[geos-devel] config script adds too many compiler options
strk at refractions.net strk at refractions.net
Tue Nov 9 15:14:19 EST 2004
Committed.
--strk;
On Tue, Nov 09, 2004 at 02:11:34PM -0500, Ferdinando Villa wrote:
> Good point. Strk - could you please remove the @CFLAGS@ from the
> --cflags line in tools/geos-config.in and commit? I'm having trouble
> findin my cvs password again...
> thanks,
> ferdinando
> On Tue, 2004-11-09 at 14:01, Mark Coletti wrote:
> > geos-config --cflags emits "-g -O2" in addition to providing the
> > include directory path.  config scripts should never set these
> > options.  For example, setting "-O2" can make debugging difficult as
> > the optimizer may relocate or outright eliminate source code.
> > Cheers,
> > Mark
> Ferdinando Villa, Ph.D., Associate Research Professor, Ecoinformatics
> Gund Institute for Ecological Economics and Dept of Botany, Univ. of Vermont
> http://ecoinformatics.uvm.edu
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
