[geos-devel] is this a bug polygon intersection?
strk
strk at keybit.net
Thu Nov 13 10:50:05 EST 2003
I've spent more then 3 hours trying to figure out how to run JTS.
And I failed. Free java VM and compilers are not able to run it.
I think downloading the latest JDK from sun whould do the trick,
but since I've seen a 16MB for an old Swing package I assume that
would take a couple of days...
Java is an ugly beast !
Any success stories about this ?
--strk;
strk wrote:
> mbdavis wrote:
> > JTS has the TestBuilder (which is a GUI) and the TestRunner (which reads XML files). Check the doc for more details.
> Thanks for the answer.
> I'm trying to run it with kaffe, but I think Swing is missing:
> java.lang.NoClassDefFoundError: javax/swing/JFrame
> Do you knwo where can I get it ?
> thanks.
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
pallamondo.net <-- take a look !
