[geos-devel] PostGIS Leak
strk strk at keybit.net
Thu Oct 23 12:31:14 EDT 2003
Hope this is the last one.
I got g++-3.3.2 / libstdc++5-3.3
exporting GLIBCPP_FORCE_NEW=1 and running doc/example
through valgrind make the following statement:
==20854== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
==20854== malloc/free: in use at exit: 0 bytes in 0 blocks.
==20854== malloc/free: 6248 allocs, 6248 frees, 207321 bytes allocated.
==20854== For counts of detected errors, rerun with: -v
==20854== No malloc'd blocks -- no leaks are possible.
FINALLY! :DD
I'm now checking postgis leaks
--strk;
strk wrote:
> me wrote:
> > Strangely enough your example runs fine on my system and I get no segfault while
> > printing the point.
> > Yury
> I finally upgraded compiler to version 3.0 and... Magic !
> Segfault disappeared. I can finally disable gcc's "smart"
> memory magic and... Surprise ! There seems to be a bug
> somewhere.. I get a segfault when deleting the vector
> used as input to GeometryCollection constructor (a just
> in time real life example of consistency issues).
> The bug probably does not show up due to memory caching smartness.
> I'll inspect on this. BTW to disable memory caching with gcc 2.91,
> 2.95, 3.0, 3.1 export CXXFLAGS=-D__USE_MALLOC and re-compile both
> geos and example.cpp. For gcc >= 3.2.2 export GLIBCPP_FORCE_NEW
> and/or GLIBCXX_FORCE_NEW at runtime.
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
