[geos-devel] GEOS Status (Sunday, Mar. 2)
Paul Ramsey
pramsey at refractions.net
Sun Mar 2 20:46:03 EST 2003
Compilation crashes and burns pretty early on. There seems to be some
trivial incompatibilities between what the headers are saying and what
the code is saying.
g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
-I../../source/headers -DGEOS_VERSION=\"1\" -g -O2 -c
GeometryFactory.cpp -MT GeometryFactory.lo -MD -MP -MF
.deps/GeometryFactory.TPlo -fno-common -DPIC -o
.libs/GeometryFactory.lo
GeometryFactory.cpp: In static member function `static Geometry*
GeometryFactory::toGeometry(Envelope*, PrecisionModel*, int)':
GeometryFactory.cpp:18: no matching function for call to `Point::Point(
Coordinate, PrecisionModel*&, int&)'
../../source/headers/geom.h:690: candidates are: Point::Point(const
Point&)
../../source/headers/geom.h:689:
Point::Point(Coordinate&,
../../source/headers/geom.h:688: Point::Point()
On Sunday, March 2, 2003, at 05:04 PM, Yury A. Bychkov wrote:
> Current status: All ported code has been cleaned up. Most of the
> Coordinate
> class instances replaced with references. Most of methods from
> Coordinate class
> have been inlined. This resulted in noticeable (~15%) performance
> improvement
> (see output below).
> To do: Add rawGetAt method to CoordinateList* classes (Norman's
> recommendation
> that should result in even better performance). Write a couple of
> example
> programs using new CoordinateList interfaces. Bring the GEOS up to
> date with the
> latest JTS version (1.3), add namespace and continue the porting (with
> isValid).
> Yury
> P.S. Latest performance numbers (P4-2.53):
> # overlapping MCs: 406
> # segment intersection tests: 226
> n Pts: 1000 Executed in 10 ms.
> # segment intersection tests: 278
> n Pts: 2000 Executed in 30 ms.
> # segment intersection tests: 248
> n Pts: 4000 Executed in 40 ms.
> # segment intersection tests: 250
> n Pts: 8000 Executed in 70 ms.
> # segment intersection tests: 272
> n Pts: 16000 Executed in 140 ms.
> # segment intersection tests: 264
> n Pts: 32000 Executed in 291 ms.
> # segment intersection tests: 236
> n Pts: 64000 Executed in 581 ms.
> n Pts: 128000 Executed in 1142 ms.
> # segment intersection tests: 238
> n Pts: 256000 Executed in 2473 ms.
> # segment intersection tests: 232
> n Pts: 512000 Executed in 4937 ms.
> n Pts: 1024000 Executed in 9403 ms.
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
