[geos-devel] Was it a big memory leak ?
Yury A. Bychkov me at yury.ca
Mon Oct 13 13:32:03 EDT 2003
Sorry, I should have put a clearer description there.No, this test shouldn't
segfault. "SegFault" description means that this test used to cause a segfault
in my code.  This problem has since been fixed, so hopefully it doesn't do that
anymore.
Yury
----- Original Message -----
To: "GEOS Development List" <geos-devel at geos.refractions.net>
Sent: Monday, October 13, 2003 8:43 AM
Subject: Re: [geos-devel] Was it a big memory leak ?
> me wrote:
> > > strk wrote:
> > > How do I run the test ?
> > You can use the test file as an input for XMLTester.cpp (the path to the
input
> > file is specified on line 55 (or 56 for *nix)).
> What should Case #53 (desc: SegFault) do ?
> It segfaults, does it mean it is correct ??
> Should I remove it from input file in order to continue checking ?
> --strk;
> PS: I added to XMLTester.cpp tha ability of using the first argument as
>     path to input file.
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
