[geos-devel] build problem on Solaris
Jan Kolar kolda at 3dgi.dk
Thu Nov 18 14:53:25 EST 2004
i am using following SPARC machine:
Sun Microsystems Inc.   SunOS 5.9
GNU Make 3.80
gcc (GCC) 3.3.2
when attempt to compile geos-2.0.1 make exits with following:
 g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
-I../../source/headers/geos -I../../source/headers -DGEOS
_VERSION=2.0.1 -g -O2 -MT IsValidOp.lo -MD -MP -MF .deps/IsValidOp.Tpo -c
../operation/valid/IsValidOp.cpp  -
fPIC -DPIC -o .libs/IsValidOp.o
../operation/valid/IsValidOp.cpp: In static member function `static bool
   geos::IsValidOp::isValid(const geos::Coordinate&)':
../operation/valid/IsValidOp.cpp:107: error: `finite' undeclared (first
use
   this function)
../operation/valid/IsValidOp.cpp:107: error: (Each undeclared identifier
is
   reported only once for each function it appears in.)
make[2]: *** [IsValidOp.lo] Error 1
make[2]: Leaving directory
`/group/3dgidata/PostgreSQLDB/test/postgresql-7.4.1/contrib/geos-2.0.1/source/geom
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/group/3dgidata/PostgreSQLDB/test/postgresql-7.4.1/contrib/geos-2.0.1/source'
make: *** [all-recursive] Error 1
any suggestions? (i can build geos1.0 on the same machine)
thank you --kolda
