[geos-devel] GEOS Postgis Error/Postgres crash
Düster Horst Horst.Duester at bd.so.ch
Fri Sep 5 07:49:19 EDT 2003
Thank you Paul for the ./configure script. Now compilation process works
correct. But now I'm running in the next problem.
I did the followinig steps:
1. Compilation and installation of GEOS
2. Compilation of Postgres 7.2.4 with:
    LDFLAGS=-lstdc++ ./configure --prefix=myPath --enable-multibyte
    stop Postgres
    make and make install
    start Postgres
3. Compilation of Postgis with GEOS option
    replace all $libdir with /myPath/lib in postgis.sql
4. Last step test with ogc test suite
    createdb ogc
    createlang plpgsql ogc
    installation of postgis.sql successful
    installation of spatial_ref_sys.sql successful
    psql -d ogc -f 1_schema.sql works OK
    psql -d ogc -f 2_queries.sql
    Postgres crashes and responses with the following error message:
psql:2_queries.sql:508: server closed the connection unexpectedly
        This probably means the server terminated abnormally
        before or while processing the request.
psql:2_queries.sql:508: connection to server was lost
I tested with my geometries (no geometry_collections) with the same result.
Any hint would be appreciated.
Horst
