[geos-devel] Compile Problem
Paul Ramsey pramsey at refractions.net
Mon Apr 5 15:49:10 EDT 2004
Hi Ken,
Sorry, should have warned the list: CVS is currently broken while the
JTS 1.4 port is applied. You will have to settle for the last numbered
release until we get things back together.
Paul
Ken Lord wrote:
> Hello List,
> I am unable to compile GEOS, I am a bit of a novice and would
> appreciate any help.
> A short time into compiling the Hourly CVS Snapshot version of GEOS,
> I get the following error message:
> In file included from BasicCoordinateList.cpp:30:
> ../headers/geom.h:316: error: integer constant is too large for
> "long" type
> ../headers/geom.h:585: error: integer constant is too large for
> "long" type
> make[2]: *** [BasicCoordinateList.lo] Error 1
> make[2]: Leaving directory `/usr/src/geos-1.0/source/geom'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/usr/src/geos-1.0/source'
> make: *** [all-recursive] Error 1
> I have also tried the 2003/11/06 download, but it fails  when it
> finds I have automake 1.7.8 instead of 1.7.3.
> For this error I tried running aclocal as it states in the error
> message, but then i get the following error when i Make
> checking dynamic linker characteristics... GNU/Linux ld.so
> ./configure: line 18728: syntax error near unexpected token `long'
> ./configure: line 18728: `PGAC_TYPE_64BIT_INT(long int)'
> make: *** [config.status] Error 2
> I am running Fedora, with qt3.1, and gcc 3.3.2.
> Thanks,
> Ken Lord
> BGC Engineering Inc.
> Vancouver BC
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
