[geos-devel] is this a bug polygon intersection?
Paul Ramsey
pramsey at refractions.net
Thu Nov 13 11:15:26 EST 2003
On Thursday, November 13, 2003, at 07:50 AM, strk wrote:
> I've spent more then 3 hours trying to figure out how to run JTS.
> And I failed. Free java VM and compilers are not able to run it.
> I think downloading the latest JDK from sun whould do the trick,
> but since I've seen a 16MB for an old Swing package I assume that
> would take a couple of days...
You'll definately need the latest Sun Java. Download the JRE instead of
the JDK since you are only going to be running stuff, much smaller
download.
> Java is an ugly beast !
> Any success stories about this ?
> --strk;
> strk wrote:
>> mbdavis wrote:
>>> JTS has the TestBuilder (which is a GUI) and the TestRunner (which
>>> reads XML files). Check the doc for more details.
>> Thanks for the answer.
>> I'm trying to run it with kaffe, but I think Swing is missing:
>> java.lang.NoClassDefFoundError: javax/swing/JFrame
>> Do you knwo where can I get it ?
>> thanks.
>> --strk;
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
> pallamondo.net <-- take a look !
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
