[geos-devel] swig module committed to CVS
Sean Gillies
sgillies at frii.com
Fri Aug 20 09:33:35 EDT 2004
OK. Also, if you give me a heads up next time I will check that the
SWIG
module is still working. It's probably broken right now. Strk's style
of methods prototyped in headers that may or may not be implemented in
the C++ source causes problems for SWIG. These methods have to be
explicitly ignored in the SWIG interface file.
Congrats on the new release!
Sean
On Aug 19, 2004, at 9:53 PM, Paul Ramsey wrote:
> Sean,
> Sorry, I just noticed that the 2.0.0 release is missing the swig
> stuff. This is because I am using the 'make dist' functionality of our
> build environment to make the distribution archive. I am going to try
> and keep doing that, so that cutting a release is dead easy. To get
> the swig stuff into the next release, we will have to add the
> appropriate Makefile.am entries to the relevant places... as you can
> see, I am hand waving. :) I am still feeling my way with the fancy
> auto* build tools.
> Paul
> Sean Gillies wrote:
>> I've committed the start of a swig interface for GEOS
>> scripting modules. All the classes in geom.h, io.h, and
>> util.h are wrapped, providing Geometry classes, WKTReader
>> and WKTWriter, and the GEOSExceptions.
>> Code examples for using it can be found in the unit tests
>> under swig/python/tests/cases.
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
