[geos-devel] Compiling on Solaris
Joshua Buysse buysse at socsci.umn.edu
Sat Sep 11 11:57:44 EDT 2004
All right.  Using similar patches to 2.0.0, it does work correctly and
passes the tests under Solaris, using Sun's compilers and
CFLAGS='-fast', both on x86 and sparc.
It does work correctly, and I can use geos-2.0.0 now that PostGIS 0.9
is released.  The package should be available from blastwave.org within
a couple of days.
Patch attached.  Thanks.
-Josh
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20040911/2df30f68/geos-2.0.0.suncc.obj
On Sep 11, 2004, at 9:50 AM, Paul Ramsey wrote:
> Joshua Buysse wrote:
> \That gets it to compile.
>> Now, the XMLTester test in source/test fails.  Here's the result
>> (from  dbx):
>> Any ideas?  I feel like a fool for asking this, but since make
>> test/make check didn't run these, do they normally work?
> Yes, they normally work, they are the first thing I run generally, to
> see if we are doing OK on a build, as they exercise the predicates
> pretty thoroughly. So it dies as soon as you try to create objects,
> not so nice :/
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
