[geos-devel] help for installing geos on hpux
Paul Ramsey
pramsey at refractions.net
Thu Aug 19 23:59:00 EDT 2004
Luis,
The error looks like your compiler croaking unpleasantly. I have seen
this from time to time, but usually on new code and an old compiler.
(Compiling PostgreSQL 7.4 on OS/X 10.2 does something like this to me.)
I am afraid I have no magic answer. Try a slightly older gcc? Make sure
your tool chain is consistent (I have found various combinations of
linkers and compilers on solaris give different results). Try try again.
Yours,
Paul
Luis Hansen wrote:
> Hi everybody
> Im a junior administrator on Unix systems
> I need to install postgresql with options to GEOS and postgis and I get troubles with GEOS installation the problem is below
> The Unix system is hpux 11.11, I used Gcc(3.3.3) to compile GEOS and I got this unexpected message when I tried "make"
> CoordinateArrayFiter.lo GEOSException.lo IllegalArgumentException.lo UniqueCoordinateArrayFilter.lo Unsupport
> edOperationException.lo -L/usr/local/lib /usr/local/lib/libintl.sl -lc
> ../../libtool[3192]: 25105 Memory fault(coredump)
> gmake[2]: *** [libgeos.la] Error 139
> gmake[2]: Leaving directory `/var/temporal/geos-1.0/source/geom'
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory `/var/temporal/geos-1.0/source'
> gmake: *** [all-recursive] Error 1
> I used three ways to compile but I always get the same message ......
> 1.- ./configure
> 2.- CC=c89 CFLAGS=-O2 LIBS=-lposix ./configure
> 3.- env CPPFLAGS=-I/usr/local/include DFLAGS=-s ./configure
> Other option that I tried was compile with 64 bits (/usr/local/pa64/) succesfully but
> It is posible works GEOS (64bits) with posgis and postgres (32bits) and how can I do it????
> Sorry for my English!
> Regards from Argentina!
> I hope that someone can help me
