[geos-devel] isvalid() still segfaulting
David Blasby dblasby at refractions.net
Wed Sep 24 13:05:47 EDT 2003
The other geometry I reported is now working. Unfortunately, I've found
another.
Find attached a program to cause isvalid() to segfault.  Also included
is the valgrind output.
dave
==10661== Memcheck, a.k.a. Valgrind, a memory error detector for x86-linux.
==10661== Copyright (C) 2002, and GNU GPL'd, by Julian Seward.
==10661== Using valgrind-1.9.6, a program instrumentation system for x86-linux.
==10661== Copyright (C) 2000-2002, and GNU GPL'd, by Julian Seward.
==10661== Estimated CPU clock rate is 1676 MHz
==10661== For more details, rerun with: -v
==10661==
geom1 = MULTIPOLYGON (((1032188.5999999999767169 967656.5000000000000000, 1032144.5999999999767169 967630.2500000000000000, 1032125.6999999999534339 967612.0000000000000000, 1032113.3000000000465661 967585.9399999999441206, 1032113.4000000000232831 967540.7500000000000000, 1032139.1999999999534339 967458.4399999999441206, 1032145.8000000000465661 967394.9399999999441206, 1032133.3000000000465661 967350.3100000000558794, 1032108.1999999999534339 967325.2500000000000000, 1032076.6999999999534339 967311.5600000000558794, 1032051.4000000000232831 967299.0600000000558794, 1032032.5999999999767169 967298.9399999999441206, 1032000.8000000000465661 967279.6899999999441206, 1031975.8000000000465661 967240.6300000000046566, 1031957.3000000000465661 967170.6300000000046566, 1031969.8000000000465661 967152.1300000000046566, 1031963.8000000000465661 967108.1899999999441206, 1031945.0999999999767169 967057.3800000000046566, 1031875.6999999999534339 967018.1300000000046566, 1031856.6999999999534339 967017.8800000000046566, 1031806.0999999999767169 967018.0600000000558794, 1031787.0999999999767169 967010.8800000000046566, 1031711.4000000000232831 966999.0000000000000000, 1031660.6999999999534339 966999.1899999999441206, 1031527.8000000000465661 967009.8100000000558794, 1031508.9000000000232831 967004.6300000000046566, 1031427.0999999999767169 966939.8800000000046566, 1031363.8000000000465661 966920.4399999999441206, 1031325.8000000000465661 966939.1899999999441206, 1031300.4000000000232831 966965.8100000000558794, 1031268.5999999999767169 966958.6300000000046566, 1031161.5999999999767169 966913.0000000000000000, 1031098.0999999999767169 966932.2500000000000000, 1031003.0999999999767169 966938.3100000000558794, 1030939.9000000000232831 966931.9399999999441206, 1030921.0999999999767169 966925.2500000000000000, 1030877.0999999999767169 966887.0000000000000000, 1030832.8000000000465661 966867.8100000000558794, 1030775.9000000000232831 966861.6899999999441206, 1030668.5999999999767169 966829.0600000000558794, 1030599.1999999999534339 966777.9399999999441206, 1030529.6999999999534339 966771.3100000000558794, 1030390.1999999999534339 966795.8100000000558794, 1030270.4000000000232831 966782.8100000000558794, 1030251.4000000000232831 966776.6300000000046566, 1030226.3000000000465661 966776.6899999999441206, 1030213.4000000000232831 966801.3100000000558794, 1030194.1999999999534339 966814.6899999999441206, 1030182.3000000000465661 966661.6899999999441206, 1030150.9000000000232831 966661.9399999999441206, 1030131.6999999999534339 966675.3100000000558794, 1030106.0999999999767169 966712.5600000000558794, 1030093.5000000000000000 966738.6899999999441206, 1030023.5999999999767169 966782.2500000000000000, 1029960.4000000000232831 966788.5000000000000000, 1029934.9000000000232831 966800.5600000000558794, 1029922.4000000000232831 966788.0600000000558794, 1029947.9000000000232831 966736.8100000000558794, 1029941.9000000000232831 966718.0000000000000000, 1029929.0999999999767169 966705.0000000000000000, 1029910.0999999999767169 966718.3800000000046566, 1029827.4000000000232831 966819.2500000000000000, 1029795.5999999999767169 966832.6300000000046566, 1029790.3000000000465661 966834.8100000000558794, 1029764.0000000000000000 966844.4399999999441206, 1029694.3000000000465661 966877.0600000000558794, 1029668.5999999999767169 966876.5600000000558794, 1029637.1999999999534339 966876.9399999999441206, 1029561.8000000000465661 966818.9399999999441206, 1029529.5999999999767169 966870.0000000000000000, 1029504.5999999999767169 966851.5000000000000000, 1029485.5000000000000000 966843.7500000000000000, 1029460.1999999999534339 966857.3800000000046566, 1029409.9000000000232831 966805.8100000000558794, 1029391.0000000000000000 966798.6300000000046566, 1029372.0000000000000000 966817.9399999999441206, 1029365.4000000000232831 966849.8800000000046566, 1029340.0999999999767169 966863.4399999999441206, 1029277.0000000000000000 966856.1300000000046566, 1029245.1999999999534339 966869.5000000000000000, 1029232.5999999999767169 966868.0600000000558794, 1029220.0000000000000000 966849.5000000000000000, 1029194.5999999999767169 966843.0600000000558794, 1029156.5999999999767169 966862.2500000000000000, 1029131.3000000000465661 966855.3100000000558794, 1029080.8000000000465661 966830.3800000000046566, 1029061.9000000000232831 966830.6300000000046566, 1029036.5999999999767169 966829.7500000000000000, 1028960.5000000000000000 966868.0600000000558794, 1028922.5999999999767169 966867.1899999999441206, 1028884.5999999999767169 966887.3100000000558794, 1028859.3000000000465661 966879.3800000000046566, 1028789.9000000000232831 966842.2500000000000000, 1028726.8000000000465661 966829.3100000000558794, 1028638.0999999999767169 966847.6300000000046566, 1028619.0999999999767169 966860.5000000000000000, 1028581.0999999999767169 966867.1300000000046566, 1028555.9000000000232831 966867.1899999999441206, 1028524.3000000000465661 966840.4399999999441206, 1028499.0999999999767169 966840.0000000000000000, 1028473.6999999999534339 966847.1300000000046566, 1028353.0000000000000000 966935.5000000000000000, 1028315.0999999999767169 966941.6300000000046566, 1028308.1999999999534339 966938.3800000000046566, 1028302.4000000000232831 966935.1300000000046566, 1028289.6999999999534339 966916.6300000000046566, 1028264.5999999999767169 966897.6300000000046566, 1028252.1999999999534339 966872.6300000000046566, 1028233.4000000000232831 966832.7500000000000000, 1028195.5999999999767169 966814.3100000000558794, 1028043.9000000000232831 966794.6300000000046566, 1027967.9000000000232831 966768.2500000000000000, 1027911.3000000000465661 966737.0600000000558794, 1027848.1999999999534339 966673.5600000000558794, 1027797.9000000000232831 966647.0600000000558794, 1027747.5000000000000000 966640.6899999999441206, 1027671.4000000000232831 966646.8800000000046566, 1027620.9000000000232831 966633.5600000000558794, 1027557.8000000000465661 966595.5600000000558794, 1027532.6999999999534339 966563.5000000000000000, 1027494.8000000000465661 966505.4399999999441206, 1027419.0000000000000000 966493.1300000000046566, 1027356.1999999999534339 966460.6300000000046566, 1027324.4000000000232831 966454.0000000000000000, 1027305.5000000000000000 966435.1899999999441206, 1027305.6999999999534339 966409.0600000000558794, 1027286.6999999999534339 966384.3100000000558794, 1027229.9000000000232831 966351.6300000000046566, 1026989.9000000000232831 966344.7500000000000000, 1026951.8000000000465661 966338.3800000000046566, 1026831.4000000000232831 966357.0000000000000000, 1026749.1999999999534339 966382.5600000000558794, 1026717.5999999999767169 966381.9399999999441206, 1026660.8000000000465661 966376.3100000000558794, 1026572.3000000000465661 966330.8800000000046566, 1026496.3000000000465661 966349.6899999999441206, 1026433.0999999999767169 966342.8100000000558794, 1026344.5000000000000000 966361.1300000000046566, 1026319.3000000000465661 966349.1300000000046566, 1026288.0000000000000000 966279.2500000000000000, 1026275.4000000000232831 966260.7500000000000000, 1026269.0999999999767169 966228.3800000000046566, 1026294.9000000000232831 966189.6899999999441206, 1026288.6999999999534339 966164.8800000000046566, 1026295.0999999999767169 966152.0600000000558794, 1026276.1999999999534339 966119.7500000000000000, 1026244.4000000000232831 966113.0600000000558794, 1026219.3000000000465661 966087.0600000000558794, 1026213.3000000000465661 966056.1899999999441206, 1026206.9000000000232831 966030.3800000000046566, 1026181.8000000000465661 966023.9399999999441206, 1026112.0000000000000000 966074.5000000000000000, 1026086.5999999999767169 966081.1300000000046566, 1026023.5999999999767169 966061.7500000000000000, 1026004.3000000000465661 966106.6899999999441206, 1025985.1999999999534339 966118.5600000000558794, 1025972.8000000000465661 966111.5600000000558794, 1025966.5999999999767169 966054.1300000000046566, 1025947.6999999999534339 966029.3100000000558794, 1025884.5000000000000000 966009.5000000000000000, 1025871.8000000000465661 966010.0000000000000000, 1025827.8000000000465661 965978.2500000000000000, 1025796.0999999999767169 965965.0000000000000000, 1025770.8000000000465661 965971.6300000000046566, 1025663.0999999999767169 966034.8800000000046566, 1025625.0000000000000000 966065.6300000000046566, 1025593.3000000000465661 966078.5000000000000000, 1025574.3000000000465661 966072.7500000000000000, 1025549.1999999999534339 966040.7500000000000000, 1025486.0999999999767169 966027.8800000000046566, 1025410.0000000000000000 966033.6300000000046566, 1025340.5000000000000000 966026.5000000000000000, 1025296.1999999999534339 966059.0000000000000000, 1025283.0999999999767169 966109.7500000000000000, 1025295.5999999999767169 966173.3800000000046566, 1025257.3000000000465661 966192.6300000000046566, 1025143.4000000000232831 966230.0600000000558794, 1025099.0999999999767169 966216.8800000000046566, 1025061.3000000000465661 966198.4399999999441206, 1024953.8000000000465661 966223.0600000000558794, 1024878.0000000000000000 966185.1300000000046566, 1024846.4000000000232831 966191.5000000000000000, 1024852.3000000000465661 966267.5000000000000000, 1024864.8000000000465661 966300.0600000000558794, 1024864.8000000000465661 966306.0600000000558794, 1024858.3000000000465661 966337.5000000000000000, 1024832.8000000000465661 966369.1300000000046566, 1024744.0999999999767169 966400.5000000000000000, 1024718.6999999999534339 966426.1899999999441206, 1024616.5999999999767169 966604.0600000000558794, 1024559.1999999999534339 966686.8100000000558794, 1024529.4000000000232831 966707.1300000000046566, 1024470.5999999999767169 966724.1300000000046566, 1024426.1999999999534339 966737.5600000000558794, 1024407.0999999999767169 966730.8800000000046566, 1024356.8000000000465661 966686.3800000000046566, 1024312.5999999999767169 966635.6300000000046566, 1024287.8000000000465661 966622.5600000000558794, 1024237.0000000000000000 966628.2500000000000000, 1024218.0000000000000000 966623.0600000000558794, 1024116.9000000000232831 966620.8100000000558794, 1024040.9000000000232831 966628.5600000000558794, 1023983.9000000000232831 966647.0600000000558794, 1023901.3000000000465661 966716.2500000000000000, 1023856.5999999999767169 966767.3100000000558794, 1023818.9000000000232831 966780.0000000000000000, 1023799.8000000000465661 966779.8100000000558794, 1023781.0000000000000000 966766.5000000000000000, 1023724.0999999999767169 966754.3800000000046566, 1023635.4000000000232831 966760.1300000000046566, 1023534.0999999999767169 966798.5600000000558794, 1023432.8000000000465661 966823.4399999999441206, 1023375.6999999999534339 966849.0000000000000000, 1023020.1999999999534339 967114.3800000000046566, 1023007.4000000000232831 967134.5000000000000000, 1022988.3000000000465661 967140.3100000000558794, 1022963.0000000000000000 967140.4399999999441206, 1022937.9000000000232831 967132.9399999999441206, 1022868.0000000000000000 967158.0000000000000000, 1022817.3000000000465661 967203.3100000000558794, 1022766.4000000000232831 967254.0600000000558794, 1022715.6999999999534339 967304.4399999999441206, 1022671.1999999999534339 967329.8800000000046566, 1022658.5999999999767169 967329.9399999999441206, 1022645.8000000000465661 967342.5000000000000000, 1022633.1999999999534339 967355.0600000000558794, 1022607.8000000000465661 967380.7500000000000000, 1022588.5999999999767169 967399.1300000000046566, 1022563.1999999999534339 967412.2500000000000000, 1022531.4000000000232831 967437.6899999999441206, 1022499.8000000000465661 967456.5600000000558794, 1022455.4000000000232831 967482.5600000000558794, 1022430.0999999999767169 967507.1899999999441206, 1022404.6999999999534339 967539.3800000000046566, 1022373.0000000000000000 967538.6899999999441206, 1022334.9000000000232831 967551.8800000000046566, 1022315.8000000000465661 967577.7500000000000000, 1022296.5000000000000000 967627.7500000000000000, 1022296.6999999999534339 967641.2500000000000000, 1022289.6999999999534339 967704.7500000000000000, 1022283.3000000000465661 967743.1899999999441206, 1022270.4000000000232831 967773.8100000000558794, 1022226.0999999999767169 967825.3800000000046566, 1022194.3000000000465661 967863.8800000000046566, 1022168.9000000000232831 967882.0000000000000000, 1022130.6999999999534339 967908.1899999999441206, 1022111.6999999999534339 967952.1899999999441206, 1022111.4000000000232831 967965.7500000000000000, 1022098.8000000000465661 967983.8100000000558794, 1022120.6999999999534339 968009.4399999999441206, 1022132.0999999999767169 968049.1300000000046566, 1022174.4000000000232831 968041.3100000000558794, 1022193.5000000000000000 968022.4399999999441206, 1022269.4000000000232831 967996.6300000000046566, 1022358.0000000000000000 967991.8800000000046566, 1022370.8000000000465661 967972.3100000000558794, 1022377.5000000000000000 967902.7500000000000000, 1022402.9000000000232831 967858.0600000000558794, 1022466.5999999999767169 967806.6300000000046566, 1022504.8000000000465661 967736.8100000000558794, 1022625.5999999999767169 967609.7500000000000000, 1022689.0999999999767169 967558.8800000000046566, 1022765.0000000000000000 967553.1300000000046566, 1022860.0000000000000000 967541.1300000000046566, 1022923.3000000000465661 967502.8100000000558794, 1022986.5999999999767169 967477.5000000000000000, 1023062.6999999999534339 967496.3800000000046566, 1023100.5999999999767169 967490.7500000000000000, 1023138.5999999999767169 967458.5600000000558794, 1023138.9000000000232831 967414.3800000000046566, 1023132.5999999999767169 967389.5600000000558794, 1023139.1999999999534339 967369.6899999999441206, 1023132.8000000000465661 967357.4399999999441206, 1023126.5000000000000000 967351.1899999999441206, 1023126.4000000000232831 967337.6300000000046566, 1023132.9000000000232831 967324.8100000000558794, 1023209.3000000000465661 967254.8800000000046566, 1023228.3000000000465661 967229.5000000000000000, 1023253.6999999999534339 967211.3800000000046566, 1023285.1999999999534339 967224.5600000000558794, 1023348.5999999999767169 967231.3800000000046566, 1023373.8000000000465661 967231.3100000000558794, 1023392.8000000000465661 967250.0600000000558794, 1023405.4000000000232831 967249.0600000000558794, 1023493.4000000000232831 967307.5600000000558794, 1023582.0000000000000000 967352.3800000000046566, 1023626.0999999999767169 967384.1899999999441206, 1023657.4000000000232831 967436.0000000000000000, 1023638.3000000000465661 