[geos-devel] 2.0.0 Tagged and Released
Stephen Lime
sdlime at comcast.net
Fri Aug 20 00:07:40 EDT 2004
Nuts, I've been using the pending release as excuse not to work on
GEOS/MapServer. Now I suppose I have to do something... ;-)
Steve
On Aug 19, 2004, at 10:54 PM, Paul Ramsey wrote:
> All,
> I have tagged and released 2.0.0.
> The version numbering is because of the API change. Hopefully there
> will not be any more of those and we can use the 2.X.Y series for
> quite some time here on out. The JTS equivalent version number is
> available in defines.
> A compatible version of PostGIS should be following shortly. I would
> like to get some enhancements into the documention first though. If
> you want to try it, the CVS version of PostGIS works fine against GEOS
> 2.0.0.
> Paul
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
