[geos-devel] GEOS Status (Sunday, Mar. 9)
Paul Ramsey pramsey at refractions.net
Mon Mar 10 11:47:18 EST 2003
Good stuff Yury. Can you give us some ETAs on to-do items 1-4 below?
Thanks,
Paul
Yury A. Bychkov wrote:
> Current status:
> 1. One example on how to use CoordinateList classes is done (in "examples"
> directory).
> 2. isValid package and 2 of its support packages (index/Sweepline and
> index/Quadtree) are ported. It doesn't run yet, because of the external
> dependencies (mainly from operation/Overlay), but that should be fixed soon ;-)
> To do:
> 1. Port the operation/Overlay and 2 remaining index packages
> 2. Write anothe example program for CoordinateLists based on arrays (Martin's
> suggestion)
> 3. Bring the GEOS up to date with the latest JTS version (1.3) and add
> namespace.
> 4. Add rawGetAt method to CoordinateList* classes (Norman's recommendation
> that should result in even better performance).
> Yury
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
