[geos-devel] Compiling on Solaris
Paul Ramsey
pramsey at refractions.net
Sat Sep 11 10:50:49 EDT 2004
Joshua Buysse wrote:
\That gets it to compile.
> Now, the XMLTester test in source/test fails. Here's the result (from
> dbx):
> Any ideas? I feel like a fool for asking this, but since make
> test/make check didn't run these, do they normally work?
Yes, they normally work, they are the first thing I run generally, to
see if we are doing OK on a build, as they exercise the predicates
pretty thoroughly. So it dies as soon as you try to create objects, not
so nice :/
