AW: [geos-devel] automake error??
Düster Horst
Horst.Duester at bd.so.ch
Tue Sep 2 12:43:27 EDT 2003
Norman,
I ask this question due to I'm not able to compile GEOS. You say automake is
OK. I think that configure runs OK but the compilation process breaks with a
lot of error messages I sent to the list some days ago. It was my last hope
that these messages were the cause of the compilation error.
I believe that automake creates a wrong link path to the compiled objects.
The error message says p.e.:
gcc: ../algorithm/CentroidArea.lo: No such file or directory
and occurs for all *.lo objects. All these objects were stored in the
directory ../geom but not in the expected directories like
../algorithm
../graph
etc.
where the source is located.
Perhaps you can help to find a solution.
My system:
redhat 7.2
Horst
-----Ursprüngliche Nachricht-----
Von: Norman Vine [mailto:nhv at cape.com]
Gesendet am: Dienstag, 2. September 2003 16:37
An: GEOS Development List
Betreff: RE: [geos-devel] automake error??
Düster Horst writes:
> Hallo all
> When running autogen.sh automake-1.4-p5 reports the following messages:
> automake: configure.in: installing `./install-sh'
> automake: configure.in: installing `./mkinstalldirs'
> automake: configure.in: installing `./missing'
> configure.in: 160: installing `./config.guess
> What's the meaning of these messages??
automake is copying < or making symlinks > some files
to the GEOS directory
These files may be different depending on the automake
version you are using
This is normal behaviour
see
% info automake
HTH
Norman
geos-devel mailing list
geos-devel at geos.refractions.net
http://geos.refractions.net/mailman/listinfo/geos-devel
