[geos-devel] performance of WKTReader
strk at refractions.net
Fri Nov 5 06:46:06 EST 2004
On Thu, Nov 04, 2004 at 06:38:50PM +0200, Øåáåêî Åâãåíèé wrote:
> Hi. I just compiled geos 2.1.0 using VC7 2003 compiler.
> 1. Looks like that WKTReader is too slow, isn't it?
Yes it is!
> I convert 29583 strings to multipolygons object;
> Total point count was 854744, avarage point count is 28
> Convertion time was about ~ 40 seconds.
> For comparation deep copy of all converted objects was about 1200
> milliseconds.
> This is good enough, if keep in mind complex structure of
> multipolygon.
> Deep copy of vector<string> that contain source for conversion was about 100 milliseconds
> 2. Is any alternative to parse WKT?
Use GeometryFactory to construct geoms.
> 3. Is exist any solution to parse WKB?
Nope. You can WKB-construct postgis geoms and then feed them to
GEOS... might be faster then WKT-constructing GEOS geoms.
> 4. Just not exacly clear from documentation.
> Copy constructor and operator= make deep copy, isn't it?
Copy constructors do, operator= doesn't (not defined).
Try sticking with documented features, as GEOS interface is
pretty unstable. From the documentation you should use
the clone() method for deep-copy.
> Thanks for pay attantion.
Thank you for sharing your experience.
--strk;
