[geos-devel] geos-config
strk strk at keybit.net
Sat Jul 3 07:22:45 EDT 2004
On Fri, Jul 02, 2004 at 11:44:32PM -0500, Stephen Lime wrote:
> Trying the new CVS version. build just fine on MacOS.  One comment on
> the new geos-config behavior. Seems like --include should keep the -I
> switch. That would make it behave just like --libs. Just a thought.
> Steve
You can use --cflags for that.
(maybe --libs should actually be --ldflags)
Please tell me if you find any uncomfortable call in the API
as we are re-designing it for next release.
> On Jun 25, 2004, at 3:40 AM, strk wrote:
> >I don't like this also.
> >I think it should produce just the path without the -I switch.
> >Anyway, you should find a geos.m4 file in the GEOS distribution
> >handy for application's configure scripts.
> >--strk;
> >On Thu, Jun 24, 2004 at 11:38:23PM -0500, Stephen Lime wrote:
> >>Hi folks: Trying to integrate geos into a configure script based on
> >>the
> >>output from geos-config. I'm curious if the --includes and --cflags
> >>options should be producing the same output (they do). I expected one
> >>of them to produce "-I/usr/local/include/geos". I can work around this
> >>using the --prefix but was wondering if the behavior is as intended.
> >>Steve
> >>_______________________________________________
> >>geos-devel mailing list
> >>geos-devel at geos.refractions.net
> >>http://geos.refractions.net/mailman/listinfo/geos-devel
