[geos-devel] GNU Changes
Paul Ramsey
pramsey at refractions.net
Wed May 28 01:09:11 EDT 2003
Yury, beware, I have made a passel of GNU compatibility changes in the
CVS.
Also, I have a problem:
The automake / autoconf build process is currently set up to assemble
all the object files in the source/geom directory, then link them into
a library. Fine, except we are now getting name collisions between
objects from different parts of the source tree, namely from
automake: source/geom/Makefile.am: object `Node.lo' created by
`../index/bintree/Node.cpp' and `../graph/Node.cpp'
automake: source/geom/Makefile.am: object `Interval.lo' created by
`../index/strtree/Interval.cpp' and `../index/bintree/Interval.cpp'
The result is unbuildableness. So, either we get a couple distinct
names, or figure out a way to marshall the objects within their home
directories yet still build a unitary library. (I think the reason we
ended up marshalling everything into source/geom was to get a single
libgeos.so as a build result.)
Help from the automake/autoconf gurus most appreciated.
P.
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
