[geos-devel] Documentation
strk
strk at keybit.net
Tue Oct 7 17:23:35 EDT 2003
I feel the same exact need. I'm still cascade-patching GEOS to
reflect getCoordinates() change to return a copy of the actual
set, which I'm not sure its the correct behaviour.
Who is responsible for GEOS overall architecture ?
PS: I will try adding an example.cpp file containing what I've
understood so far ...
--strk;
dblasby wrote:
> Sounds like there's a bunch of changes happening to GEOS.
> We really need to have some documentation on what GEOS-enabled software
> is supposed to do with respect to memory management.
> I mean, when I construct a Geometry out of a CoordinateList, can I
> delete it when the Geometry is constructed? Or is it autmatically
> destroyed when the Geometry is destroyed.
> How about functions like getCoordinate() or getCoordinates() - are these
> returning copies or the actual set of coordinates?
> So far I've been trying to answer these questions by reading the code
> (which is cumbersome), or (worse) making test programs and seeing if
> valgrind complains!
> This could be simple program that would construct,use, and delete some
> geometries, with comments about when you should (or should not) free memory.
> dave
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