967453.8800000000046566, 1023612.9000000000232831 967453.9399999999441206, 1023581.5999999999767169 967447.2500000000000000, 1023549.8000000000465661 967454.6300000000046566, 1023518.3000000000465661 967453.4399999999441206, 1023511.9000000000232831 967447.1899999999441206, 1023492.9000000000232831 967454.0600000000558794, 1023480.3000000000465661 967460.5600000000558794, 1023467.5000000000000000 967459.6300000000046566, 1023454.8000000000465661 967473.1899999999441206, 1023461.0000000000000000 967479.4399999999441206, 1023498.9000000000232831 967536.5000000000000000, 1023505.0000000000000000 967555.3100000000558794, 1023511.1999999999534339 967556.1300000000046566, 1023695.0999999999767169 967499.6300000000046566, 1023713.9000000000232831 967493.7500000000000000, 1023758.3000000000465661 967498.9399999999441206, 1023783.5999999999767169 967493.3800000000046566, 1023815.3000000000465661 967461.3800000000046566, 1023872.1999999999534339 967454.4399999999441206, 1023942.0999999999767169 967410.8100000000558794, 1024011.6999999999534339 967385.3100000000558794, 1024018.3000000000465661 967366.4399999999441206, 1024018.4000000000232831 967347.3800000000046566, 1024031.1999999999534339 967327.8100000000558794, 1024037.5000000000000000 967315.5000000000000000, 1024062.9000000000232831 967296.8100000000558794, 1024095.0000000000000000 967239.8100000000558794, 1024120.0999999999767169 967220.6899999999441206, 1024139.0999999999767169 967219.8800000000046566, 1024151.8000000000465661 967221.3100000000558794, 1024196.0999999999767169 967226.5000000000000000, 1024215.0999999999767169 967227.1899999999441206, 1024253.0999999999767169 967221.5600000000558794, 1024284.6999999999534339 967214.1899999999441206, 1024316.4000000000232831 967195.2500000000000000, 1024329.0999999999767169 967183.1899999999441206, 1024348.3000000000465661 967138.6899999999441206, 1024373.5000000000000000 967125.6300000000046566, 1024417.9000000000232831 967120.2500000000000000, 1024456.0000000000000000 967126.1899999999441206, 1024493.8000000000465661 967138.5600000000558794, 1024531.5999999999767169 967151.5000000000000000, 1024582.0999999999767169 967164.9399999999441206, 1024613.8000000000465661 967177.6300000000046566, 1024626.3000000000465661 967190.1899999999441206, 1024632.5999999999767169 967208.9399999999441206, 1024613.4000000000232831 967222.8100000000558794, 1024588.0999999999767169 967228.3800000000046566, 1024588.0999999999767169 967253.4399999999441206, 1024613.1999999999534339 967280.0000000000000000, 1024632.1999999999534339 967279.6899999999441206, 1024841.3000000000465661 967223.1300000000046566, 1024892.0999999999767169 967190.9399999999441206, 1024911.0999999999767169 967184.5600000000558794, 1024955.3000000000465661 967203.7500000000000000, 1025031.0999999999767169 967191.5600000000558794, 1025037.5000000000000000 967192.7500000000000000, 1025170.3000000000465661 967179.5600000000558794, 1025240.0000000000000000 967186.1899999999441206, 1025271.4000000000232831 967199.3800000000046566, 1025296.8000000000465661 967204.8100000000558794, 1025372.6999999999534339 967193.5600000000558794, 1025404.4000000000232831 967174.1300000000046566, 1025467.8000000000465661 967109.7500000000000000, 1025487.0999999999767169 967098.3800000000046566, 1025499.9000000000232831 967101.3800000000046566, 1025506.0000000000000000 967097.6300000000046566, 1025512.3000000000465661 967091.8100000000558794, 1025537.5999999999767169 967084.6899999999441206, 1025582.1999999999534339 967060.2500000000000000, 1025645.1999999999534339 967079.6300000000046566, 1025746.1999999999534339 967136.5600000000558794, 1025847.3000000000465661 967150.3100000000558794, 1025910.4000000000232831 967169.2500000000000000, 1025960.9000000000232831 967182.0600000000558794, 1026074.8000000000465661 967175.7500000000000000, 1026093.9000000000232831 967169.4399999999441206, 1026125.3000000000465661 967183.6899999999441206, 1026144.0999999999767169 967195.8800000000046566, 1026201.0999999999767169 967252.6899999999441206, 1026226.3000000000465661 967259.6899999999441206, 1026251.5999999999767169 967246.5000000000000000, 1026333.9000000000232831 967222.4399999999441206, 1026359.1999999999534339 967227.9399999999441206, 1026390.5999999999767169 967279.2500000000000000, 1026598.4000000000232831 967432.9399999999441206, 1026661.5999999999767169 967483.9399999999441206, 1026737.0999999999767169 967528.9399999999441206, 1026787.6999999999534339 967541.3100000000558794, 1026800.4000000000232831 967535.2500000000000000, 1026838.0999999999767169 967554.7500000000000000, 1026875.9000000000232831 967599.2500000000000000, 1026907.4000000000232831 967605.4399999999441206, 1026932.9000000000232831 967605.8800000000046566, 1027123.0999999999767169 967524.0600000000558794, 1027205.4000000000232831 967499.5000000000000000, 1027319.5999999999767169 967461.0000000000000000, 1027345.0000000000000000 967435.8800000000046566, 1027344.9000000000232831 967397.2500000000000000, 1027332.5999999999767169 967352.6300000000046566, 1027326.4000000000232831 967327.7500000000000000, 1027332.9000000000232831 967288.3800000000046566, 1027345.5000000000000000 967288.8800000000046566, 1027364.5999999999767169 967295.0600000000558794, 1027414.8000000000465661 967378.2500000000000000, 1027439.9000000000232831 967391.1899999999441206, 1027477.9000000000232831 967366.0000000000000000, 1027503.3000000000465661 967385.5000000000000000, 1027515.8000000000465661 967410.5600000000558794, 1027490.3000000000465661 967435.6899999999441206, 1027546.6999999999534339 967569.7500000000000000, 1027565.4000000000232831 967582.5000000000000000, 1027609.9000000000232831 967582.6300000000046566, 1027666.4000000000232831 967640.4399999999441206, 1027691.5999999999767169 967647.3800000000046566, 1027723.4000000000232831 967633.9399999999441206, 1027742.3000000000465661 967647.7500000000000000, 1027761.3000000000465661 967646.9399999999441206, 1027780.0000000000000000 967660.1899999999441206, 1027805.4000000000232831 967665.6300000000046566, 1027881.5000000000000000 967654.3800000000046566, 1028014.0999999999767169 967673.8100000000558794, 1028045.8000000000465661 967686.0600000000558794, 1028064.3000000000465661 967723.8100000000558794, 1028038.8000000000465661 967794.1899999999441206, 1028051.0999999999767169 967814.2500000000000000, 1028139.9000000000232831 967832.5000000000000000, 1028165.0999999999767169 967826.8800000000046566, 1028216.4000000000232831 967737.9399999999441206, 1028235.3000000000465661 967718.1300000000046566, 1028285.9000000000232831 967693.3800000000046566, 1028330.1999999999534339 967686.9399999999441206, 1028349.3000000000465661 967694.1899999999441206, 1028399.6999999999534339 967713.1300000000046566, 1028507.3000000000465661 967726.0600000000558794, 1028620.5999999999767169 967790.0000000000000000, 1028677.9000000000232831 967758.0000000000000000, 1028759.9000000000232831 967771.5600000000558794, 1028791.4000000000232831 967791.2500000000000000, 1028829.4000000000232831 967798.1899999999441206, 1028924.4000000000232831 967771.5600000000558794, 1028943.4000000000232831 967778.2500000000000000, 1028962.1999999999534339 967810.6300000000046566, 1029075.6999999999534339 967868.0000000000000000, 1029069.3000000000465661 967893.3100000000558794, 1029037.3000000000465661 967913.3100000000558794, 1029018.5999999999767169 967906.0600000000558794, 1028917.5000000000000000 967848.6300000000046566, 1028841.9000000000232831 967822.2500000000000000, 1028803.8000000000465661 967861.0000000000000000, 1028790.5999999999767169 967962.3800000000046566, 1028790.5000000000000000 967981.9399999999441206, 1028802.8000000000465661 968045.6899999999441206, 1028846.9000000000232831 968090.4399999999441206, 1028928.9000000000232831 968097.0000000000000000, 1028954.4000000000232831 968096.8800000000046566, 1029093.5000000000000000 968078.9399999999441206, 1029169.5999999999767169 968066.1899999999441206, 1029226.4000000000232831 968072.3100000000558794, 1029384.4000000000232831 968086.1899999999441206, 1029434.9000000000232831 968105.0600000000558794, 1029529.8000000000465661 968137.6300000000046566, 1029586.5999999999767169 968117.6899999999441206, 1029650.3000000000465661 968061.3100000000558794, 1029802.8000000000465661 967953.5000000000000000, 1029847.0999999999767169 967922.0000000000000000, 1029954.9000000000232831 967883.3100000000558794, 1030055.9000000000232831 967896.5600000000558794, 1030137.8000000000465661 967941.2500000000000000, 1030200.9000000000232831 967999.2500000000000000, 1030213.5000000000000000 968024.8100000000558794, 1030200.5999999999767169 968056.4399999999441206, 1030200.4000000000232831 968088.5600000000558794, 1030231.9000000000232831 968113.8800000000046566, 1030307.9000000000232831 968120.1899999999441206, 1030421.5999999999767169 968140.4399999999441206, 1030453.1999999999534339 968140.5600000000558794, 1030485.0000000000000000 968128.1899999999441206, 1030586.4000000000232831 968077.2500000000000000, 1030649.5000000000000000 968083.5600000000558794, 1030674.9000000000232831 968077.5000000000000000, 1030751.0999999999767169 968045.6300000000046566, 1030852.0999999999767169 968033.3100000000558794, 1030934.4000000000232831 968046.3800000000046566, 1030959.6999999999534339 968046.8100000000558794, 1030985.0999999999767169 968015.1300000000046566, 1031004.3000000000465661 967957.1300000000046566, 1031042.5999999999767169 967887.8100000000558794, 1031080.5999999999767169 967856.0600000000558794, 1031112.3000000000465661 967881.2500000000000000, 1031143.4000000000232831 967952.2500000000000000, 1031231.6999999999534339 968009.1899999999441206, 1031244.3000000000465661 968034.7500000000000000, 1031250.5000000000000000 968067.0600000000558794, 1031288.0999999999767169 968143.2500000000000000, 1031287.9000000000232831 968181.8800000000046566, 1031275.0000000000000000 968219.5000000000000000, 1031274.9000000000232831 968251.6300000000046566, 1031293.8000000000465661 968270.4399999999441206, 1031287.4000000000232831 968289.2500000000000000, 1031280.9000000000232831 968321.1300000000046566, 1031299.5999999999767169 968359.9399999999441206, 1031305.8000000000465661 968385.8100000000558794, 1031293.0000000000000000 968416.9399999999441206, 1031293.0000000000000000 968436.0000000000000000, 1031330.8000000000465661 968455.9399999999441206, 1031368.9000000000232831 968443.3100000000558794, 1031406.9000000000232831 968418.1300000000046566, 1031432.3000000000465661 968411.5000000000000000, 1031457.4000000000232831 968417.9399999999441206, 1031533.1999999999534339 968456.3800000000046566, 1031558.5999999999767169 968418.1899999999441206, 1031577.8000000000465661 968411.8100000000558794, 1031621.8000000000465661 968431.0600000000558794, 1031672.3000000000465661 968463.0000000000000000, 1031672.1999999999534339 968488.1300000000046566, 1031672.1999999999534339 968507.6899999999441206, 1031691.1999999999534339 968520.8800000000046566, 1031710.0999999999767169 968514.5600000000558794, 1031792.4000000000232831 968508.5600000000558794, 1031817.5999999999767169 968508.5000000000000000, 1031899.6999999999534339 968527.6300000000046566, 1031962.9000000000232831 968560.0000000000000000, 1032019.5000000000000000 968585.1899999999441206, 1032070.0000000000000000 968630.1899999999441206, 1032082.5999999999767169 968649.2500000000000000, 1032113.9000000000232831 968681.0600000000558794, 1032182.9000000000232831 968821.0000000000000000, 1032252.0999999999767169 968891.3100000000558794, 1032296.4000000000232831 968911.0000000000000000, 1032315.3000000000465661 968905.2500000000000000, 1032397.4000000000232831 968925.3100000000558794, 1032441.5000000000000000 968968.5600000000558794, 1032473.0999999999767169 968987.8100000000558794, 1032529.8000000000465661 969001.5000000000000000, 1032618.0999999999767169 969033.8100000000558794, 1032662.4000000000232831 969078.6300000000046566, 1032674.5999999999767169 969129.2500000000000000, 1032718.9000000000232831 969147.9399999999441206, 1032762.9000000000232831 969193.2500000000000000, 1032819.6999999999534339 969242.0000000000000000, 1032857.3000000000465661 969249.4399999999441206, 1032901.9000000000232831 969229.9399999999441206, 1032920.8000000000465661 969243.1899999999441206, 1032932.5000000000000000 969306.4399999999441206, 1033019.5000000000000000 969416.0600000000558794, 1033075.9000000000232831 969448.8100000000558794, 1033158.0999999999767169 969449.3100000000558794, 1033208.4000000000232831 969461.7500000000000000, 1033264.5999999999767169 969520.5000000000000000, 1033308.5000000000000000 969546.2500000000000000, 1033465.0000000000000000 969674.5600000000558794, 1033508.5000000000000000 969738.4399999999441206, 1033552.3000000000465661 969784.2500000000000000, 1033652.8000000000465661 969836.6300000000046566, 1033708.6999999999534339 969893.9399999999441206, 1033740.4000000000232831 969907.6899999999441206, 1033835.0000000000000000 969927.7500000000000000, 1033872.4000000000232831 969958.7500000000000000, 1033903.1999999999534339 970035.1899999999441206, 1034022.0000000000000000 970138.5000000000000000, 1034146.9000000000232831 970268.1300000000046566, 1034190.9000000000232831 970287.8800000000046566, 1034248.0999999999767169 970274.8800000000046566, 1034273.0999999999767169 970287.8100000000558794, 1034328.6999999999534339 970390.8100000000558794, 1034366.4000000000232831 970416.3100000000558794, 1034410.5999999999767169 970423.4399999999441206, 1034441.9000000000232831 970442.7500000000000000, 1034516.5999999999767169 970544.8800000000046566, 1034541.3000000000465661 970583.4399999999441206, 1034572.3000000000465661 970634.8100000000558794, 1034596.4000000000232831 970724.1300000000046566, 1034640.4000000000232831 970743.2500000000000000, 1034710.1999999999534339 970737.8100000000558794, 1034747.9000000000232831 970750.7500000000000000, 1034785.3000000000465661 970795.3800000000046566, 1034860.9000000000232831 970821.6899999999441206, 1034873.3000000000465661 970847.7500000000000000, 1034898.0999999999767169 970879.8100000000558794, 1034960.9000000000232831 970918.8100000000558794, 1034973.0999999999767169 970943.8100000000558794, 1034972.4000000000232831 970995.0600000000558794, 1034952.4000000000232831 971072.1899999999441206, 1034957.9000000000232831 971148.1899999999441206, 1034982.8000000000465661 971173.1899999999441206, 1035008.1999999999534339 971180.1300000000046566, 1035040.0000000000000000 971174.2500000000000000, 1035229.0999999999767169 971208.3800000000046566, 1035486.0999999999767169 971401.1300000000046566, 1035510.5000000000000000 971458.2500000000000000, 1035534.5999999999767169 971561.0600000000558794, 1035572.3000000000465661 971586.5600000000558794, 1035635.3000000000465661 971594.3800000000046566, 1035748.9000000000232831 971614.6899999999441206, 1035837.5999999999767169 971602.8800000000046566, 1035862.8000000000465661 971608.8100000000558794, 1035894.3000000000465661 971635.5600000000558794, 1035956.5999999999767169 971706.1899999999441206, 1036075.9000000000232831 971757.7500000000000000, 1036214.8000000000465661 971785.0000000000000000, 1036233.9000000000232831 971785.1899999999441206, 1036284.4000000000232831 