[geos-devel] geos-config
Stephen Lime sdlime at comcast.net
Sat Jul 3 00:44:32 EDT 2004
Trying the new CVS version. build just fine on MacOS.  One comment on
the new geos-config behavior. Seems like --include should keep the -I
switch. That would make it behave just like --libs. Just a thought.
Steve
On Jun 25, 2004, at 3:40 AM, strk wrote:
> I don't like this also.
> I think it should produce just the path without the -I switch.
> Anyway, you should find a geos.m4 file in the GEOS distribution
> handy for application's configure scripts.
> --strk;
> On Thu, Jun 24, 2004 at 11:38:23PM -0500, Stephen Lime wrote:
>> Hi folks: Trying to integrate geos into a configure script based on
>> the
>> output from geos-config. I'm curious if the --includes and --cflags
>> options should be producing the same output (they do). I expected one
>> of them to produce "-I/usr/local/include/geos". I can work around this
>> using the --prefix but was wondering if the behavior is as intended.
>> Steve
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
