[geos-devel] Still Leaking in PostGIS
Paul Ramsey pramsey at refractions.net
Sat Oct 18 19:46:18 EDT 2003
I loaded up a polygon table, and then did this:
   select wb_id from csn_waterbodies where isvalid(the_geom) limit 100;
I did this over and over. Each time, the postgres instance I was
connected to got a little bit larger. Probably this is repeatable with
any data set at all, but I can provide the 100 records I used if necessary.
P.
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
