[geos-devel] Was it a big memory leak ?
strk
strk at keybit.net
Mon Oct 13 11:43:26 EDT 2003
me wrote:
> > strk wrote:
> > How do I run the test ?
> You can use the test file as an input for XMLTester.cpp (the path to the input
> file is specified on line 55 (or 56 for *nix)).
What should Case #53 (desc: SegFault) do ?
It segfaults, does it mean it is correct ??
Should I remove it from input file in order to continue checking ?
--strk;
PS: I added to XMLTester.cpp tha ability of using the first argument as
path to input file.