971786.5600000000558794, 1036347.5999999999767169 971792.8800000000046566, 1036398.5999999999767169 971768.1300000000046566, 1036455.3000000000465661 971762.1899999999441206, 1036474.5000000000000000 971755.8800000000046566, 1036576.1999999999534339 971712.4399999999441206, 1036595.0999999999767169 971712.6300000000046566, 1036607.0999999999767169 971763.3100000000558794, 1036612.5999999999767169 971834.3100000000558794, 1036613.0999999999767169 971899.0000000000000000, 1036694.4000000000232831 971952.6899999999441206, 1036731.3000000000465661 972020.8800000000046566, 1036756.4000000000232831 972033.8800000000046566, 1036826.0000000000000000 972011.3100000000558794, 1036976.8000000000465661 972092.7500000000000000, 1036995.4000000000232831 972130.0600000000558794, 1037001.6999999999534339 972137.3100000000558794, 1037021.5000000000000000 972150.5000000000000000, 1037045.9000000000232831 972156.5000000000000000, 1037108.3000000000465661 972209.0600000000558794, 1037170.5000000000000000 972292.1899999999441206, 1037195.4000000000232831 972336.2500000000000000, 1037195.3000000000465661 972362.3100000000558794, 1037220.0999999999767169 972393.8800000000046566, 1037225.6999999999534339 972445.8100000000558794, 1037275.5999999999767169 972509.3800000000046566, 1037370.1999999999534339 972548.0600000000558794, 1037389.4000000000232831 972541.6899999999441206, 1037440.8000000000465661 972466.3100000000558794, 1037530.3000000000465661 972402.8100000000558794, 1037613.5999999999767169 972365.6300000000046566, 1037723.8000000000465661 972281.6899999999441206, 1037775.5999999999767169 972255.8800000000046566, 1037814.5999999999767169 972230.6899999999441206, 1038017.9000000000232831 972194.4399999999441206, 1038036.8000000000465661 972194.6300000000046566, 1038080.0999999999767169 972220.3800000000046566, 1038186.5999999999767169 972234.8800000000046566, 1038205.5999999999767169 972236.1300000000046566, 1038313.5000000000000000 972192.9399999999441206, 1038408.1999999999534339 972168.3100000000558794, 1038509.1999999999534339 972163.5000000000000000, 1038585.5000000000000000 972113.6300000000046566, 1038642.5999999999767169 972107.6300000000046566, 1038661.8000000000465661 972089.2500000000000000, 1038693.3000000000465661 972082.9399999999441206, 1038712.3000000000465661 972082.6300000000046566, 1038756.1999999999534339 972109.3100000000558794, 1038781.5999999999767169 972109.3100000000558794, 1038844.9000000000232831 972103.5600000000558794, 1038914.8000000000465661 972085.5600000000558794, 1038946.3000000000465661 972085.7500000000000000, 1038977.8000000000465661 972105.4399999999441206, 1039034.6999999999534339 972098.5000000000000000, 1039110.6999999999534339 972106.3100000000558794, 1039205.9000000000232831 972081.6899999999441206, 1039358.0999999999767169 972057.1899999999441206, 1039396.6999999999534339 972025.9399999999441206, 1039410.0000000000000000 971987.7500000000000000, 1039501.9000000000232831 971873.0000000000000000, 1039521.1999999999534339 971847.0600000000558794, 1039546.4000000000232831 971841.5000000000000000, 1039577.6999999999534339 971874.3100000000558794, 1039591.8000000000465661 971890.1899999999441206, 1039616.5999999999767169 971922.2500000000000000, 1039635.4000000000232831 971936.5600000000558794, 1039660.6999999999534339 971923.4399999999441206, 1039691.9000000000232831 971924.5600000000558794, 1039711.0999999999767169 971924.2500000000000000, 1039813.5000000000000000 971967.0600000000558794, 1039885.0999999999767169 971976.0600000000558794, 1039904.8000000000465661 971974.7500000000000000, 1040017.0999999999767169 971879.1899999999441206, 1040071.8000000000465661 971851.7500000000000000, 1040166.6999999999534339 971845.7500000000000000, 1040236.5999999999767169 971815.1899999999441206, 1040319.0999999999767169 971802.6300000000046566, 1040610.4000000000232831 971762.1899999999441206, 1040763.1999999999534339 971686.9399999999441206, 1040832.9000000000232831 971694.5000000000000000, 1040889.5999999999767169 971688.5600000000558794, 1041124.5999999999767169 971600.8100000000558794, 1041188.1999999999534339 971570.5000000000000000, 1041201.3000000000465661 971539.4399999999441206, 1041226.9000000000232831 971520.2500000000000000, 1041258.5999999999767169 971513.8800000000046566, 1041340.8000000000465661 971521.4399999999441206, 1041359.6999999999534339 971521.1300000000046566, 1041385.5999999999767169 971483.8800000000046566, 1041404.8000000000465661 971470.5000000000000000, 1041474.4000000000232831 971458.5600000000558794, 1041519.4000000000232831 971395.9399999999441206, 1041544.8000000000465661 971388.8100000000558794, 1041620.5000000000000000 971415.1899999999441206, 1041714.5000000000000000 971467.4399999999441206, 1041764.8000000000465661 971493.8100000000558794, 1041777.6999999999534339 971487.3100000000558794, 1041871.3000000000465661 971583.6300000000046566, 1041972.0000000000000000 971629.0600000000558794, 1042041.4000000000232831 971618.5600000000558794, 1042066.8000000000465661 971623.9399999999441206, 1042091.9000000000232831 971650.0000000000000000, 1042148.4000000000232831 971670.1300000000046566, 1042281.5000000000000000 971644.9399999999441206, 1042326.3000000000465661 971614.5000000000000000, 1042382.9000000000232831 971622.0600000000558794, 1042421.0000000000000000 971614.9399999999441206, 1042466.0000000000000000 971571.4399999999441206, 1042491.1999999999534339 971564.8100000000558794, 1042522.4000000000232831 971584.1300000000046566, 1042541.4000000000232831 971584.6899999999441206, 1042586.0000000000000000 971572.8100000000558794, 1042648.5000000000000000 971631.3800000000046566, 1042717.9000000000232831 971650.0000000000000000, 1042755.8000000000465661 971644.3100000000558794, 1042800.5999999999767169 971605.8100000000558794, 1042851.4000000000232831 971581.0600000000558794, 1042945.9000000000232831 971608.1899999999441206, 1042965.0999999999767169 971608.3800000000046566, 1043009.5999999999767169 971582.8800000000046566, 1043028.5999999999767169 971590.1300000000046566, 1043065.5000000000000000 971660.8100000000558794, 1043109.5999999999767169 971687.0000000000000000, 1043122.3000000000465661 971686.0000000000000000, 1043171.9000000000232831 971756.0600000000558794, 1043190.5999999999767169 971781.8100000000558794, 1043240.9000000000232831 971795.7500000000000000, 1043317.4000000000232831 971758.4399999999441206, 1043336.1999999999534339 971758.1300000000046566, 1043386.5000000000000000 971791.1300000000046566, 1043449.6999999999534339 971784.8800000000046566, 1043519.4000000000232831 971792.5000000000000000, 1043538.1999999999534339 971792.1300000000046566, 1043589.0999999999767169 971780.4399999999441206, 1043614.4000000000232831 971767.8800000000046566, 1043672.1999999999534339 971711.6899999999441206, 1043684.9000000000232831 971692.1300000000046566, 1043704.1999999999534339 971673.2500000000000000, 1043729.4000000000232831 971667.6300000000046566, 1043754.8000000000465661 971673.6300000000046566, 1043779.8000000000465661 971699.6300000000046566, 1043829.8000000000465661 971732.1300000000046566, 1043892.8000000000465661 971757.5000000000000000, 1043924.5999999999767169 971745.1300000000046566, 1044026.6999999999534339 971670.5600000000558794, 1044128.5000000000000000 971627.1300000000046566, 1044364.5999999999767169 971458.0600000000558794, 1044549.0000000000000000 971357.9399999999441206, 1044651.1999999999534339 971294.9399999999441206, 1044752.8000000000465661 971277.5000000000000000, 1044879.0999999999767169 971290.7500000000000000, 1044904.3000000000465661 971291.6899999999441206, 1044967.9000000000232831 971260.3800000000046566, 1045025.5999999999767169 971203.7500000000000000, 1045076.5999999999767169 971165.9399999999441206, 1045146.4000000000232831 971154.0000000000000000, 1045184.5000000000000000 971129.2500000000000000, 1045210.0000000000000000 971104.1300000000046566, 1045261.0999999999767169 971079.3800000000046566, 1045292.9000000000232831 971047.4399999999441206, 1045369.9000000000232831 970984.9399999999441206, 1045510.0999999999767169 970884.6899999999441206, 1045605.1999999999534339 970866.0600000000558794, 1045681.5000000000000000 970841.7500000000000000, 1045713.4000000000232831 970816.3800000000046566, 1045814.9000000000232831 970779.3800000000046566, 1045916.9000000000232831 970736.0000000000000000, 1046068.8000000000465661 970717.9399999999441206, 1046163.5999999999767169 970726.4399999999441206, 1046226.6999999999534339 970739.3100000000558794, 1046265.0000000000000000 970707.0600000000558794, 1046322.5999999999767169 970663.5600000000558794, 1046348.5000000000000000 970613.8100000000558794, 1046369.1999999999534339 970480.5000000000000000, 1046407.9000000000232831 970403.5600000000558794, 1046575.0000000000000000 970208.3800000000046566, 1046606.5999999999767169 970189.9399999999441206, 1046670.1999999999534339 970177.2500000000000000, 1046721.0000000000000000 970159.0000000000000000, 1046739.9000000000232831 970165.2500000000000000, 1046853.5000000000000000 970179.0000000000000000, 1046935.5999999999767169 970193.0000000000000000, 1046992.5999999999767169 970187.0600000000558794, 1047017.8000000000465661 970193.0600000000558794, 1047080.9000000000232831 970206.8800000000046566, 1047112.5000000000000000 970207.1300000000046566, 1047207.5000000000000000 970183.5000000000000000, 1047485.9000000000232831 970180.1899999999441206, 1047599.9000000000232831 970162.3100000000558794, 1047682.0000000000000000 970169.8100000000558794, 1047700.9000000000232831 970169.0600000000558794, 1047802.5999999999767169 970151.1899999999441206, 1047878.5999999999767169 970145.4399999999441206, 1047915.9000000000232831 970197.5000000000000000, 1047959.9000000000232831 970223.6899999999441206, 1047991.3000000000465661 970223.9399999999441206, 1048073.5999999999767169 970217.8800000000046566, 1048105.5000000000000000 970205.5000000000000000, 1048219.6999999999534339 970168.5600000000558794, 1048263.9000000000232831 970168.6899999999441206, 1048282.9000000000232831 970175.8800000000046566, 1048358.9000000000232831 970176.1300000000046566, 1048421.9000000000232831 970195.5600000000558794, 1048542.1999999999534339 970171.3800000000046566, 1048567.8000000000465661 970158.7500000000000000, 1048599.3000000000465661 970166.5000000000000000, 1048669.0000000000000000 970159.9399999999441206, 1048687.8999999999068677 970160.6899999999441206, 1048694.0000000000000000 970180.5000000000000000, 1048680.8999999999068677 970199.1300000000046566, 1048680.8000000000465661 970236.7500000000000000, 1048711.6000000000931323 970269.0600000000558794, 1048743.3000000000465661 970269.6899999999441206, 1048762.3000000000465661 970269.3800000000046566, 1048857.5000000000000000 970238.2500000000000000, 1048920.8000000000465661 970246.0600000000558794, 1048946.3000000000465661 970227.4399999999441206, 1048940.8000000000465661 970175.5000000000000000, 1048884.3999999999068677 970123.7500000000000000, 1048891.1000000000931323 970098.8800000000046566, 1048923.0000000000000000 970073.4399999999441206, 1048954.8000000000465661 970068.0600000000558794, 1048998.6000000000931323 970094.3100000000558794, 1049035.6000000000931323 970157.9399999999441206, 1049041.5000000000000000 970201.8100000000558794, 1049065.8999999999068677 970260.0000000000000000, 1049121.8000000000465661 970349.8800000000046566, 1049259.1000000000931323 970504.0600000000558794, 1049284.0000000000000000 970516.0600000000558794, 1049340.3999999999068677 970561.8100000000558794, 1049466.3999999999068677 970607.1300000000046566, 1049529.0000000000000000 970659.6300000000046566, 1049591.8999999999068677 970679.5600000000558794, 1049667.8000000000465661 970699.3800000000046566, 1049686.8999999999068677 970693.5600000000558794, 1049737.8000000000465661 970668.3100000000558794, 1049808.1000000000931323 970605.1300000000046566, 1049858.6000000000931323 970599.5000000000000000, 1049903.3999999999068677 970568.0000000000000000, 1049966.6000000000931323 970574.8100000000558794, 1050055.5000000000000000 970544.0000000000000000, 1050087.1000000000931323 970538.6300000000046566, 1050112.3000000000465661 970539.0600000000558794, 1050175.5000000000000000 970563.9399999999441206, 1050352.0000000000000000 970585.5600000000558794, 1050447.1000000000931323 970573.9399999999441206, 1050541.6000000000931323 970594.0600000000558794, 1050567.1000000000931323 970588.3800000000046566, 1050599.1000000000931323 970562.0000000000000000, 1050681.5000000000000000 970537.4399999999441206, 1050700.5000000000000000 970538.6300000000046566, 1050763.5000000000000000 970564.0000000000000000, 1050820.3999999999068677 970559.0600000000558794, 1050845.8000000000465661 970559.0000000000000000, 1050877.1000000000931323 970577.7500000000000000, 1050940.3000000000465661 970598.1300000000046566, 1051065.8999999999068677 970663.0000000000000000, 1051128.8999999999068677 970675.8800000000046566, 1051211.3999999999068677 970664.3800000000046566, 1051256.0000000000000000 970619.8100000000558794, 1051281.6000000000931323 970614.7500000000000000, 1051312.8000000000465661 970640.0000000000000000, 1051331.5000000000000000 970659.7500000000000000, 1051350.5000000000000000 970665.9399999999441206, 1051369.5000000000000000 970660.1300000000046566, 1051388.3999999999068677 970666.3800000000046566, 1051425.3000000000465661 970756.0600000000558794, 1051468.8999999999068677 970800.8800000000046566, 1051544.1000000000931323 970851.8100000000558794, 1051662.8000000000465661 970974.7500000000000000, 1051712.8999999999068677 971013.1899999999441206, 1051857.6000000000931323 971065.2500000000000000, 1051920.8999999999068677 971059.5600000000558794, 1051958.6000000000931323 971073.5000000000000000, 1052059.8999999999068677 971087.1899999999441206, 1052167.3000000000465661 971100.2500000000000000, 1052293.8000000000465661 971083.8100000000558794, 1052375.8000000000465661 971103.8800000000046566, 1052420.0000000000000000 971111.0000000000000000, 1052515.1000000000931323 971099.0000000000000000, 1052533.8999999999068677 971098.6899999999441206, 1052578.3000000000465661 971112.8800000000046566, 1052603.3999999999068677 971112.8100000000558794, 1052635.1000000000931323 971112.4399999999441206, 1052736.1000000000931323 971120.6899999999441206, 1052831.5000000000000000 971089.0600000000558794, 1052888.8000000000465661 971058.5600000000558794, 1052946.3000000000465661 971007.8800000000046566, 1053066.5000000000000000 970983.1899999999441206, 1053117.8000000000465661 970952.4399999999441206, 1053149.8999999999068677 970901.9399999999441206, 1053226.8000000000465661 970832.5000000000000000, 1053272.0000000000000000 970750.8100000000558794, 1053356.1000000000931323 970604.2500000000000000, 1053508.8999999999068677 970517.5000000000000000, 1053730.8999999999068677 970481.4399999999441206, 1053781.8999999999068677 970449.7500000000000000, 1053838.8999999999068677 970431.1899999999441206, 1053940.6000000000931323 970407.3800000000046566, 1054061.3999999999068677 970332.5000000000000000, 1054131.8999999999068677 970269.3100000000558794, 1054151.3999999999068677 970224.3800000000046566, 1054189.8999999999068677 970181.0600000000558794, 