[geos-devel] Re: GEOS Status (Sunday, Mar. 9)
Yury A. Bychkov me at yury.ca
Mon Mar 10 23:38:56 EST 2003
Tomorrow I am going to ASI Exchange in Vancouver, so I'll not have that much
time to work on GEOS this week. This week I should be able to finish 2 remaining
index packages and write a new example program and probably port enough of the
operation/Overlay to run the isValid(). Next week I should be able to finish the
Overlay and items 3-4.
Yury
> Good stuff Yury. Can you give us some ETAs on to-do items 1-4 below?
> Thanks,
> Paul
> Yury A. Bychkov wrote:
> > Current status:
> > 1. One example on how to use CoordinateList classes is done (in "examples"
> > directory).
> > 2. isValid package and 2 of its support packages (index/Sweepline and
> > index/Quadtree) are ported. It doesn't run yet, because of the external
> > dependencies (mainly from operation/Overlay), but that should be fixed soon
> > To do:
> > 1. Port the operation/Overlay and 2 remaining index packages
> > 2. Write anothe example program for CoordinateLists based on arrays
(Martin's
> > suggestion)
> > 3. Bring the GEOS up to date with the latest JTS version (1.3) and add
> > namespace.
> > 4. Add rawGetAt method to CoordinateList* classes (Norman's recommendation
> > that should result in even better performance).
> > Yury
>        __
>       | Paul Ramsey
>       | Refractions Research
>       | Email: pramsey at refractions.net
>       | Phone: (250) 885-0632
>       \_
