[geos-devel] automake error??
Norman Vine nhv at cape.com
Tue Sep 2 11:36:32 EDT 2003
Düster Horst writes:
> Hallo all
> When running autogen.sh automake-1.4-p5 reports the following messages:
> automake: configure.in: installing `./install-sh'
> automake: configure.in: installing `./mkinstalldirs'
> automake: configure.in: installing `./missing'
> configure.in: 160: installing `./config.guess
> What's the meaning of these messages??
automake is copying < or making symlinks > some files
to the GEOS directory
These files may be different depending on the automake
version you are using
This is normal behaviour
see
% info automake
HTH
Norman
