[geos-devel] isvalid() -- segmentation fault
David Blasby dblasby at refractions.net
Thu Sep 18 18:26:56 EDT 2003
I've attached the valgrind output.
dave
==10681== Memcheck, a.k.a. Valgrind, a memory error detector for x86-linux.
==10681== Copyright (C) 2002, and GNU GPL'd, by Julian Seward.
==10681== Using valgrind-1.9.6, a program instrumentation system for x86-linux.
==10681== Copyright (C) 2000-2002, and GNU GPL'd, by Julian Seward.
==10681== Estimated CPU clock rate is 1673 MHz
==10681== For more details, rerun with: -v
==10681==
geom1 = POLYGON ((1033707.5999999999767169 1048313.0999999999767169, 1033694.9000000000232831 1048315.6999999999534339, 1033659.9000000000232831 1048344.3000000000465661, 1033627.5999999999767169 1048388.8000000000465661, 1033620.9000000000232831 1048426.8000000000465661, 1033623.5999999999767169 1048471.3000000000465661, 1033623.5999999999767169 1048480.8000000000465661, 1033616.8000000000465661 1048503.1999999999534339, 1033629.0999999999767169 1048541.3000000000465661, 1033668.3000000000465661 1048707.6000000000931323, 1033696.3000000000465661 1048755.6000000000931323, 1033721.4000000000232831 1048771.6000000000931323, 1033724.5000000000000000 1048772.0000000000000000, 1033737.1999999999534339 1048772.0000000000000000, 1033772.0999999999767169 1048756.3999999999068677, 1033794.5999999999767169 1048721.8999999999068677, 1033811.0999999999767169 1048667.3999999999068677, 1033814.8000000000465661 1048613.6000000000931323, 1033815.0999999999767169 1048597.5000000000000000, 1033809.1999999999534339 1048556.0999999999767169, 1033809.3000000000465661 1048549.5999999999767169, 1033797.0999999999767169 1048501.9000000000232831, 1033790.9000000000232831 1048492.1999999999534339, 1033773.0000000000000000 1048399.5999999999767169, 1033760.5999999999767169 1048377.5999999999767169, 1033741.8000000000465661 1048357.8000000000465661, 1033742.0999999999767169 1048341.8000000000465661, 1033713.9000000000232831 1048313.4000000000232831, 1033707.5999999999767169 1048313.0999999999767169))
==10681== Invalid read of size 4
==10681==    at 0x402A456C: geos::BinTreeNode::find(geos::BinTreeInterval *) (../index/bintree/BinTreeNode.cpp:64)
==10681==    by 0x402A5005: geos::Root::insertContained(geos::BinTreeNode *, geos::BinTreeInterval *, void *) (../index/bintree/Root.cpp:59)
==10681==    by 0x402A4F8D: geos::Root::insert(geos::BinTreeInterval *, void *) (../index/bintree/Root.cpp:40)
==10681==    by 0x402A3CE6: geos::Bintree::insert(geos::BinTreeInterval *, void *) (../index/bintree/Bintree.cpp:58)
==10681==    by 0x4028ADF5: geos::MCPointInRing::buildIndex(void) (../algorithm/MCPointInRing.cpp:38)
==10681==    by 0x4028AC7A: geos::MCPointInRing::MCPointInRing(geos::LinearRing *) (../algorithm/MCPointInRing.cpp:20)
==10681==    by 0x402CBCBD: geos::IsValidOp::checkHolesInShell(geos::Polygon *, geos::GeometryGraph *) (/usr/include/g++-3/memory:36)
==10681==    by 0x402CB26E: geos::IsValidOp::checkValid(geos::Polygon *) (../operation/valid/IsValidOp.cpp:92)
==10681==    by 0x402CB048: geos::IsValidOp::checkValid(geos::Geometry *) (../operation/valid/IsValidOp.cpp:54)
==10681==    by 0x402CAF0E: geos::IsValidOp::isValid(void) (../operation/valid/IsValidOp.cpp:37)
==10681==    Address 0x4128707C is 24 bytes inside a block of size 32 free'd
==10681==    at 0x40168F45: __builtin_delete (vg_clientfuncs.c:199)
==10681==    by 0x402A44B3: geos::BinTreeNode::~BinTreeNode(void) (../index/bintree/BinTreeNode.cpp:31)
==10681==    by 0x402A4F66: geos::Root::insert(geos::BinTreeInterval *, void *) (../index/bintree/Root.cpp:33)
==10681==
==10681==    at 0x402A4570: geos::BinTreeNode::find(geos::BinTreeInterval *) (../index/bintree/BinTreeNode.cpp:64)
==10681==    Address 0x41287078 is 20 bytes inside a block of size 32 free'd
==10681==
