[geos-devel] GNU Changes
Paul Ramsey pramsey at refractions.net
Wed May 28 10:49:09 EDT 2003
Yury,
Could you do the file name changes?
Thanks,
Paul
On Wednesday, May 28, 2003, at 06:02 AM, Ferdinando Villa wrote:
> I'd just call the files different names. As pointed out in the past,
> merging objects from different development trees into one library is
> not
> a clean approach automake-wise - I'd very much prefer building separate
> libraries (and use `geos-config --libs` to extract the link parameters,
> which is much simpler than doing -Lgeos and having to figure out where
> prefix is), or building one library with all the sources in one
> directory (which would avoid naming problems from the start). Anyway
> the
> solution here is simple - change filenames...
> ciao f
> On Wed, 2003-05-28 at 01:09, Paul Ramsey wrote:
>> Yury, beware, I have made a passel of GNU compatibility changes in the
>> CVS.
>> Also, I have a problem:
>> The automake / autoconf build process is currently set up to assemble
>> all the object files in the source/geom directory, then link them into
>> a library. Fine, except we are now getting name collisions between
>> objects from different parts of the source tree, namely from
>> automake: source/geom/Makefile.am: object `Node.lo' created by
>> `../index/bintree/Node.cpp' and `../graph/Node.cpp'
>> automake: source/geom/Makefile.am: object `Interval.lo' created by
>> `../index/strtree/Interval.cpp' and `../index/bintree/Interval.cpp'
>> The result is unbuildableness.  So, either we get a couple distinct
>> names, or figure out a way to marshall the objects within their home
>> directories yet still build a unitary library. (I think the reason we
>> ended up marshalling everything into source/geom was to get a single
>> libgeos.so as a build result.)
>> Help from the automake/autoconf gurus most appreciated.
>> P.
>>       Paul Ramsey
>>       Refractions Research
>>       Email: pramsey at refractions.net
>>       Phone: (250) 885-0632
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
> ferdinando villa, ph.d.                    associate professor
> gund institute for ecological economics, university of vermont
> 590 main street, burlington, vt 05405    phone: (802) 656-2972
      Paul Ramsey
