[geos-devel] swig module committed to CVS
strk at refractions.net strk at refractions.net
Fri Aug 20 10:02:37 EDT 2004
On Fri, Aug 20, 2004 at 07:33:35AM -0600, Sean Gillies wrote:
> OK.  Also, if you give me a heads up next time I will check that the
> SWIG
> module is still working.  It's probably broken right now.  Strk's style
> of methods prototyped in headers that may or may not be implemented in
> the C++ source causes problems for SWIG.  These methods have to be
> explicitly ignored in the SWIG interface file.
It is not style, just bugs.
I tought I've fixed it already and sent you a notice
about that. Am I missing something ?
--strk;
> Congrats on the new release!
> Sean
> On Aug 19, 2004, at 9:53 PM, Paul Ramsey wrote:
> >Sean,
> >Sorry, I just noticed that the 2.0.0 release is missing the swig
> >stuff. This is because I am using the 'make dist' functionality of our
> >build environment to make the distribution archive. I am going to try
> >and keep doing that, so that cutting a release is dead easy. To get
> >the swig stuff into the next release, we will have to add the
> >appropriate Makefile.am entries to the relevant places... as you can
> >see, I am hand waving. :) I am still feeling my way with the fancy
> >auto* build tools.
> >Paul
> >Sean Gillies wrote:
> >>I've committed the start of a swig interface for GEOS
> >>scripting modules.  All the classes in geom.h, io.h, and
> >>util.h are wrapped, providing Geometry classes, WKTReader
> >>and WKTWriter, and the GEOSExceptions.
> >>Code examples for using it can be found in the unit tests
> >>under swig/python/tests/cases.
> >_______________________________________________
> >geos-devel mailing list
> >geos-devel at geos.refractions.net
> >http://geos.refractions.net/mailman/listinfo/geos-devel