==10681==    at 0x402A4589: geos::BinTreeNode::find(geos::BinTreeInterval *) (../index/bintree/BinTreeNode.cpp:67)
==10681==    Address 0x4128706C is 8 bytes inside a block of size 32 free'd
==10681==
==10681==    at 0x402A501B: geos::Root::insertContained(geos::BinTreeNode *, geos::BinTreeInterval *, void *) (../index/bintree/Root.cpp:62)
==10681==    by 0x4027532B: geos::Geometry::isValid(void) (Geometry.cpp:242)
==10681==    Address 0x41287070 is 12 bytes inside a block of size 32 free'd
==10681==
==10681==    at 0x402A4C47: geos::NodeBase::add(void *) (/usr/include/g++-3/stl_vector.h:319)
==10681==    by 0x402A5022: geos::Root::insertContained(geos::BinTreeNode *, geos::BinTreeInterval *, void *) (../index/bintree/Root.cpp:62)
==10681==    Address 0x41287064 is 0 bytes inside a block of size 32 free'd
==10681==
==10681==    at 0x402A4C49: geos::NodeBase::add(void *) (/usr/include/g++-3/stl_vector.h:320)
==10681==    Address 0x412870FC is 4 bytes inside a block of size 12 free'd
==10681==    by 0x402A4BB9: geos::NodeBase::~NodeBase(void) (/usr/include/g++-3/stl_vector.h:266)
==10681==    by 0x402A449E: geos::BinTreeNode::~BinTreeNode(void) (../index/bintree/BinTreeNode.cpp:31)
==10681==
==10681==    at 0x402A4C4E: geos::NodeBase::add(void *) (/usr/include/g++-3/stl_vector.h:320)
==10681==    Address 0x41287100 is 8 bytes inside a block of size 12 free'd
==10681==
==10681== Invalid write of size 4
==10681==    at 0x402A4C61: geos::NodeBase::add(void *) (/usr/include/g++-3/stl_vector.h:322)
==10681==
==10681==    at 0x402E0308: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:590)
==10681==    by 0x402A4C6E: geos::NodeBase::add(void *) (/usr/include/g++-3/stl_vector.h:197)
==10681==
==10681==    at 0x402E030D: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:590)
==10681==
==10681==    at 0x402E0353: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:196)
==10681==    Address 0x412870F8 is 0 bytes inside a block of size 12 free'd
==10681==
==10681==    at 0x402E0404: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_alloc.h:402)
==10681==
==10681==    at 0x402E0441: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_uninitialized.h:78)
==10681==
==10681==    at 0x402E045D: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:95)
==10681==
==10681==    at 0x402E0465: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:95)
==10681==
==10681==    at 0x402E04CB: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:612)
==10681==
==10681==    at 0x402E04D0: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:613)
==10681==
==10681==    at 0x402E04DF: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:614)
==10681==
==10681== Conditional jump or move depends on uninitialised value(s)
==10681==    at 0x402A5129: geos::indexMonotoneChain::~indexMonotoneChain(void) (../index/chain/indexMonotoneChain.cpp:18)
==10681==    by 0x402A4B2F: geos::NodeBase::~NodeBase(void) (/usr/include/g++-3/stl_vector.h:218)
==10681==    by 0x402A4BEF: geos::NodeBase::~NodeBase(void) (../index/bintree/NodeBase.cpp:29)
==10681==    by 0x402A4E9D: geos::Root::~Root(void) (../index/bintree/Root.cpp:10)
==10681==    by 0x402A3BEF: geos::Bintree::~Bintree(void) (../index/bintree/Bintree.cpp:31)
==10681==    by 0x4028AD10: geos::MCPointInRing::~MCPointInRing(void) (../algorithm/MCPointInRing.cpp:24)
==10681==    by 0x402CBE3B: geos::IsValidOp::checkHolesInShell(geos::Polygon *, geos::GeometryGraph *) (../operation/valid/IsValidOp.cpp:261)
==10681==
==10681== Use of uninitialised value of size 4
==10681==    at 0x402A514E: geos::indexMonotoneChain::~indexMonotoneChain(void) (../index/chain/indexMonotoneChain.cpp:19)
==10681==
==10681== Jump to the invalid address stated on the next line
==10681==    at 0x0: ???
==10681==    Address 0x0 is not stack'd, malloc'd or free'd
