[geos-devel] 2.0.0 Tagged and Released
Paul Ramsey pramsey at refractions.net
Thu Aug 19 23:54:45 EDT 2004
All,
I have tagged and released 2.0.0.
The version numbering is because of the API change. Hopefully there will
not be any more of those and we can use the 2.X.Y series for quite some
time here on out. The JTS equivalent version number is available in defines.
A compatible version of PostGIS should be following shortly. I would
like to get some enhancements into the documention first though. If you
want to try it, the CVS version of PostGIS works fine against GEOS 2.0.0.
Paul