1054183.8999999999068677 970162.2500000000000000, 1054177.8999999999068677 970136.4399999999441206, 1054248.1000000000931323 970079.3100000000558794, 1054254.8000000000465661 970049.3800000000046566, 1054248.8999999999068677 970016.0600000000558794, 1054262.0000000000000000 969978.3800000000046566, 1054256.0000000000000000 969940.0600000000558794, 1054269.3999999999068677 969895.8100000000558794, 1054269.8000000000465661 969870.1899999999441206, 1054245.3999999999068677 969800.0000000000000000, 1054264.3999999999068677 969780.6300000000046566, 1054296.0000000000000000 969799.8800000000046566, 1054321.3000000000465661 969800.3100000000558794, 1054315.3999999999068677 969769.5000000000000000, 1054322.0000000000000000 969743.1300000000046566, 1054392.3999999999068677 969679.9399999999441206, 1054399.3000000000465661 969628.9399999999441206, 1054412.3999999999068677 969604.8800000000046566, 1054437.8999999999068677 969579.6300000000046566, 1054462.8999999999068677 969604.6899999999441206, 1054524.8999999999068677 969700.8100000000558794, 1054574.8999999999068677 969732.8100000000558794, 1054625.3999999999068677 969753.3100000000558794, 1054638.1000000000931323 969752.1899999999441206, 1054713.6000000000931323 969792.1899999999441206, 1054794.5000000000000000 969881.5000000000000000, 1054920.0000000000000000 969958.9399999999441206, 1055102.6000000000931323 970016.3800000000046566, 1055109.3000000000465661 970018.6300000000046566, 1055128.1000000000931323 970018.8100000000558794, 1055223.5000000000000000 969969.6300000000046566, 1055407.8000000000465661 969900.6300000000046566, 1055712.0000000000000000 969847.0000000000000000, 1055750.3999999999068677 969822.3100000000558794, 1055866.1000000000931323 969645.3800000000046566, 1055974.8000000000465661 969563.5000000000000000, 1056039.0000000000000000 969501.0600000000558794, 1056230.0000000000000000 969387.1300000000046566, 1056268.6000000000931323 969336.8100000000558794, 1056389.8999999999068677 969261.4399999999441206, 1056421.8999999999068677 969218.5000000000000000, 1056511.3999999999068677 969155.4399999999441206, 1056543.5000000000000000 969110.4399999999441206, 1056537.3999999999068677 969092.6300000000046566, 1056544.3000000000465661 969041.6899999999441206, 1056569.8000000000465661 969028.5600000000558794, 1056588.8000000000465661 969035.8100000000558794, 1056614.1000000000931323 969035.7500000000000000, 1056645.6000000000931323 969041.9399999999441206, 1056671.0000000000000000 969043.3800000000046566, 1056690.1000000000931323 969017.4399999999441206, 1056703.1000000000931323 968998.3800000000046566, 1056805.6000000000931323 968891.1899999999441206, 1056857.1000000000931323 968809.2500000000000000, 1056876.3000000000465661 968789.3800000000046566, 1056959.3000000000465661 968746.1899999999441206, 1057067.6000000000931323 968671.3800000000046566, 1057105.6000000000931323 968659.1899999999441206, 1057176.0000000000000000 968608.5600000000558794, 1057271.3000000000465661 968585.0000000000000000, 1057436.8000000000465661 968497.1899999999441206, 1057468.5000000000000000 968478.2500000000000000, 1057481.6000000000931323 968459.1899999999441206, 1057475.3999999999068677 968439.3800000000046566, 1057475.6000000000931323 968414.2500000000000000, 1057507.6000000000931323 968382.8100000000558794, 1057565.1000000000931323 968344.7500000000000000, 1057609.6000000000931323 968307.7500000000000000, 1057666.8000000000465661 968307.8100000000558794, 1057723.8999999999068677 968283.3100000000558794, 1057781.5000000000000000 968233.2500000000000000, 1057781.8999999999068677 968207.6300000000046566, 1057814.0000000000000000 968176.1899999999441206, 1057872.0000000000000000 968068.8800000000046566, 1057910.8999999999068677 968011.5600000000558794, 1057974.5000000000000000 967980.8100000000558794, 1058057.6000000000931323 967905.0000000000000000, 1058133.6000000000931323 967887.7500000000000000, 1058184.8999999999068677 967836.9399999999441206, 1058223.1000000000931323 967824.2500000000000000, 1058311.6000000000931323 967812.9399999999441206, 1058439.0000000000000000 967750.3100000000558794, 1058496.1000000000931323 967737.8800000000046566, 1058635.8999999999068677 967681.7500000000000000, 1058706.3999999999068677 967612.6300000000046566, 1058757.5000000000000000 967575.8100000000558794, 1058833.5000000000000000 967563.5600000000558794, 1058852.8000000000465661 967544.1899999999441206, 1058879.0000000000000000 967462.3100000000558794, 1058956.8000000000465661 967323.5600000000558794, 1059059.1000000000931323 967221.9399999999441206, 1059225.0000000000000000 967116.0600000000558794, 1059282.6000000000931323 967059.4399999999441206, 1059327.3000000000465661 967027.9399999999441206, 1059417.0000000000000000 966933.3800000000046566, 1059506.8999999999068677 966838.8100000000558794, 1059519.6000000000931323 966812.6899999999441206, 1059513.8000000000465661 966781.3100000000558794, 1059527.1000000000931323 966737.0600000000558794, 1059590.8999999999068677 966686.6899999999441206, 1059623.1000000000931323 966630.1899999999441206, 1059680.8000000000465661 966579.5600000000558794, 1059694.3999999999068677 966509.3100000000558794, 1059745.8000000000465661 966445.9399999999441206, 1059746.0000000000000000 966420.8800000000046566, 1059709.0000000000000000 966351.1300000000046566, 1059709.3999999999068677 966312.5000000000000000, 1059767.8000000000465661 966205.2500000000000000, 1059826.0000000000000000 966091.3800000000046566, 1059879.1000000000931323 965887.5000000000000000, 1059905.5000000000000000 965812.1300000000046566, 1059924.6000000000931323 965799.3800000000046566, 1059886.3000000000465661 965718.6899999999441206, 1059888.6000000000931323 965633.8100000000558794, 1059869.8000000000465661 965633.1899999999441206, 1059787.8000000000465661 965619.5600000000558794, 1059655.3999999999068677 965580.5000000000000000, 1059642.8000000000465661 965579.5600000000558794, 1059592.3000000000465661 965573.1899999999441206, 1059554.6000000000931323 965547.6899999999441206, 1059516.8999999999068677 965540.2500000000000000, 1059491.3000000000465661 965547.3800000000046566, 1059427.0000000000000000 965628.3800000000046566, 1059420.5000000000000000 965647.2500000000000000, 1059273.3999999999068677 965779.8800000000046566, 1059163.3999999999068677 965982.1300000000046566, 1059092.6000000000931323 966070.4399999999441206, 1059085.3999999999068677 966147.4399999999441206, 1059021.0000000000000000 966235.9399999999441206, 1059014.3000000000465661 966267.3100000000558794, 1059019.8999999999068677 966324.3100000000558794, 1058998.3999999999068677 966521.8100000000558794, 1058972.3000000000465661 966585.1300000000046566, 1058889.3000000000465661 966648.3800000000046566, 1058876.8999999999068677 966659.8800000000046566, 1058863.6000000000931323 966673.0000000000000000, 1058831.0000000000000000 966755.6899999999441206, 1058767.3000000000465661 966799.0000000000000000, 1058716.3999999999068677 966824.1899999999441206, 1058658.8000000000465661 966880.8100000000558794, 1058645.6000000000931323 966912.9399999999441206, 1058543.3999999999068677 967013.6300000000046566, 1058460.5000000000000000 967043.7500000000000000, 1058434.8999999999068677 967069.3800000000046566, 1058459.8999999999068677 967095.4399999999441206, 1058484.8000000000465661 967147.0000000000000000, 1058484.3999999999068677 967166.0600000000558794, 1058427.3999999999068677 967158.0000000000000000, 1058370.8999999999068677 967132.8100000000558794, 1058320.1000000000931323 967158.0600000000558794, 1058301.1000000000931323 967156.8800000000046566, 1058257.1000000000931323 967130.6300000000046566, 1058238.1000000000931323 967131.4399999999441206, 1058091.8000000000465661 967193.3100000000558794, 1058047.3999999999068677 967199.7500000000000000, 1058003.0000000000000000 967217.1899999999441206, 1057939.8999999999068677 967203.3100000000558794, 1057901.6000000000931323 967222.9399999999441206, 1057876.0000000000000000 967260.6300000000046566, 1057856.8000000000465661 967285.0600000000558794, 1057799.6000000000931323 967298.0600000000558794, 1057742.8000000000465661 967284.9399999999441206, 1057717.5000000000000000 967290.5000000000000000, 1057673.3000000000465661 967277.3100000000558794, 1057635.3000000000465661 967296.0000000000000000, 1057584.3000000000465661 967326.7500000000000000, 1057489.0000000000000000 967351.8800000000046566, 1057330.0000000000000000 967420.8100000000558794, 1057285.6000000000931323 967438.7500000000000000, 1057227.8000000000465661 967501.8800000000046566, 1057189.6000000000931323 967521.5600000000558794, 1057157.8999999999068677 967526.4399999999441206, 1057075.1000000000931323 967570.0600000000558794, 1057011.0000000000000000 967633.5000000000000000, 1056953.3000000000465661 967708.6899999999441206, 1056902.3999999999068677 967721.3800000000046566, 1056889.8999999999068677 967721.4399999999441206, 1056870.3000000000465661 967771.3800000000046566, 1056806.1000000000931323 967840.8100000000558794, 1056742.6000000000931323 967872.6300000000046566, 1056716.8999999999068677 967897.3100000000558794, 1056678.0000000000000000 967973.1899999999441206, 1056645.8000000000465661 968011.1899999999441206, 1056639.0000000000000000 968050.0600000000558794, 1056645.1000000000931323 968067.8100000000558794, 1056607.1000000000931323 968068.5000000000000000, 1056588.3000000000465661 968061.7500000000000000, 1056550.3999999999068677 968067.3800000000046566, 1056441.8000000000465661 968143.1899999999441206, 1056396.8999999999068677 968198.8100000000558794, 1056301.1000000000931323 968256.0600000000558794, 1056275.8000000000465661 968293.7500000000000000, 1056274.5000000000000000 968363.5000000000000000, 1056274.5000000000000000 968377.0600000000558794, 1056254.8999999999068677 968421.0000000000000000, 1056241.8000000000465661 968458.1899999999441206, 1056235.6000000000931323 968471.4399999999441206, 1056209.8999999999068677 968484.1300000000046566, 1056165.6000000000931323 968470.4399999999441206, 1056128.0000000000000000 968451.4399999999441206, 1056026.3000000000465661 968494.9399999999441206, 1055892.3999999999068677 968570.3800000000046566, 1055791.1000000000931323 968587.6899999999441206, 1055727.3000000000465661 968631.0600000000558794, 1055670.3000000000465661 968650.0000000000000000, 1055587.3999999999068677 968699.6899999999441206, 1055447.5000000000000000 968756.3100000000558794, 1055295.5000000000000000 968766.2500000000000000, 1055263.3999999999068677 968792.1899999999441206, 1055231.6000000000931323 968830.6300000000046566, 1055180.6000000000931323 968855.3800000000046566, 1055073.0000000000000000 968866.5000000000000000, 1054932.3000000000465661 968985.8800000000046566, 1054868.3999999999068677 969042.7500000000000000, 1054843.0000000000000000 969048.8100000000558794, 1054811.5000000000000000 969035.6300000000046566, 1054798.6000000000931323 969035.6300000000046566, 1054779.8000000000465661 969034.9399999999441206, 1054600.0000000000000000 969256.2500000000000000, 1054561.5000000000000000 969281.4399999999441206, 1054536.0000000000000000 969312.1899999999441206, 1054510.0000000000000000 969363.3800000000046566, 1054478.3999999999068677 969369.7500000000000000, 1054415.3000000000465661 969355.9399999999441206, 1054313.3999999999068677 969418.9399999999441206, 1054274.8999999999068677 969443.6300000000046566, 1054223.8999999999068677 969500.0000000000000000, 1054128.3999999999068677 969544.6899999999441206, 1054102.5000000000000000 969587.8800000000046566, 1054064.3999999999068677 969606.5600000000558794, 1054032.8000000000465661 969612.9399999999441206, 1053969.3999999999068677 969605.6300000000046566, 1053944.0000000000000000 969619.2500000000000000, 1053918.3000000000465661 969662.5000000000000000, 1053644.3000000000465661 969812.5000000000000000, 1053529.5000000000000000 969881.1300000000046566, 1053498.0000000000000000 969887.0000000000000000, 1053435.0000000000000000 969874.5600000000558794, 1053358.8000000000465661 969886.3800000000046566, 1053321.0000000000000000 969872.4399999999441206, 1053289.8999999999068677 969827.5600000000558794, 1053264.8000000000465661 969814.5600000000558794, 1053125.6000000000931323 969806.5000000000000000, 1053100.6000000000931323 969801.0600000000558794, 1053043.5000000000000000 969818.5000000000000000, 1053005.0000000000000000 969857.2500000000000000, 1052973.3000000000465661 969868.1300000000046566, 1052795.3999999999068677 969918.3800000000046566, 1052642.8000000000465661 969980.0000000000000000, 1052566.8999999999068677 969998.2500000000000000, 1052497.3000000000465661 970004.2500000000000000, 1052472.0000000000000000 969996.8100000000558794, 1052415.1000000000931323 970003.7500000000000000, 1052313.5000000000000000 970020.6300000000046566, 1052263.0000000000000000 970019.7500000000000000, 1052243.8000000000465661 970019.5600000000558794, 1052168.0000000000000000 970031.3100000000558794, 1052111.3999999999068677 970006.5600000000558794, 1052023.0000000000000000 969985.2500000000000000, 1051998.0000000000000000 969978.8100000000558794, 1051941.5000000000000000 969934.0600000000558794, 1051877.8999999999068677 969946.3100000000558794, 1051820.8999999999068677 969964.2500000000000000, 1051802.0000000000000000 969957.5600000000558794, 1051771.1000000000931323 969913.6899999999441206, 1051745.6000000000931323 969913.8100000000558794, 1051701.1000000000931323 969925.7500000000000000, 1051682.3999999999068677 969918.5600000000558794, 1051468.0000000000000000 969852.3800000000046566, 1051361.3000000000465661 969794.1899999999441206, 1051285.8999999999068677 969768.3100000000558794, 1051260.8999999999068677 969741.8100000000558794, 1051248.1000000000931323 969741.8100000000558794, 1051197.8999999999068677 969716.8800000000046566, 1051141.3000000000465661 969695.6899999999441206, 1051090.8000000000465661 969689.8800000000046566, 1050983.0000000000000000 969707.5000000000000000, 1050856.8999999999068677 969681.2500000000000000, 1050800.5000000000000000 969634.9399999999441206, 1050725.8000000000465661 969551.4399999999441206, 1050682.3000000000465661 969475.5000000000000000, 1050620.3999999999068677 969366.2500000000000000, 1050595.3999999999068677 969353.3100000000558794, 1050582.3999999999068677 969360.3100000000558794, 1050557.3999999999068677 969339.8100000000558794, 1050557.8999999999068677 969320.7500000000000000, 1050551.8999999999068677 969295.9399999999441206, 1050520.5000000000000000 969270.1899999999441206, 1050432.6000000000931323 969218.2500000000000000, 1050224.5000000000000000 969176.8800000000046566, 1050205.5000000000000000 969177.6899999999441206, 1050168.3000000000465661 969201.8800000000046566, 1050141.8999999999068677 969201.5000000000000000, 1050073.8999999999068677 969067.4399999999441206, 1050049.0000000000000000 969047.9399999999441206, 1050029.8999999999068677 969048.2500000000000000, 1049922.3000000000465661 969066.3800000000046566, 1049820.3999999999068677 969116.3100000000558794, 1049763.3999999999068677 969109.2500000000000000, 1049700.1000000000931323 969114.4399999999441206, 1049567.8999999999068677 969094.5000000000000000, 1049511.3999999999068677 969049.2500000000000000, 1049492.5000000000000000 969049.0000000000000000, 