Surrey, BC, CANADA phone: (604) 501-9985
> Developer http://www.safe.com fax: (604) 501-9965
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
