[geos-devel] GEOS Postgis Error/Postgres crash
Paul Ramsey
pramsey at refractions.net
Fri Sep 5 11:18:44 EDT 2003
We do not pass the conformance suite yet. Yury is fixing up the last
remaining bugs. The bug you hit (line 508) appears to be
PointOnSurface() which I think we have already reported.
P.
Düster Horst wrote:
> Thank you Paul for the ./configure script. Now compilation process works
> correct. But now I'm running in the next problem.
> I did the followinig steps:
> 1. Compilation and installation of GEOS
> 2. Compilation of Postgres 7.2.4 with:
> LDFLAGS=-lstdc++ ./configure --prefix=myPath --enable-multibyte
> stop Postgres
> make and make install
> start Postgres
> 3. Compilation of Postgis with GEOS option
> replace all $libdir with /myPath/lib in postgis.sql
> 4. Last step test with ogc test suite
> createdb ogc
> createlang plpgsql ogc
> installation of postgis.sql successful
> installation of spatial_ref_sys.sql successful
> psql -d ogc -f 1_schema.sql works OK
> psql -d ogc -f 2_queries.sql
> Postgres crashes and responses with the following error message:
> psql:2_queries.sql:508: server closed the connection unexpectedly
> This probably means the server terminated abnormally
> before or while processing the request.
> psql:2_queries.sql:508: connection to server was lost
> I tested with my geometries (no geometry_collections) with the same result.
> Any hint would be appreciated.
> Horst
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