1049448.0000000000000000 969055.4399999999441206, 1049429.0000000000000000 969047.6899999999441206, 1049366.6000000000931323 968997.6899999999441206, 1049259.6000000000931323 968952.0600000000558794, 1049202.8000000000465661 968957.5000000000000000, 1049139.5000000000000000 968949.1899999999441206, 1049056.3000000000465661 968976.8100000000558794, 1049037.8000000000465661 968987.1300000000046566, 1048987.0000000000000000 968999.7500000000000000, 1048898.3000000000465661 969004.5600000000558794, 1048866.8000000000465661 968997.8800000000046566, 1048816.6000000000931323 968971.8800000000046566, 1048772.5000000000000000 968965.2500000000000000, 1048721.8999999999068677 968970.9399999999441206, 1048607.3000000000465661 969013.9399999999441206, 1048549.9000000000232831 969045.9399999999441206, 1048448.8000000000465661 969056.7500000000000000, 1048334.5999999999767169 969080.6899999999441206, 1048290.0999999999767169 969087.1300000000046566, 1048162.9000000000232831 969149.6300000000046566, 1048042.5000000000000000 969167.3100000000558794, 1047998.3000000000465661 969166.6899999999441206, 1047903.3000000000465661 969160.1899999999441206, 1047884.5999999999767169 969153.0000000000000000, 1047770.5000000000000000 969177.9399999999441206, 1047700.5000000000000000 969214.9399999999441206, 1047674.8000000000465661 969240.1300000000046566, 1047630.4000000000232831 969258.6300000000046566, 1047585.8000000000465661 969271.0000000000000000, 1047509.4000000000232831 969321.3800000000046566, 1047477.6999999999534339 969314.6899999999441206, 1047446.0999999999767169 969326.6300000000046566, 1047426.9000000000232831 969340.0000000000000000, 1047383.0000000000000000 969313.7500000000000000, 1047364.1999999999534339 969301.0000000000000000, 1047319.5999999999767169 969332.5600000000558794, 1047192.1999999999534339 969406.6899999999441206, 1047173.0999999999767169 969400.3800000000046566, 1047154.1999999999534339 969393.1899999999441206, 1047135.4000000000232831 969373.9399999999441206, 1047110.4000000000232831 969361.5000000000000000, 1047072.5000000000000000 969368.0600000000558794, 1046990.5999999999767169 969347.0000000000000000, 1046920.9000000000232831 969346.4399999999441206, 1046889.5999999999767169 969315.1300000000046566, 1046826.9000000000232831 969281.6899999999441206, 1046807.8000000000465661 969282.5000000000000000, 1046706.4000000000232831 969306.3800000000046566, 1046598.6999999999534339 969317.0000000000000000, 1046554.3000000000465661 969342.4399999999441206, 1046452.5999999999767169 969354.3100000000558794, 1046421.0000000000000000 969360.1899999999441206, 1046345.3000000000465661 969346.8100000000558794, 1046243.9000000000232831 969371.2500000000000000, 1046225.1999999999534339 969382.5600000000558794, 1046192.5999999999767169 969422.0600000000558794, 1046147.9000000000232831 969453.0600000000558794, 1046128.9000000000232831 969445.8100000000558794, 1046078.6999999999534339 969426.3800000000046566, 1046059.8000000000465661 969425.6899999999441206, 1045918.8000000000465661 969572.1300000000046566, 1045822.0999999999767169 969710.1300000000046566, 1045789.8000000000465661 969773.7500000000000000, 1045764.3000000000465661 969785.8100000000558794, 1045745.3000000000465661 969792.1899999999441206, 1045675.5999999999767169 969785.0600000000558794, 1045492.1999999999534339 969802.9399999999441206, 1045377.9000000000232831 969845.9399999999441206, 1045307.9000000000232831 969877.0000000000000000, 1045263.6999999999534339 969857.3100000000558794, 1045219.5999999999767169 969849.6899999999441206, 1045200.5999999999767169 969850.4399999999441206, 1045181.3000000000465661 969888.3800000000046566, 1045162.0000000000000000 969906.7500000000000000, 1045067.0999999999767169 969912.8100000000558794, 1044818.9000000000232831 970024.6899999999441206, 1044799.8000000000465661 970031.0000000000000000, 1044724.1999999999534339 970016.6899999999441206, 1044673.4000000000232831 970029.8100000000558794, 1044494.8000000000465661 970148.3800000000046566, 1044462.8000000000465661 970192.8100000000558794, 1044429.8000000000465661 970287.0600000000558794, 1044379.0000000000000000 970325.3100000000558794, 1044296.4000000000232831 970344.3800000000046566, 1043904.4000000000232831 970333.4399999999441206, 1043847.5999999999767169 970319.2500000000000000, 1043816.0999999999767169 970319.1300000000046566, 1043790.6999999999534339 970319.1899999999441206, 1043740.5000000000000000 970293.1899999999441206, 1043689.9000000000232831 970279.8100000000558794, 1043614.0000000000000000 970298.1300000000046566, 1043487.8000000000465661 970265.3800000000046566, 1043335.4000000000232831 970313.9399999999441206, 1043183.3000000000465661 970350.5600000000558794, 1043132.4000000000232831 970356.2500000000000000, 1043082.4000000000232831 970317.1899999999441206, 1043031.9000000000232831 970311.3100000000558794, 1043000.3000000000465661 970311.1300000000046566, 1042968.3000000000465661 970355.1300000000046566, 1042943.0999999999767169 970341.1899999999441206, 1042879.9000000000232831 970321.8100000000558794, 1042791.5999999999767169 970308.0000000000000000, 1042741.3000000000465661 970294.5600000000558794, 1042653.3000000000465661 970242.6899999999441206, 1042596.8000000000465661 970224.0000000000000000, 1042577.5000000000000000 970229.3100000000558794, 1042539.8000000000465661 970223.4399999999441206, 1042476.6999999999534339 970203.0000000000000000, 1042413.5999999999767169 970197.1899999999441206, 1042362.8000000000465661 970208.3800000000046566, 1042312.0999999999767169 970207.0000000000000000, 1042148.0999999999767169 970199.4399999999441206, 1042034.0999999999767169 970204.7500000000000000, 1042008.0000000000000000 970256.0600000000558794, 1042001.4000000000232831 970274.3800000000046566, 1041944.1999999999534339 970306.3800000000046566, 1041887.0999999999767169 970317.3100000000558794, 1041842.9000000000232831 970305.1899999999441206, 1041817.9000000000232831 970285.6899999999441206, 1041799.0999999999767169 970279.5000000000000000, 1041754.3000000000465661 970323.5000000000000000, 1041735.0999999999767169 970341.3800000000046566, 1041715.9000000000232831 970347.6899999999441206, 1041665.8000000000465661 970322.2500000000000000, 1041646.9000000000232831 970309.0000000000000000, 1041583.5999999999767169 970314.7500000000000000, 1041533.3000000000465661 970276.1899999999441206, 1041470.6999999999534339 970249.7500000000000000, 1041458.5999999999767169 970219.7500000000000000, 1041420.9000000000232831 970166.1300000000046566, 1041370.5000000000000000 970159.1899999999441206, 1041269.0999999999767169 970178.6300000000046566, 1041250.1999999999534339 970184.3800000000046566, 1041173.9000000000232831 970202.1899999999441206, 1041110.6999999999534339 970201.8800000000046566, 1041078.8000000000465661 970226.8100000000558794, 1041047.0000000000000000 970232.6899999999441206, 1040946.0999999999767169 970212.3800000000046566, 1040876.5000000000000000 970217.3100000000558794, 1040787.9000000000232831 970210.5600000000558794, 1040496.5999999999767169 970259.1300000000046566, 1040401.3000000000465661 970302.3100000000558794, 1040369.5000000000000000 970295.6300000000046566, 1040344.4000000000232831 970295.6899999999441206, 1040325.0999999999767169 970307.5000000000000000, 1040230.3000000000465661 970313.0600000000558794, 1040198.5000000000000000 970325.9399999999441206, 1040135.4000000000232831 970319.1300000000046566, 1040008.0999999999767169 970368.1300000000046566, 1039989.3000000000465661 970361.3800000000046566, 1039944.8000000000465661 970373.8800000000046566, 1039843.3000000000465661 970410.2500000000000000, 1039824.0999999999767169 970410.5600000000558794, 1039780.0999999999767169 970404.3800000000046566, 1039761.3000000000465661 970397.1899999999441206, 1039748.4000000000232831 970397.6899999999441206, 1039698.3000000000465661 970371.8100000000558794, 1039616.3000000000465661 970357.6899999999441206, 1039565.5999999999767169 970356.3100000000558794, 1039464.3000000000465661 970362.1899999999441206, 1039400.8000000000465661 970380.8800000000046566, 1039337.9000000000232831 970361.0000000000000000, 1039312.4000000000232831 970361.0600000000558794, 1039160.8000000000465661 970372.0600000000558794, 1039065.8000000000465661 970378.1300000000046566, 1038964.9000000000232831 970357.8100000000558794, 1038882.4000000000232831 970368.8100000000558794, 1038813.0000000000000000 970356.2500000000000000, 1038749.8000000000465661 970360.9399999999441206, 1038680.4000000000232831 970334.8100000000558794, 1038636.1999999999534339 970353.2500000000000000, 1038610.3000000000465661 970391.9399999999441206, 1038590.4000000000232831 970455.0000000000000000, 1038564.8000000000465661 970492.7500000000000000, 1038520.3000000000465661 970511.1899999999441206, 1038482.1999999999534339 970511.2500000000000000, 1038431.8000000000465661 970504.3800000000046566, 1038412.8000000000465661 970497.1300000000046566, 1038393.6999999999534339 970503.4399999999441206, 1038343.4000000000232831 970490.5600000000558794, 1038299.1999999999534339 970483.3800000000046566, 1038280.1999999999534339 970489.7500000000000000, 1038260.6999999999534339 970528.1899999999441206, 1038247.5000000000000000 970578.9399999999441206, 1038183.8000000000465661 970609.1899999999441206, 1038056.4000000000232831 970684.8800000000046566, 1037987.1999999999534339 970658.1899999999441206, 1037968.1999999999534339 970664.5600000000558794, 1037930.4000000000232831 970645.5600000000558794, 1037911.5000000000000000 970625.3100000000558794, 1037867.3000000000465661 970638.2500000000000000, 1037848.3000000000465661 970632.0000000000000000, 1037779.4000000000232831 970574.2500000000000000, 1037741.1999999999534339 970598.4399999999441206, 1037721.9000000000232831 970617.3100000000558794, 1037702.9000000000232831 970623.6899999999441206, 1037639.8000000000465661 970609.7500000000000000, 1037576.5000000000000000 970628.9399999999441206, 1037513.4000000000232831 970614.6300000000046566, 1037436.9000000000232831 970653.0000000000000000, 1037411.5999999999767169 970658.6300000000046566, 1037380.0999999999767169 970651.9399999999441206, 1037354.6999999999534339 970658.0000000000000000, 1037303.4000000000232831 970696.8100000000558794, 1037277.8000000000465661 970721.0000000000000000, 1037252.5999999999767169 970733.5600000000558794, 1037221.0999999999767169 970726.9399999999441206, 1037195.6999999999534339 970732.5000000000000000, 1037093.8000000000465661 970788.5000000000000000, 1037062.0999999999767169 970795.3800000000046566, 1037036.5999999999767169 970807.4399999999441206, 1037005.0999999999767169 970795.2500000000000000, 1036979.9000000000232831 970794.3100000000558794, 1036941.4000000000232831 970825.0600000000558794, 1036909.8000000000465661 970832.4399999999441206, 1036846.9000000000232831 970812.0000000000000000, 1036815.4000000000232831 970792.8100000000558794, 1036697.5000000000000000 970613.2500000000000000, 1036647.5000000000000000 970568.1899999999441206, 1036452.4000000000232831 970495.7500000000000000, 1036377.0999999999767169 970444.2500000000000000, 1036364.4000000000232831 970444.2500000000000000, 1036320.6999999999534339 970412.0000000000000000, 1036183.8000000000465661 970232.2500000000000000, 1036133.8000000000465661 970180.6899999999441206, 1036089.6999999999534339 970161.0000000000000000, 1036045.9000000000232831 970129.1899999999441206, 1036021.0999999999767169 970083.6300000000046566, 1035889.4000000000232831 969999.9399999999441206, 1035833.0000000000000000 969961.1899999999441206, 1035808.0999999999767169 969929.6899999999441206, 1035771.4000000000232831 969813.8100000000558794, 1035746.9000000000232831 969762.6899999999441206, 1035671.8000000000465661 969704.1899999999441206, 1035659.8000000000465661 969648.0000000000000000, 1035641.0999999999767169 969621.7500000000000000, 1035590.9000000000232831 969595.7500000000000000, 1035571.9000000000232831 969596.0000000000000000, 1035540.3000000000465661 969601.8800000000046566, 1035515.0000000000000000 969601.9399999999441206, 1035490.4000000000232831 969556.3800000000046566, 1035471.5999999999767169 969537.1300000000046566, 1035452.5999999999767169 969537.3800000000046566, 1035389.3000000000465661 969549.6300000000046566, 1035351.8000000000465661 969504.5600000000558794, 1035352.4000000000232831 969453.4399999999441206, 1035352.5999999999767169 969433.8100000000558794, 1035321.3000000000465661 969408.5600000000558794, 1035289.8000000000465661 969408.9399999999441206, 1035099.3000000000465661 969457.5600000000558794, 1035017.4000000000232831 969437.0000000000000000, 1034992.4000000000232831 969424.0000000000000000, 1034966.8000000000465661 969443.1899999999441206, 1034953.5999999999767169 969481.3800000000046566, 1034934.4000000000232831 969499.7500000000000000, 1034915.5000000000000000 969500.0600000000558794, 1034865.1999999999534339 969486.6300000000046566, 1034840.1999999999534339 969473.6300000000046566, 1034821.0999999999767169 969460.8800000000046566, 1034783.0999999999767169 969453.5000000000000000, 1034739.1999999999534339 969433.2500000000000000, 1034695.9000000000232831 969363.8800000000046566, 1034677.0999999999767169 969343.6300000000046566, 1034677.8000000000465661 969286.3800000000046566, 1034691.0999999999767169 969243.2500000000000000, 1034691.3000000000465661 969223.6300000000046566, 1034629.0999999999767169 969146.5000000000000000, 1034460.0999999999767169 968992.6899999999441206, 1034435.0999999999767169 968979.6899999999441206, 1034409.5999999999767169 968984.7500000000000000, 1034230.4000000000232831 969167.4399999999441206, 1034173.0999999999767169 969198.5000000000000000, 1034122.1999999999534339 969204.6300000000046566, 1033914.1999999999534339 969164.8100000000558794, 1033863.6999999999534339 969144.4399999999441206, 1033838.6999999999534339 969131.9399999999441206, 1033789.5999999999767169 969003.6300000000046566, 1033733.4000000000232831 968946.2500000000000000, 1033689.4000000000232831 968932.6300000000046566, 1033645.4000000000232831 968894.3800000000046566, 1033627.1999999999534339 968849.5000000000000000, 1033627.5000000000000000 968811.8800000000046566, 1033647.1999999999534339 968766.8100000000558794, 1033647.4000000000232831 968748.3100000000558794, 1033622.5999999999767169 968716.2500000000000000, 1033622.9000000000232831 968691.1899999999441206, 1033642.0999999999767169 968671.2500000000000000, 1033661.0000000000000000 968670.9399999999441206, 1033679.8000000000465661 968691.1899999999441206, 1033692.0999999999767169 968710.3100000000558794, 1033704.9000000000232831 968710.1899999999441206, 1033742.6999999999534339 968717.1300000000046566, 1033761.9000000000232831 968698.2500000000000000, 1033768.8000000000465661 968647.8100000000558794, 1033693.9000000000232831 968576.2500000000000000, 1033700.4000000000232831 968551.8800000000046566, 1033706.9000000000232831 968538.6300000000046566, 1033713.5000000000000000 968519.7500000000000000, 1033707.4000000000232831 968493.3800000000046566, 1033688.9000000000232831 968468.5600000000558794, 1033663.5999999999767169 968467.6899999999441206, 1033587.0999999999767169 968512.0600000000558794, 1033555.5999999999767169 