[geos-devel] build problem on Solaris
QuiƱones Victor
victor at dpec.com.ar
Thu Nov 18 15:01:55 EST 2004
On Thu, 18 Nov 2004 20:53:25 +0100 (CET)
Jan Kolar <kolda at 3dgi.dk> wrote:
#i am using following SPARC machine:
#Sun Microsystems Inc. SunOS 5.9
#GNU Make 3.80
#gcc (GCC) 3.3.2
#when attempt to compile geos-2.0.1 make exits with following:
# g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
#-I../../source/headers/geos -I../../source/headers -DGEOS
#_VERSION=2.0.1 -g -O2 -MT IsValidOp.lo -MD -MP -MF .deps/IsValidOp.Tpo -c
#../operation/valid/IsValidOp.cpp -
#fPIC -DPIC -o .libs/IsValidOp.o
#../operation/valid/IsValidOp.cpp: In static member function `static bool
# geos::IsValidOp::isValid(const geos::Coordinate&)':
#../operation/valid/IsValidOp.cpp:107: error: `finite' undeclared (first
#use
# this function)
#../operation/valid/IsValidOp.cpp:107: error: (Each undeclared identifier
#is
# reported only once for each function it appears in.)
#make[2]: *** [IsValidOp.lo] Error 1
#make[2]: Leaving directory
#`/group/3dgidata/PostgreSQLDB/test/postgresql-7.4.1/contrib/geos-2.0.1/source/geom
#make[1]: *** [all-recursive] Error 1
#make[1]: Leaving directory
#`/group/3dgidata/PostgreSQLDB/test/postgresql-7.4.1/contrib/geos-2.0.1/source'
#make: *** [all-recursive] Error 1
#any suggestions? (i can build geos1.0 on the same machine)
LDFLAGS=-lstdc++
i did and works!
#thank you --kolda
#_______________________________________________
#geos-devel mailing list
#geos-devel at geos.refractions.net
#http://geos.refractions.net/mailman/listinfo/geos-devel
