[geos-devel] build problem on Solaris
Jan Kolar
kolda at 3dgi.dk
Fri Nov 19 06:05:11 EST 2004
using LDFLAGS=3D-lstdc++ does not help to me. compilation exits at the same
point with the same error. any other suggestions? --kolda
On Thu, 18 Nov 2004, [ISO-8859-1] Qui=F1ones Victor wrote:
> On Thu, 18 Nov 2004 20:53:25 +0100 (CET)
> Jan Kolar <kolda at 3dgi.dk> wrote:
>=20
> #i am using following SPARC machine:
> #Sun Microsystems Inc. SunOS 5.9
> #GNU Make 3.80
> #gcc (GCC) 3.3.2
> #when attempt to compile geos-2.0.1 make exits with following:
> # g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> #-I../../source/headers/geos -I../../source/headers -DGEOS
> #_VERSION=3D2.0.1 -g -O2 -MT IsValidOp.lo -MD -MP -MF .deps/IsValidOp.Tpo=
-c
> #../operation/valid/IsValidOp.cpp -
> #fPIC -DPIC -o .libs/IsValidOp.o
> #../operation/valid/IsValidOp.cpp: In static member function `static bool=
=20
> # geos::IsValidOp::isValid(const geos::Coordinate&)':
> #../operation/valid/IsValidOp.cpp:107: error: `finite' undeclared (first
> #use=20
> # this function)
> #../operation/valid/IsValidOp.cpp:107: error: (Each undeclared identifier
> #is=20
> # reported only once for each function it appears in.)
> #make[2]: *** [IsValidOp.lo] Error 1
> #make[2]: Leaving directory
> #`/group/3dgidata/PostgreSQLDB/test/postgresql-7.4.1/contrib/geos-2.0.1/s=
ource/geom
> #make[1]: *** [all-recursive] Error 1
> #make[1]: Leaving directory
ource'
> #make: *** [all-recursive] Error 1
> #any suggestions? (i can build geos1.0 on the same machine)
>=20
> LDFLAGS=3D-lstdc++
>=20
> i did and works!
> #thank you --kolda
> #_______________________________________________
> #geos-devel mailing list
> #geos-devel at geos.refractions.net
> #http://geos.refractions.net/mailman/listinfo/geos-devel
>=20
>=20