968517.9399999999441206, 1033529.9000000000232831 968543.0600000000558794, 1033541.9000000000232831 968587.7500000000000000, 1033528.9000000000232831 968613.8800000000046566, 1033496.8000000000465661 968656.8800000000046566, 1033496.5000000000000000 968675.9399999999441206, 1033502.6999999999534339 968688.6899999999441206, 1033489.8000000000465661 968714.3800000000046566, 1033470.6999999999534339 968714.1899999999441206, 1033408.8000000000465661 968618.4399999999441206, 1033290.0999999999767169 968496.0600000000558794, 1033247.3000000000465661 968380.5000000000000000, 1033216.0999999999767169 968342.1899999999441206, 1033096.5000000000000000 968283.6300000000046566, 1033058.9000000000232831 968251.0600000000558794, 1033014.5999999999767169 968231.3800000000046566, 1032964.3000000000465661 968179.8100000000558794, 1032913.8000000000465661 968146.3800000000046566, 1032888.5999999999767169 968114.3100000000558794, 1032825.5999999999767169 968093.9399999999441206, 1032749.5999999999767169 968084.6300000000046566, 1032724.3000000000465661 968078.1899999999441206, 1032673.9000000000232831 968021.1300000000046566, 1032598.8000000000465661 967867.3100000000558794, 1032542.3000000000465661 967778.3800000000046566, 1032460.3000000000465661 967752.2500000000000000, 1032384.4000000000232831 967739.9399999999441206, 1032327.5000000000000000 967751.8100000000558794, 1032301.9000000000232831 967771.5600000000558794, 1032238.5999999999767169 967783.7500000000000000, 1032207.0999999999767169 967784.1300000000046566, 1032188.0999999999767169 967776.4399999999441206, 1032169.5999999999767169 967700.4399999999441206, 1032182.4000000000232831 967675.3100000000558794, 1032188.5999999999767169 967656.5000000000000000), (1026124.3000000000465661 966144.2500000000000000, 1026143.3000000000465661 966144.4399999999441206, 1026162.0999999999767169 966163.6899999999441206, 1026149.4000000000232831 966176.2500000000000000, 1026124.0000000000000000 966170.3800000000046566, 1026111.4000000000232831 966156.8800000000046566, 1026124.3000000000465661 966144.2500000000000000), (1023891.9000000000232831 967359.8100000000558794, 1023910.8000000000465661 967360.0000000000000000, 1023898.0999999999767169 967385.6300000000046566, 1023866.0999999999767169 967410.6300000000046566, 1023802.9000000000232831 967416.7500000000000000, 1023771.4000000000232831 967410.1300000000046566, 1023783.9000000000232831 967390.5000000000000000, 1023866.5999999999767169 967365.8800000000046566, 1023891.9000000000232831 967359.8100000000558794), (1022975.5999999999767169 967177.5000000000000000, 1023045.0999999999767169 967190.5600000000558794, 1023057.5999999999767169 967210.1300000000046566, 1022994.0999999999767169 967261.5000000000000000, 1022930.5000000000000000 967318.3800000000046566, 1022835.5999999999767169 967369.0600000000558794, 1022765.5999999999767169 967419.6899999999441206, 1022759.3000000000465661 967400.8800000000046566, 1022772.3000000000465661 967361.6899999999441206, 1022791.5999999999767169 967298.1899999999441206, 1022810.8000000000465661 967260.7500000000000000, 1022836.1999999999534339 967235.0600000000558794, 1022880.5000000000000000 967209.6300000000046566, 1022931.3000000000465661 967191.3800000000046566, 1022975.5999999999767169 967177.5000000000000000), (1049960.6000000000931323 970046.3800000000046566, 1049979.5000000000000000 970053.1300000000046566, 1050023.0000000000000000 970111.4399999999441206, 1050066.8000000000465661 970143.1899999999441206, 1050109.8000000000465661 970245.2500000000000000, 1050090.5000000000000000 970271.0600000000558794, 1050045.8999999999068677 970289.5600000000558794, 1050020.8000000000465661 970288.6300000000046566, 1049989.1000000000931323 970281.9399999999441206, 1049944.8000000000465661 970294.3800000000046566, 1049925.8999999999068677 970288.1300000000046566, 1049913.5000000000000000 970262.0600000000558794, 1049907.8999999999068677 970206.1300000000046566, 1049927.5000000000000000 970148.6300000000046566, 1049921.5000000000000000 970134.8100000000558794, 1049928.5000000000000000 970077.8100000000558794, 1049960.6000000000931323 970046.3800000000046566), (1023139.9000000000232831 967210.6899999999441206, 1023158.9000000000232831 967210.8100000000558794, 1023152.3000000000465661 967242.7500000000000000, 1023127.0999999999767169 967274.4399999999441206, 1023088.5999999999767169 967338.7500000000000000, 1023075.6999999999534339 967414.0600000000558794, 1023018.4000000000232831 967439.5600000000558794, 1022980.5000000000000000 967446.1899999999441206, 1022917.0999999999767169 967458.8800000000046566, 1022891.9000000000232831 967470.0600000000558794, 1022860.0999999999767169 967496.0000000000000000, 1022790.4000000000232831 967508.4399999999441206, 1022765.0999999999767169 967508.0000000000000000, 1022759.3000000000465661 967463.5600000000558794, 1022809.9000000000232831 967420.3100000000558794, 1022854.3000000000465661 967400.3800000000046566, 1022917.6999999999534339 967369.5600000000558794, 1023019.4000000000232831 967286.5000000000000000, 1023044.9000000000232831 967254.8100000000558794, 1023095.5000000000000000 967223.0600000000558794, 1023139.9000000000232831 967210.6899999999441206), (1031826.9000000000232831 967897.0600000000558794, 1031845.9000000000232831 967909.8100000000558794, 1031864.5000000000000000 967979.7500000000000000, 1031857.5999999999767169 968062.8100000000558794, 1031882.5999999999767169 968183.6899999999441206, 1031888.3000000000465661 968259.6899999999441206, 1031869.4000000000232831 968273.5600000000558794, 1031831.4000000000232831 968260.5600000000558794, 1031787.4000000000232831 968234.3800000000046566, 1031736.8000000000465661 968227.0000000000000000, 1031654.6999999999534339 968195.3800000000046566, 1031623.3000000000465661 968138.0000000000000000, 1031604.5999999999767169 968081.1300000000046566, 1031604.8000000000465661 968055.0000000000000000, 1031649.3000000000465661 968010.9399999999441206, 1031700.1999999999534339 967979.2500000000000000, 1031725.4000000000232831 967959.5600000000558794, 1031801.5000000000000000 967909.7500000000000000, 1031826.9000000000232831 967897.0600000000558794)))
==10661== Invalid read of size 4
==10661==    at 0x402A6EDD: geos::QuadTreeNode::find(geos::Envelope *) (../index/quadtree/QuadTreeNode.cpp:66)
==10661==    by 0x402A788F: geos::QuadTreeRoot::insertContained(geos::QuadTreeNode *, geos::Envelope *, void *) (../index/quadtree/QuadTreeRoot.cpp:61)
==10661==    by 0x402A77F4: geos::QuadTreeRoot::insert(geos::Envelope *, void *) (../index/quadtree/QuadTreeRoot.cpp:40)
==10661==    by 0x402A6505: geos::Quadtree::insert(geos::Envelope *, void *) (../index/quadtree/Quadtree.cpp:57)
==10661==    Address 0x414C9810 is 28 bytes inside a block of size 36 free'd
==10661==    at 0x40168F45: __builtin_delete (vg_clientfuncs.c:199)
==10661==    by 0x402A6E1B: geos::QuadTreeNode::~QuadTreeNode(void) (../index/quadtree/QuadTreeNode.cpp:33)
==10661==    by 0x402A77CD: geos::QuadTreeRoot::insert(geos::Envelope *, void *) (../index/quadtree/QuadTreeRoot.cpp:33)
==10661==
==10661== Invalid read of size 8
==10661==    at 0x402A722B: geos::QuadTreeNodeBase::getSubnodeIndex(geos::Envelope *, geos::Coordinate *) (../index/quadtree/QuadTreeNodeBase.cpp:11)
==10661==    by 0x402A6EE6: geos::QuadTreeNode::find(geos::Envelope *) (../index/quadtree/QuadTreeNode.cpp:66)
==10661==    Address 0x4129F06C is 0 bytes inside a block of size 28 free'd
==10661==    by 0x402D866D: geos::Coordinate::~Coordinate(void) (../headers/geom.h:99)
==10661==    by 0x402A6DF9: geos::QuadTreeNode::~QuadTreeNode(void) (../index/quadtree/QuadTreeNode.cpp:32)
==10661==
==10661==    at 0x402A7244: geos::QuadTreeNodeBase::getSubnodeIndex(geos::Envelope *, geos::Coordinate *) (../index/quadtree/QuadTreeNodeBase.cpp:12)
==10661==    Address 0x4129F074 is 8 bytes inside a block of size 28 free'd
==10661==
==10661==    at 0x402A7265: geos::QuadTreeNodeBase::getSubnodeIndex(geos::Envelope *, geos::Coordinate *) (../index/quadtree/QuadTreeNodeBase.cpp:13)
==10661==
==10661==    at 0x402A728B: geos::QuadTreeNodeBase::getSubnodeIndex(geos::Envelope *, geos::Coordinate *) (../index/quadtree/QuadTreeNodeBase.cpp:15)
==10661==
==10661==    at 0x402A6EF6: geos::QuadTreeNode::find(geos::Envelope *) (../index/quadtree/QuadTreeNode.cpp:69)
==10661==    Address 0x414C9804 is 16 bytes inside a block of size 36 free'd
==10661==
==10661==    at 0x402A78A8: geos::QuadTreeRoot::insertContained(geos::QuadTreeNode *, geos::Envelope *, void *) (../index/quadtree/QuadTreeRoot.cpp:64)
==10661==    by 0x402CD15A: geos::QuadtreeNestedRingTester::buildQuadtree(void) (../operation/valid/QuadtreeNestedRingTester.cpp:75)
==10661==    Address 0x414C9808 is 20 bytes inside a block of size 36 free'd
==10661==
==10661==    at 0x402A74B7: geos::QuadTreeNodeBase::add(void *) (/usr/include/g++-3/stl_vector.h:319)
==10661==    by 0x402A78AF: geos::QuadTreeRoot::insertContained(geos::QuadTreeNode *, geos::Envelope *, void *) (../index/quadtree/QuadTreeRoot.cpp:64)
==10661==    Address 0x414C97F4 is 0 bytes inside a block of size 36 free'd
==10661==
==10661==    at 0x402A74B9: geos::QuadTreeNodeBase::add(void *) (/usr/include/g++-3/stl_vector.h:320)
==10661==    Address 0x414C984C is 4 bytes inside a block of size 12 free'd
==10661==    by 0x402A7469: geos::QuadTreeNodeBase::~QuadTreeNodeBase(void) (/usr/include/g++-3/stl_vector.h:266)
==10661==    by 0x402A6E06: geos::QuadTreeNode::~QuadTreeNode(void) (../index/quadtree/QuadTreeNode.cpp:33)
==10661==
==10661==    at 0x402A74BE: geos::QuadTreeNodeBase::add(void *) (/usr/include/g++-3/stl_vector.h:320)
==10661==    Address 0x414C9850 is 8 bytes inside a block of size 12 free'd
==10661==
==10661== Invalid write of size 4
==10661==    at 0x402A74D1: geos::QuadTreeNodeBase::add(void *) (/usr/include/g++-3/stl_vector.h:322)
==10661==
==10661==    at 0x402E0618: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:590)
==10661==    by 0x402A74DE: geos::QuadTreeNodeBase::add(void *) (/usr/include/g++-3/stl_vector.h:197)
==10661==
==10661==    at 0x402E061D: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:590)
==10661==
==10661==    at 0x402E0663: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:196)
==10661==    Address 0x414C9848 is 0 bytes inside a block of size 12 free'd
==10661==
==10661==    at 0x402E0714: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_alloc.h:402)
==10661==
==10661==    at 0x402E0751: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_uninitialized.h:78)
==10661==
==10661==    at 0x402E076D: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:95)
==10661==
==10661==    at 0x402E0775: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:95)
==10661==
==10661==    at 0x402E07DB: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:612)
==10661==
==10661==    at 0x402E07E0: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:613)
==10661==
==10661==    at 0x402E07EF: vector<void *, allocator<void *> >::_M_insert_aux(void **, void *const &) (/usr/include/g++-3/stl_vector.h:614)
==10661==
==10661==    at 0x402A75BE: geos::QuadTreeNodeBase::addAllItemsFromOverlapping(geos::Envelope *, vector<void *, allocator<void *> > *) (../index/quadtree/QuadTreeNodeBase.cpp:69)
==10661==    by 0x402A75C9: geos::QuadTreeNodeBase::addAllItemsFromOverlapping(geos::Envelope *, vector<void *, allocator<void *> > *) (../index/quadtree/QuadTreeNodeBase.cpp:69)
==10661==    by 0x402A656C: geos::Quadtree::query(geos::Envelope *) (../index/quadtree/Quadtree.cpp:67)
==10661==    by 0x402CCE2C: geos::QuadtreeNestedRingTester::isNonNested(void) (../operation/valid/QuadtreeNestedRingTester.cpp:39)
==10661==
==10661==    at 0x402A757D: geos::QuadTreeNodeBase::addAllItemsFromOverlapping(geos::Envelope *, vector<void *, allocator<void *> > *) (../index/quadtree/QuadTreeNodeBase.cpp:61)
pure virtual method called
// g++ test3.cpp -I/usr/local/include/geos -lgeos
#include "stdio.h"
#include "io.h"
#include "geom.h"
using namespace geos;
int main(int argC, char* argV[])
	WKTReader *r = new WKTReader();
	GeometryFactory *geomFactory;
	Geometry *g1, *g2 ;
	geomFactory= new GeometryFactory( new PrecisionModel(), -1);
	//g1 = r->read("MULTIPOLYGON(((1033707.6 1048313.1,1033694.9 1048315.7,1033659.9 1048344.3,1033627.6 1048388.8,1033620.9 1048426.8,1033623.6 1048471.3,1033623.6 1048480.8,1033616.8 1048503.2,1033629.1 1048541.3,1033668.3 1048707.6,1033696.3 1048755.6,1033721.4 1048771.6,1033724.5 1048772,1033737.2 1048772,1033772.1 1048756.4,1033794.6 1048721.9,1033811.1 1048667.4,1033814.8 1048613.6,1033815.1 1048597.5,1033809.2 1048556.1,1033809.3 1048549.6,1033797.1 1048501.9,1033790.9 1048492.2,1033773 1048399.6,1033760.6 1048377.6,1033741.8 1048357.8,1033742.1 1048341.8,1033713.9 1048313.4,1033707.6 1048313.1)))");
	//g1 = r->read("POLYGON((1033707.6 1048313.1,1033694.9 1048315.7,1033659.9 1048344.3,1033627.6 1048388.8,1033620.9 1048426.8,1033623.6 1048471.3,1033623.6 1048480.8,1033616.8 1048503.2,1033629.1 1048541.3,1033668.3 1048707.6,1033696.3 1048755.6,1033721.4 1048771.6,1033724.5 1048772,1033737.2 1048772,1033772.1 1048756.4,1033794.6 1048721.9,1033811.1 1048667.4,1033814.8 1048613.6,1033815.1 1048597.5,1033809.2 1048556.1,1033809.3 1048549.6,1033797.1 1048501.9,1033790.9 1048492.2,1033773 1048399.6,1033760.6 1048377.6,1033741.8 1048357.8,1033742.1 1048341.8,1033713.9 1048313.4,1033707.6 1048313.1))");
