[geos-devel] Was it a big memory leak ?
Yury A. Bychkov me at yury.ca
Fri Oct 10 04:50:20 EDT 2003
> strk wrote:
> How do I run the test ?
You can use the test file as an input for XMLTester.cpp (the path to the input
file is specified on line 55 (or 56 for *nix)).
> PS: just a curiosity: do you start fixing bugs @ 02:30:51AM ? ;)
Normally I try to do it a little earlier ;-), but this week I am exceptionally
busy and that is pretty much the only time I can work on GEOS.
Yury
