[geos-devel] Re: gettimeofday for win32
Frank Warmerdam
fwarmerdam at gmail.com
Fri Dec 3 09:09:14 EST 2004
On Fri, 3 Dec 2004 11:28:41 +0100, strk at refractions.net
<strk at refractions.net> wrote:
> On Thu, Dec 02, 2004 at 09:22:27AM -0500, Frank Warmerdam wrote:
> > o The use of the long long static uid in various items in geom.h caused
> > a problem. I just hacked out the UIDs as they don't seem to have any
> > purpose.
> That is mainly Martin's way of versioning classes.
> Anyway a 64-bit int type is needed for the DoubleBits class, better
> to handle win32 case in platform.h.
Strk,
Actually my problem here is that I don't know how to express
64 bit constants for MSVC. The "LL" (long long) postfix does not
work. Anyone know how to do this right?
> > o The base class toVector() returns a const result while the overrides return
> > non-const. I had to change the base to non-const as well, though I am
> > not clear what the original intent was.
> We should probably have two methods:
> const vector<Coordinate>* toVector() const;
> vector<Coordinate>* toVector();
But the version of toVector() that returns a non-const result does not
really affect the object is invoked on, so conceptually the method should
still be const even if the result isn't.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