	g1 = r->read("MULTIPOLYGON(((1032188.6 967656.5,1032144.6 967630.25,1032125.7 967612,1032113.3 967585.94,1032113.4 967540.75,1032139.2 967458.44,1032145.8 967394.94,1032133.3 967350.31,1032108.2 967325.25,1032076.7 967311.56,1032051.4 967299.06,1032032.6 967298.94,1032000.8 967279.69,1031975.8 967240.63,1031957.3 967170.63,1031969.8 967152.13,1031963.8 967108.19,1031945.1 967057.38,1031875.7 967018.13,1031856.7 967017.88,1031806.1 967018.06,1031787.1 967010.88,1031711.4 966999,1031660.7 966999.19,1031527.8 967009.81,1031508.9 967004.63,1031427.1 966939.88,1031363.8 966920.44,1031325.8 966939.19,1031300.4 966965.81,1031268.6 966958.63,1031161.6 966913,1031098.1 966932.25,1031003.1 966938.31,1030939.9 966931.94,1030921.1 966925.25,1030877.1 966887,1030832.8 966867.81,1030775.9 966861.69,1030668.6 966829.06,1030599.2 966777.94,1030529.7 966771.31,1030390.2 966795.81,1030270.4 966782.81,1030251.4 966776.63,1030226.3 966776.69,1030213.4 966801.31,1030194.2 966814.69,1030182.3 966661.69,1030150.9 966661.94,1030131.7 966675.31,1030106.1 966712.56,1030093.5 966738.69,1030023.6 966782.25,1029960.4 966788.5,1029934.9 966800.56,1029922.4 966788.06,1029947.9 966736.81,1029941.9 966718,1029929.1 966705,1029910.1 966718.38,1029827.4 966819.25,1029795.6 966832.63,1029790.3 966834.81,1029764 966844.44,1029694.3 966877.06,1029668.6 966876.56,1029637.2 966876.94,1029561.8 966818.94,1029529.6 966870,1029504.6 966851.5,1029485.5 966843.75,1029460.2 966857.38,1029409.9 966805.81,1029391 966798.63,1029372 966817.94,1029365.4 966849.88,1029340.1 966863.44,1029277 966856.13,1029245.2 966869.5,1029232.6 966868.06,1029220 966849.5,1029194.6 966843.06,1029156.6 966862.25,1029131.3 966855.31,1029080.8 966830.38,1029061.9 966830.63,1029036.6 966829.75,1028960.5 966868.06,1028922.6 966867.19,1028884.6 966887.31,1028859.3 966879.38,1028789.9 966842.25,1028726.8 966829.31,1028638.1 966847.63,1028619.1 966860.5,1028581.1 966867.13,1028555.9 966867.19,1028524.3 966840.44,1028499.1 966840,1028473.7 966847.13,1028353 966935.5,1028315.1 966941.63,1028308.2 966938.38,1028302.4 966935.13,1028289.7 966916.63,1028264.6 966897.63,1028252.2 966872.63,1028233.4 966832.75,1028195.6 966814.31,1028043.9 966794.63,1027967.9 966768.25,1027911.3 966737.06,1027848.2 966673.56,1027797.9 966647.06,1027747.5 966640.69,1027671.4 966646.88,1027620.9 966633.56,1027557.8 966595.56,1027532.7 966563.5,1027494.8 966505.44,1027419 966493.13,1027356.2 966460.63,1027324.4 966454,1027305.5 966435.19,1027305.7 966409.06,1027286.7 966384.31,1027229.9 966351.63,1026989.9 966344.75,1026951.8 966338.38,1026831.4 966357,1026749.2 966382.56,1026717.6 966381.94,1026660.8 966376.31,1026572.3 966330.88,1026496.3 966349.69,1026433.1 966342.81,1026344.5 966361.13,1026319.3 966349.13,1026288 966279.25,1026275.4 966260.75,1026269.1 966228.38,1026294.9 966189.69,1026288.7 966164.88,1026295.1 966152.06,1026276.2 966119.75,1026244.4 966113.06,1026219.3 966087.06,1026213.3 966056.19,1026206.9 966030.38,1026181.8 966023.94,1026112 966074.5,1026086.6 966081.13,1026023.6 966061.75,1026004.3 966106.69,1025985.2 966118.56,1025972.8 966111.56,1025966.6 966054.13,1025947.7 966029.31,1025884.5 966009.5,1025871.8 966010,1025827.8 965978.25,1025796.1 965965,1025770.8 965971.63,1025663.1 966034.88,1025625 966065.63,1025593.3 966078.5,1025574.3 966072.75,1025549.2 966040.75,1025486.1 966027.88,1025410 966033.63,1025340.5 966026.5,1025296.2 966059,1025283.1 966109.75,1025295.6 966173.38,1025257.3 966192.63,1025143.4 966230.06,1025099.1 966216.88,1025061.3 966198.44,1024953.8 966223.06,1024878 966185.13,1024846.4 966191.5,1024852.3 966267.5,1024864.8 966300.06,1024864.8 966306.06,1024858.3 966337.5,1024832.8 966369.13,1024744.1 966400.5,1024718.7 966426.19,1024616.6 966604.06,1024559.2 966686.81,1024529.4 966707.13,1024470.6 966724.13,1024426.2 966737.56,1024407.1 966730.88,1024356.8 966686.38,1024312.6 966635.63,1024287.8 966622.56,1024237 966628.25,1024218 966623.06,1024116.9 966620.81,1024040.9 966628.56,1023983.9 966647.06,1023901.3 966716.25,1023856.6 966767.31,1023818.9 966780,1023799.8 966779.81,1023781 966766.5,1023724.1 966754.38,1023635.4 966760.13,1023534.1 966798.56,1023432.8 966823.44,1023375.7 966849,1023020.2 967114.38,1023007.4 967134.5,1022988.3 967140.31,1022963 967140.44,1022937.9 967132.94,1022868 967158,1022817.3 967203.31,1022766.4 967254.06,1022715.7 967304.44,1022671.2 967329.88,1022658.6 967329.94,1022645.8 967342.5,1022633.2 967355.06,1022607.8 967380.75,1022588.6 967399.13,1022563.2 967412.25,1022531.4 967437.69,1022499.8 967456.56,1022455.4 967482.56,1022430.1 967507.19,1022404.7 967539.38,1022373 967538.69,1022334.9 967551.88,1022315.8 967577.75,1022296.5 967627.75,1022296.7 967641.25,1022289.7 967704.75,1022283.3 967743.19,1022270.4 967773.81,1022226.1 967825.38,1022194.3 967863.88,1022168.9 967882,1022130.7 967908.19,1022111.7 967952.19,1022111.4 967965.75,1022098.8 967983.81,1022120.7 968009.44,1022132.1 968049.13,1022174.4 968041.31,1022193.5 968022.44,1022269.4 967996.63,1022358 967991.88,1022370.8 967972.31,1022377.5 967902.75,1022402.9 967858.06,1022466.6 967806.63,1022504.8 967736.81,1022625.6 967609.75,1022689.1 967558.88,1022765 967553.13,1022860 967541.13,1022923.3 967502.81,1022986.6 967477.5,1023062.7 967496.38,1023100.6 967490.75,1023138.6 967458.56,1023138.9 967414.38,1023132.6 967389.56,1023139.2 967369.69,1023132.8 967357.44,1023126.5 967351.19,1023126.4 967337.63,1023132.9 967324.81,1023209.3 967254.88,1023228.3 967229.5,1023253.7 967211.38,1023285.2 967224.56,1023348.6 967231.38,1023373.8 967231.31,1023392.8 967250.06,1023405.4 967249.06,1023493.4 967307.56,1023582 967352.38,1023626.1 967384.19,1023657.4 967436,1023638.3 967453.88,1023612.9 967453.94,1023581.6 967447.25,1023549.8 967454.63,1023518.3 967453.44,1023511.9 967447.19,1023492.9 967454.06,1023480.3 967460.56,1023467.5 967459.63,1023454.8 967473.19,1023461 967479.44,1023498.9 967536.5,1023505 967555.31,1023511.2 967556.13,1023695.1 967499.63,1023713.9 967493.75,1023758.3 967498.94,1023783.6 967493.38,1023815.3 967461.38,1023872.2 967454.44,1023942.1 967410.81,1024011.7 967385.31,1024018.3 967366.44,1024018.4 967347.38,1024031.2 967327.81,1024037.5 967315.5,1024062.9 967296.81,1024095 967239.81,1024120.1 967220.69,1024139.1 967219.88,1024151.8 967221.31,1024196.1 967226.5,1024215.1 967227.19,1024253.1 967221.56,1024284.7 967214.19,1024316.4 967195.25,1024329.1 967183.19,1024348.3 967138.69,1024373.5 967125.63,1024417.9 967120.25,1024456 967126.19,1024493.8 967138.56,1024531.6 967151.5,1024582.1 967164.94,1024613.8 967177.63,1024626.3 967190.19,1024632.6 967208.94,1024613.4 967222.81,1024588.1 967228.38,1024588.1 967253.44,1024613.2 967280,1024632.2 967279.69,1024841.3 967223.13,1024892.1 967190.94,1024911.1 967184.56,1024955.3 967203.75,1025031.1 967191.56,1025037.5 967192.75,1025170.3 967179.56,1025240 967186.19,1025271.4 967199.38,1025296.8 967204.81,1025372.7 967193.56,1025404.4 967174.13,1025467.8 967109.75,1025487.1 967098.38,1025499.9 967101.38,1025506 967097.63,1025512.3 967091.81,1025537.6 967084.69,1025582.2 967060.25,1025645.2 967079.63,1025746.2 967136.56,1025847.3 967150.31,1025910.4 967169.25,1025960.9 967182.06,1026074.8 967175.75,1026093.9 967169.44,1026125.3 967183.69,1026144.1 967195.88,1026201.1 967252.69,1026226.3 967259.69,1026251.6 967246.5,1026333.9 967222.44,1026359.2 967227.94,1026390.6 967279.25,1026598.4 967432.94,1026661.6 967483.94,1026737.1 967528.94,1026787.7 967541.31,1026800.4 967535.25,1026838.1 967554.75,1026875.9 967599.25,1026907.4 967605.44,1026932.9 967605.88,1027123.1 967524.06,1027205.4 967499.5,1027319.6 967461,1027345 967435.88,1027344.9 967397.25,1027332.6 967352.63,1027326.4 967327.75,1027332.9 967288.38,1027345.5 967288.88,1027364.6 967295.06,1027414.8 967378.25,1027439.9 967391.19,1027477.9 967366,1027503.3 967385.5,1027515.8 967410.56,1027490.3 967435.69,1027546.7 967569.75,1027565.4 967582.5,1027609.9 967582.63,1027666.4 967640.44,1027691.6 967647.38,1027723.4 967633.94,1027742.3 967647.75,1027761.3 967646.94,1027780 967660.19,1027805.4 967665.63,1027881.5 967654.38,1028014.1 967673.81,1028045.8 967686.06,1028064.3 967723.81,1028038.8 967794.19,1028051.1 967814.25,1028139.9 967832.5,1028165.1 967826.88,1028216.4 967737.94,1028235.3 967718.13,1028285.9 967693.38,1028330.2 967686.94,1028349.3 967694.19,1028399.7 967713.13,1028507.3 967726.06,1028620.6 967790,1028677.9 967758,1028759.9 967771.56,1028791.4 967791.25,1028829.4 967798.19,1028924.4 967771.56,1028943.4 967778.25,1028962.2 967810.63,1029075.7 967868,1029069.3 967893.31,1029037.3 967913.31,1029018.6 967906.06,1028917.5 967848.63,1028841.9 967822.25,1028803.8 967861,1028790.6 967962.38,1028790.5 967981.94,1028802.8 968045.69,1028846.9 968090.44,1028928.9 968097,1028954.4 968096.88,1029093.5 968078.94,1029169.6 968066.19,1029226.4 968072.31,1029384.4 968086.19,1029434.9 968105.06,1029529.8 968137.63,1029586.6 968117.69,1029650.3 968061.31,1029802.8 967953.5,1029847.1 967922,1029954.9 967883.31,1030055.9 967896.56,1030137.8 967941.25,1030200.9 967999.25,1030213.5 968024.81,1030200.6 968056.44,1030200.4 968088.56,1030231.9 968113.88,1030307.9 968120.19,1030421.6 968140.44,1030453.2 968140.56,1030485 968128.19,1030586.4 968077.25,1030649.5 968083.56,1030674.9 968077.5,1030751.1 968045.63,1030852.1 968033.31,1030934.4 968046.38,1030959.7 968046.81,1030985.1 968015.13,1031004.3 967957.13,1031042.6 967887.81,1031080.6 967856.06,1031112.3 967881.25,1031143.4 967952.25,1031231.7 968009.19,1031244.3 968034.75,1031250.5 968067.06,1031288.1 968143.25,1031287.9 968181.88,1031275 968219.5,1031274.9 968251.63,1031293.8 968270.44,1031287.4 968289.25,1031280.9 968321.13,1031299.6 968359.94,1031305.8 968385.81,1031293 968416.94,1031293 968436,1031330.8 968455.94,1031368.9 968443.31,1031406.9 968418.13,1031432.3 968411.5,1031457.4 968417.94,1031533.2 968456.38,1031558.6 968418.19,1031577.8 968411.81,1031621.8 968431.06,1031672.3 968463,1031672.2 968488.13,1031672.2 968507.69,1031691.2 968520.88,1031710.1 968514.56,1031792.4 968508.56,1031817.6 968508.5,1031899.7 968527.63,1031962.9 968560,1032019.5 968585.19,1032070 968630.19,1032082.6 968649.25,1032113.9 968681.06,1032182.9 968821,1032252.1 968891.31,1032296.4 968911,1032315.3 968905.25,1032397.4 968925.31,1032441.5 968968.56,1032473.1 968987.81,1032529.8 969001.5,1032618.1 969033.81,1032662.4 969078.63,1032674.6 969129.25,1032718.9 969147.94,1032762.9 969193.25,1032819.7 969242,1032857.3 969249.44,1032901.9 969229.94,1032920.8 969243.19,1032932.5 969306.44,1033019.5 969416.06,1033075.9 969448.81,1033158.1 969449.31,1033208.4 969461.75,1033264.6 969520.5,1033308.5 969546.25,1033465 969674.56,1033508.5 969738.44,1033552.3 969784.25,1033652.8 969836.63,1033708.7 969893.94,1033740.4 969907.69,1033835 969927.75,1033872.4 969958.75,1033903.2 970035.19,1034022 970138.5,1034146.9 970268.13,1034190.9 970287.88,1034248.1 970274.88,1034273.1 970287.81,1034328.7 970390.81,1034366.4 970416.31,1034410.6 970423.44,1034441.9 970442.75,1034516.6 970544.88,1034541.3 970583.44,1034572.3 970634.81,1034596.4 970724.13,1034640.4 970743.25,1034710.2 970737.81,1034747.9 970750.75,1034785.3 970795.38,1034860.9 970821.69,1034873.3 970847.75,1034898.1 970879.81,1034960.9 970918.81,1034973.1 970943.81,1034972.4 970995.06,1034952.4 971072.19,1034957.9 971148.19,1034982.8 971173.19,1035008.2 971180.13,1035040 971174.25,1035229.1 971208.38,1035486.1 971401.13,1035510.5 971458.25,1035534.6 971561.06,1035572.3 971586.56,1035635.3 971594.38,1035748.9 971614.69,1035837.6 971602.88,1035862.8 971608.81,1035894.3 971635.56,1035956.6 971706.19,1036075.9 971757.75,1036214.8 971785,1036233.9 971785.19,1036284.4 971786.56,1036347.6 971792.88,1036398.6 971768.13,1036455.3 971762.19,1036474.5 971755.88,1036576.2 971712.44,1036595.1 971712.63,1036607.1 971763.31,1036612.6 971834.31,1036613.1 971899,1036694.4 971952.69,1036731.3 972020.88,1036756.4 972033.88,1036826 972011.31,1036976.8 972092.75,1036995.4 972130.06,1037001.7 972137.31,1037021.5 972150.5,1037045.9 972156.5,1037108.3 972209.06,1037170.5 972292.19,1037195.4 972336.25,1037195.3 972362.31,1037220.1 972393.88,1037225.7 972445.81,1037275.6 972509.38,1037370.2 972548.06,1037389.4 972541.69,1037440.8 972466.31,1037530.3 972402.81,1037613.6 972365.63,1037723.8 972281.69,1037775.6 972255.88,1037814.6 972230.69,1038017.9 972194.44,1038036.8 972194.63,1038080.1 972220.38,1038186.6 972234.88,1038205.6 972236.13,1038313.5 972192.94,1038408.2 972168.31,1038509.2 972163.5,1038585.5 972113.63,1038642.6 972107.63,1038661.8 972089.25,1038693.3 972082.94,1038712.3 972082.63,1038756.2 972109.31,1038781.6 972109.31,1038844.9 972103.56,1038914.8 972085.56,1038946.3 972085.75,1038977.8 972105.44,1039034.7 972098.5,1039110.7 972106.31,1039205.9 972081.69,1039358.1 972057.19,1039396.7 972025.94,1039410 971987.75,1039501.9 971873,1039521.2 971847.06,1039546.4 971841.5,1039577.7 971874.31,1039591.8 971890.19,1039616.6 971922.25,1039635.4 971936.56,1039660.7 971923.44,1039691.9 971924.56,1039711.1 971924.25,1039813.5 971967.06,1039885.1 971976.06,1039904.8 971974.75,1040017.1 971879.19,1040071.8 971851.75,1040166.7 971845.75,1040236.6 971815.19,1040319.1 971802.63,1040610.4 971762.19,1040763.2 971686.94,1040832.9 971694.5,1040889.6 971688.56,1041124.6 971600.81,1041188.2 971570.5,1041201.3 971539.44,1041226.9 971520.25,1041258.6 971513.88,1041340.8 971521.44,1041359.7 971521.13,1041385.6 971483.88,1041404.8 971470.5,1041474.4 971458.56,1041519.4 971395.94,1041544.8 971388.81,1041620.5 971415.19,1041714.5 971467.44,1041764.8 971493.81,1041777.7 971487.31,1041871.3 971583.63,1041972 971629.06,1042041.4 971618.56,1042066.8 971623.94,1042091.9 971650,1042148.4 971670.13,1042281.5 971644.94,1042326.3 971614.5,1042382.9 971622.06,1042421 971614.94,1042466 971571.44,1042491.2 971564.81,1042522.4 971584.13,1042541.4 971584.69,1042586 971572.81,1042648.5 971631.38,1042717.9 971650,1042755.8 971644.31,1042800.6 971605.81,1042851.4 971581.06,1042945.9 971608.19,1042965.1 971608.38,1043009.6 971582.88,1043028.6 971590.13,1043065.5 971660.81,1043109.6 971687,1043122.3 971686,1043171.9 971756.06,1043190.6 971781.81,1043240.9 971795.75,1043317.4 971758.44,1043336.2 971758.13,1043386.5 971791.13,1043449.7 971784.88,1043519.4 971792.5,1043538.2 971792.13,1043589.1 971780.44,1043614.4 971767.88,1043672.2 971711.69,1043684.9 971692.13,1043704.2 971673.25,1043729.4 971667.63,1043754.8 971673.63,1043779.8 971699.63,1043829.8 971732.13,1043892.8 971757.5,1043924.6 971745.13,1044026.7 971670.56,1044128.5 971627.13,1044364.6 971458.06,1044549 971357.94,1044651.2 971294.94,1044752.8 971277.5,1044879.1 971290.75,1044904.3 971291.69,1044967.9 971260.38,1045025.6 971203.75,1045076.6 971165.94,1045146.4 971154,1045184.5 971129.25,1045210 971104.13,1045261.1 971079.38,1045292.9 971047.44,1045369.9 970984.94,1045510.1 970884.69,1045605.2 970866.06,1045681.5 970841.75,1045713.4 970816.38,1045814.9 970779.38,1045916.9 970736,1046068.8 970717.94,1046163.6 970726.44,1046226.7 970739.31,1046265 970707.06,1046322.6 970663.56,1046348.5 970613.81,1046369.2 970480.5,1046407.9 970403.56,1046575 970208.38,1046606.6 970189.94,1046670.2 970177.25,1046721 970159,1046739.9 970165.25,1046853.5 970179,1046935.6 970193,1046992.6 970187.06,1047017.8 970193.06,1047080.9 970206.88,1047112.5 970207.13,1047207.5 970183.5,1047485.9 970180.19,1047599.9 970162.31,1047682 970169.81,1047700.9 970169.06,1047802.6 970151.19,1047878.6 970145.44,1047915.9 970197.5,1047959.9 970223.69,1047991.3 970223.94,1048073.6 970217.88,1048105.5 970205.5,1048219.7 970168.56,1048263.9 970168.69,1048282.9 970175.88,1048358.9 970176.13,1048421.9 970195.56,1048542.2 970171.38,1048567.8 970158.75,1048599.3 970166.5,1048669 970159.94,1048687.9 970160.69,1048694 970180.5,1048680.9 970199.13,1048680.8 970236.75,1048711.6 970269.06,1048743.3 970269.69,1048762.3 970269.38,1048857.5 970238.25,1048920.8 970246.06,1048946.3 970227.44,1048940.8 970175.5,1048884.4 970123.75,1048891.1 970098.88,1048923 970073.44,1048954.8 970068.06,1048998.6 970094.31,1049035.6 970157.94,1049041.5 970201.81,1049065.9 970260,1049121.8 970349.88,1049259.1 970504.06,1049284 970516.06,1049340.4 970561.81,1049466.4 970607.13,1049529 970659.63,1049591.9 970679.56,1049667.8 970699.38,1049686.9 970693.56,1049737.8 970668.31,1049808.1 970605.13,1049858.6 970599.5,1049903.4 970568,1049966.6 970574.81,1050055.5 970544,1050087.1 970538.63,1050112.3 970539.06,1050175.5 970563.94,1050352 970585.56,1050447.1 970573.94,1050541.6 970594.06,1050567.1 970588.38,1050599.1 970562,1050681.5 970537.44,1050700.5 970538.63,1050763.5 970564,1050820.4 970559.06,1050845.8 970559,1050877.1 970577.75,1050940.3 970598.13,1051065.9 970663,1051128.9 970675.88,1051211.4 970664.38,1051256 970619.81,1051281.6 970614.75,1051312.8 970640,1051331.5 970659.75,1051350.5 970665.94,1051369.5 970660.13,1051388.4 970666.38,1051425.3 970756.06,1051468.9 970800.88,1051544.1 970851.81,1051662.8 970974.75,1051712.9 971013.19,1051857.6 971065.25,1051920.9 971059.56,1051958.6 971073.5,1052059.9 971087.19,1052167.3 971100.25,1052293.8 971083.81,1052375.8 971103.88,1052420 971111,1052515.1 971099,1052533.9 971098.69,1052578.3 971112.88,1052603.4 971112.81,1052635.1 971112.44,1052736.1 971120.69,1052831.5 971089.06,1052888.8 971058.56,1052946.3 971007.88,1053066.5 970983.19,1053117.8 970952.44,1053149.9 970901.94,1053226.8 970832.5,1053272 970750.81,1053356.1 970604.25,1053508.9 970517.5,1053730.9 970481.44,1053781.9 970449.75,1053838.9 970431.19,1053940.6 970407.38,1054061.4 970332.5,1054131.9 970269.31,1054151.4 970224.38,1054189.9 970181.06,1054183.9 970162.25,1054177.9 970136.44,1054248.1 970079.31,1054254.8 970049.38,1054248.9 970016.06,1054262 969978.38,1054256 969940.06,1054269.4 969895.81,1054269.8 969870.19,1054245.4 969800,1054264.4 969780.63,1054296 969799.88,1054321.3 969800.31,1054315.4 969769.5,1054322 969743.13,1054392.4 969679.94,1054399.3 969628.94,1054412.4 969604.88,1054437.9 969579.63,1054462.9 969604.69,1054524.9 969700.81,1054574.9 969732.81,1054625.4 969753.31,1054638.1 969752.19,1054713.6 969792.19,1054794.5 969881.5,1054920 969958.94,1055102.6 970016.38,1055109.3 970018.63,1055128.1 970018.81,1055223.5 969969.63,1055407.8 969900.63,1055712 969847,1055750.4 969822.31,1055866.1 969645.38,1055974.8 969563.5,1056039 969501.06,1056230 969387.13,1056268.6 969336.81,1056389.9 969261.44,1056421.9 969218.5,1056511.4 969155.44,1056543.5 969110.44,1056537.4 969092.63,1056544.3 969041.69,1056569.8 969028.56,1056588.8 969035.81,1056614.1 969035.75,1056645.6 969041.94,1056671 969043.38,1056690.1 969017.44,1056703.1 968998.38,1056805.6 968891.19,1056857.1 968809.25,1056876.3 968789.38,1056959.3 968746.19,1057067.6 968671.38,1057105.6 968659.19,1057176 968608.56,1057271.3 968585,1057436.8 968497.19,1057468.5 968478.25,1057481.6 968459.19,1057475.4 968439.38,1057475.6 968414.25,1057507.6 968382.81,1057565.1 968344.75,1057609.6 968307.75,1057666.8 968307.81,1057723.9 968283.31,1057781.5 968233.25,1057781.9 968207.63,1057814 968176.19,1057872 968068.88,1057910.9 968011.56,1057974.5 967980.81,1058057.6 967905,1058133.6 967887.75,1058184.9 967836.94,1058223.1 967824.25,1058311.6 967812.94,1058439 967750.31,1058496.1 967737.88,1058635.9 967681.75,1058706.4 967612.63,1058757.5 967575.81,1058833.5 967563.56,1058852.8 967544.19,1058879 967462.31,1058956.8 967323.56,1059059.1 967221.94,1059225 967116.06,1059282.6 967059.44,1059327.3 967027.94,1059417 966933.38,1059506.9 966838.81,1059519.6 966812.69,1059513.8 966781.31,1059527.1 966737.06,1059590.9 966686.69,1059623.1 966630.19,1059680.8 966579.56,1059694.4 966509.31,1059745.8 966445.94,1059746 966420.88,1059709 966351.13,1059709.4 966312.5,1059767.8 966205.25,1059826 966091.38,1059879.1 965887.5,1059905.5 965812.13,1059924.6 965799.38,1059886.3 965718.69,1059888.6 965633.81,1059869.8 965633.19,1059787.8 965619.56,1059655.4 965580.5,1059642.8 965579.56,1059592.3 965573.19,1059554.6 965547.69,1059516.9 965540.25,1059491.3 965547.38,1059427 965628.38,1059420.5 965647.25,1059273.4 965779.88,1059163.4 965982.13,1059092.6 966070.44,1059085.4 966147.44,1059021 966235.94,1059014.3 966267.31,1059019.9 966324.31,1058998.4 966521.81,1058972.3 966585.13,1058889.3 966648.38,1058876.9 966659.88,1058863.6 966673,1058831 966755.69,1058767.3 966799,1058716.4 966824.19,1058658.8 966880.81,1058645.6 966912.94,1058543.4 967013.63,1058460.5 967043.75,1058434.9 967069.38,1058459.9 967095.44,1058484.8 967147,1058484.4 967166.06,1058427.4 967158,1058370.9 967132.81,1058320.1 967158.06,1058301.1 967156.88,1058257.1 967130.63,1058238.1 967131.44,1058091.8 967193.31,1058047.4 967199.75,1058003 967217.19,1057939.9 967203.31,1057901.6 967222.94,1057876 967260.63,1057856.8 967285.06,1057799.6 967298.06,1057742.8 967284.94,1057717.5 967290.5,1057673.3 967277.31,1057635.3 967296,1057584.3 967326.75,1057489 967351.88,1057330 967420.81,1057285.6 967438.75,1057227.8 967501.88,1057189.6 967521.56,1057157.9 967526.44,1057075.1 967570.06,1057011 967633.5,1056953.3 967708.69,1056902.4 967721.38,1056889.9 967721.44,1056870.3 967771.38,1056806.1 967840.81,1056742.6 967872.63,1056716.9 967897.31,1056678 967973.19,1056645.8 968011.19,1056639 968050.06,1056645.1 968067.81,1056607.1 968068.5,1056588.3 968061.75,1056550.4 968067.38,1056441.8 968143.19,1056396.9 968198.81,1056301.1 968256.06,1056275.8 968293.75,1056274.5 968363.5,1056274.5 968377.06,1056254.9 968421,1056241.8 968458.19,1056235.6 968471.44,1056209.9 968484.13,1056165.6 968470.44,1056128 968451.44,1056026.3 968494.94,1055892.4 968570.38,1055791.1 968587.69,1055727.3 968631.06,1055670.3 968650,1055587.4 968699.69,1055447.5 968756.31,1055295.5 968766.25,1055263.4 968792.19,1055231.6 968830.63,1055180.6 968855.38,1055073 968866.5,1054932.3 968985.88,1054868.4 969042.75,1054843 969048.81,1054811.5 969035.63,1054798.6 969035.63,1054779.8 969034.94,1054600 969256.25,1054561.5 969281.44,1054536 969312.19,1054510 969363.38,1054478.4 969369.75,1054415.3 969355.94,1054313.4 969418.94,1054274.9 969443.63,1054223.9 969500,1054128.4 969544.69,1054102.5 969587.88,1054064.4 969606.56,1054032.8 969612.94,1053969.4 969605.63,1053944 969619.25,1053918.3 969662.5,1053644.3 969812.5,1053529.5 969881.13,1053498 969887,1053435 969874.56,1053358.8 969886.38,1053321 969872.44,1053289.9 969827.56,1053264.8 969814.56,1053125.6 969806.5,1053100.6 969801.06,1053043.5 969818.5,1053005 969857.25,1052973.3 969868.13,1052795.4 969918.38,1052642.8 969980,1052566.9 969998.25,1052497.3 970004.25,1052472 969996.81,1052415.1 970003.75,1052313.5 970020.63,1052263 970019.75,1052243.8 970019.56,1052168 970031.31,1052111.4 970006.56,1052023 969985.25,1051998 969978.81,1051941.5 969934.06,1051877.9 969946.31,1051820.9 969964.25,1051802 969957.56,1051771.1 969913.69,1051745.6 969913.81,1051701.1 969925.75,1051682.4 969918.56,1051468 969852.38,1051361.3 969794.19,1051285.9 969768.31,1051260.9 969741.81,1051248.1 969741.81,1051197.9 969716.88,1051141.3 969695.69,1051090.8 969689.88,1050983 969707.5,1050856.9 969681.25,1050800.5 969634.94,1050725.8 969551.44,1050682.3 969475.5,1050620.4 969366.25,1050595.4 969353.31,1050582.4 969360.31,1050557.4 969339.81,1050557.9 969320.75,1050551.9 969295.94,1050520.5 969270.19,1050432.6 969218.25,1050224.5 969176.88,1050205.5 969177.69,1050168.3 969201.88,1050141.9 969201.5,1050073.9 969067.44,1050049 969047.94,1050029.9 969048.25,1049922.3 969066.38,1049820.4 969116.31,1049763.4 969109.25,1049700.1 969114.44,1049567.9 969094.5,1049511.4 969049.25,1049492.5 969049,1049448 969055.44,1049429 969047.69,1049366.6 968997.69,1049259.6 968952.06,1049202.8 968957.5,1049139.5 968949.19,1049056.3 968976.81,1049037.8 968987.13,1048987 968999.75,1048898.3 969004.56,1048866.8 968997.88,1048816.6 968971.88,1048772.5 968965.25,1048721.9 968970.94,1048607.3 969013.94,1048549.9 969045.94,1048448.8 969056.75,1048334.6 969080.69,1048290.1 969087.13,1048162.9 969149.63,1048042.5 969167.31,1047998.3 969166.69,1047903.3 969160.19,1047884.6 969153,1047770.5 969177.94,1047700.5 969214.94,1047674.8 969240.13,1047630.4 969258.63,1047585.8 969271,1047509.4 969321.38,1047477.7 969314.69,1047446.1 969326.63,1047426.9 969340,1047383 969313.75,1047364.2 969301,1047319.6 969332.56,1047192.2 969406.69,1047173.1 969400.38,1047154.2 969393.19,1047135.4 969373.94,1047110.4 969361.5,1047072.5 969368.06,1046990.6 969347,1046920.9 969346.44,1046889.6 969315.13,1046826.9 969281.69,1046807.8 969282.5,1046706.4 969306.38,1046598.7 969317,1046554.3 969342.44,1046452.6 969354.31,1046421 969360.19,1046345.3 969346.81,1046243.9 969371.25,1046225.2 969382.56,1046192.6 969422.06,1046147.9 969453.06,1046128.9 969445.81,1046078.7 969426.38,1046059.8 969425.69,1045918.8 969572.13,1045822.1 969710.13,1045789.8 969773.75,1045764.3 969785.81,1045745.3 969792.19,1045675.6 969785.06,1045492.2 969802.94,1045377.9 969845.94,1045307.9 969877,1045263.7 969857.31,1045219.6 969849.69,1045200.6 969850.44,1045181.3 969888.38,1045162 969906.75,1045067.1 969912.81,1044818.9 970024.69,1044799.8 970031,1044724.2 970016.69,1044673.4 970029.81,1044494.8 970148.38,1044462.8 970192.81,1044429.8 970287.06,1044379 970325.31,1044296.4 970344.38,1043904.4 970333.44,1043847.6 970319.25,1043816.1 970319.13,1043790.7 970319.19,1043740.5 970293.19,1043689.9 970279.81,1043614 970298.13,1043487.8 970265.38,1043335.4 970313.94,1043183.3 970350.56,1043132.4 970356.25,1043082.4 970317.19,1043031.9 970311.31,1043000.3 970311.13,1042968.3 970355.13,1042943.1 970341.19,1042879.9 970321.81,1042791.6 970308,1042741.3 970294.56,1042653.3 970242.69,1042596.8 970224,1042577.5 970229.31,1042539.8 970223.44,1042476.7 970203,1042413.6 970197.19,1042362.8 970208.38,1042312.1 970207,1042148.1 970199.44,1042034.1 970204.75,1042008 970256.06,1042001.4 970274.38,1041944.2 970306.38,1041887.1 970317.31,1041842.9 970305.19,1041817.9 970285.69,1041799.1 970279.5,1041754.3 970323.5,1041735.1 970341.38,1041715.9 970347.69,1041665.8 970322.25,1041646.9 970309,1041583.6 970314.75,1041533.3 970276.19,1041470.7 970249.75,1041458.6 970219.75,1041420.9 970166.13,1041370.5 970159.19,1041269.1 970178.63,1041250.2 970184.38,1041173.9 970202.19,1041110.7 970201.88,1041078.8 970226.81,1041047 970232.69,1040946.1 970212.38,1040876.5 970217.31,1040787.9 970210.56,1040496.6 970259.13,1040401.3 970302.31,1040369.5 970295.63,1040344.4 970295.69,1040325.1 970307.5,1040230.3 970313.06,1040198.5 970325.94,1040135.4 970319.13,1040008.1 970368.13,1039989.3 970361.38,1039944.8 970373.88,1039843.3 970410.25,1039824.1 970410.56,1039780.1 970404.38,1039761.3 970397.19,1039748.4 970397.69,1039698.3 970371.81,1039616.3 970357.69,1039565.6 970356.31,1039464.3 970362.19,1039400.8 970380.88,1039337.9 970361,1039312.4 970361.06,1039160.8 970372.06,1039065.8 970378.13,1038964.9 970357.81,1038882.4 970368.81,1038813 970356.25,1038749.8 970360.94,1038680.4 970334.81,1038636.2 970353.25,1038610.3 970391.94,1038590.4 970455,1038564.8 970492.75,1038520.3 970511.19,1038482.2 970511.25,1038431.8 970504.38,1038412.8 970497.13,1038393.7 970503.44,1038343.4 970490.56,1038299.2 970483.38,1038280.2 970489.75,1038260.7 970528.19,1038247.5 970578.94,1038183.8 970609.19,1038056.4 970684.88,1037987.2 970658.19,1037968.2 970664.56,1037930.4 970645.56,1037911.5 970625.31,1037867.3 970638.25,1037848.3 970632,1037779.4 970574.25,1037741.2 970598.44,1037721.9 970617.31,1037702.9 970623.69,1037639.8 970609.75,1037576.5 970628.94,1037513.4 970614.63,1037436.9 970653,1037411.6 970658.63,1037380.1 970651.94,1037354.7 970658,1037303.4 970696.81,1037277.8 970721,1037252.6 970733.56,1037221.1 970726.94,1037195.7 970732.5,1037093.8 970788.5,1037062.1 970795.38,1037036.6 970807.44,1037005.1 970795.25,1036979.9 970794.31,1036941.4 970825.06,1036909.8 970832.44,1036846.9 970812,1036815.4 970792.81,1036697.5 970613.25,1036647.5 970568.19,1036452.4 970495.75,1036377.1 970444.25,1036364.4 970444.25,1036320.7 970412,1036183.8 970232.25,1036133.8 970180.69,1036089.7 970161,1036045.9 970129.19,1036021.1 970083.63,1035889.4 969999.94,1035833 969961.19,1035808.1 969929.69,1035771.4 969813.81,1035746.9 969762.69,1035671.8 969704.19,1035659.8 969648,1035641.1 969621.75,1035590.9 969595.75,1035571.9 969596,1035540.3 969601.88,1035515 969601.94,1035490.4 969556.38,1035471.6 969537.13,1035452.6 969537.38,1035389.3 969549.63,1035351.8 969504.56,1035352.4 969453.44,1035352.6 969433.81,1035321.3 969408.56,1035289.8 969408.94,1035099.3 969457.56,1035017.4 969437,1034992.4 969424,1034966.8 969443.19,1034953.6 969481.38,1034934.4 969499.75,1034915.5 969500.06,1034865.2 969486.63,1034840.2 969473.63,1034821.1 969460.88,1034783.1 969453.5,1034739.2 969433.25,1034695.9 969363.88,1034677.1 969343.63,1034677.8 969286.38,1034691.1 969243.25,1034691.3 969223.63,1034629.1 969146.5,1034460.1 968992.69,1034435.1 968979.69,1034409.6 968984.75,1034230.4 969167.44,1034173.1 969198.5,1034122.2 969204.63,1033914.2 969164.81,1033863.7 969144.44,1033838.7 969131.94,1033789.6 969003.63,1033733.4 968946.25,1033689.4 968932.63,1033645.4 968894.38,1033627.2 968849.5,1033627.5 968811.88,1033647.2 968766.81,1033647.4 968748.31,1033622.6 968716.25,1033622.9 968691.19,1033642.1 968671.25,1033661 968670.94,1033679.8 968691.19,1033692.1 968710.31,1033704.9 968710.19,1033742.7 968717.13,1033761.9 968698.25,1033768.8 968647.81,1033693.9 968576.25,1033700.4 968551.88,1033706.9 968538.63,1033713.5 968519.75,1033707.4 968493.38,1033688.9 968468.56,1033663.6 968467.69,1033587.1 968512.06,1033555.6 968517.94,1033529.9 968543.06,1033541.9 968587.75,1033528.9 968613.88,1033496.8 968656.88,1033496.5 968675.94,1033502.7 968688.69,1033489.8 968714.38,1033470.7 968714.19,1033408.8 968618.44,1033290.1 968496.06,1033247.3 968380.5,1033216.1 968342.19,1033096.5 968283.63,1033058.9 968251.06,1033014.6 968231.38,1032964.3 968179.81,1032913.8 968146.38,1032888.6 968114.31,1032825.6 968093.94,1032749.6 968084.63,1032724.3 968078.19,1032673.9 968021.13,1032598.8 967867.31,1032542.3 967778.38,1032460.3 967752.25,1032384.4 967739.94,1032327.5 967751.81,1032301.9 967771.56,1032238.6 967783.75,1032207.1 967784.13,1032188.1 967776.44,1032169.6 967700.44,1032182.4 967675.31,1032188.6 967656.5),(1026124.3 966144.25,1026143.3 966144.44,1026162.1 966163.69,1026149.4 966176.25,1026124 966170.38,1026111.4 966156.88,1026124.3 966144.25),(1023891.9 967359.81,1023910.8 967360,1023898.1 967385.63,1023866.1 967410.63,1023802.9 967416.75,1023771.4 967410.13,1023783.9 967390.5,1023866.6 967365.88,1023891.9 967359.81),(1022975.6 967177.5,1023045.1 967190.56,1023057.6 967210.13,1022994.1 967261.5,1022930.5 967318.38,1022835.6 967369.06,1022765.6 967419.69,1022759.3 967400.88,1022772.3 967361.69,1022791.6 967298.19,1022810.8 967260.75,1022836.2 967235.06,1022880.5 967209.63,1022931.3 967191.38,1022975.6 967177.5),(1049960.6 970046.38,1049979.5 970053.13,1050023 970111.44,1050066.8 970143.19,1050109.8 970245.25,1050090.5 970271.06,1050045.9 970289.56,1050020.8 970288.63,1049989.1 970281.94,1049944.8 970294.38,1049925.9 970288.13,1049913.5 970262.06,1049907.9 970206.13,1049927.5 970148.63,1049921.5 970134.81,1049928.5 970077.81,1049960.6 970046.38),(1023139.9 967210.69,1023158.9 967210.81,1023152.3 967242.75,1023127.1 967274.44,1023088.6 967338.75,1023075.7 967414.06,1023018.4 967439.56,1022980.5 967446.19,1022917.1 967458.88,1022891.9 967470.06,1022860.1 967496,1022790.4 967508.44,1022765.1 967508,1022759.3 967463.56,1022809.9 967420.31,1022854.3 967400.38,1022917.7 967369.56,1023019.4 967286.5,1023044.9 967254.81,1023095.5 967223.06,1023139.9 967210.69),(1031826.9 967897.06,1031845.9 967909.81,1031864.5 967979.75,1031857.6 968062.81,1031882.6 968183.69,1031888.3 968259.69,1031869.4 968273.56,1031831.4 968260.56,1031787.4 968234.38,1031736.8 968227,1031654.7 968195.38,1031623.3 968138,1031604.6 968081.13,1031604.8 968055,1031649.3 968010.94,1031700.2 967979.25,1031725.4 967959.56,1031801.5 967909.75,1031826.9 967897.06)))" );
	string s= g1->toString();
	cout << "geom1 = "<<s << endl;
	try {
	if (g1->isValid())
		cout <<" is valid" << endl;
	else
		cout << " in NOT valid "<< endl;
	catch(...)
		cout<<"error thrown"<<endl;
