[geos-devel] win32 build
Paul Spencer
pagameba at magma.ca
Mon Sep 20 21:17:22 EDT 2004
I've attempted to build the current cvs version on Windows using Visual
Studio .net and the included solution file to no avail ... multiple
errors which I can post if you need them. So I tried to back off to the
2.0.0 version ... which has no windows support apparently. To make it
compile, I simply added all the cpp files to a blank dll project and set
the include path, this seems to work (except I don't have a .lib file,
but that's my problem ;))
However, I want to ask about copious warnings:
* SimpleGeometryPrecisionReducer.cpp line 103 ... geomEdit is never
initialized AFAIK ... the code to do this is apparently commented out
just above it. Does this function ever get invoked? It will most
likely cause a crash if it does ...
* MarkupSTL.cpp: loads of signed/unsigned mismatches and size_t to int
conversions :(
* DoubleBits.cpp: line 96, conversion from int64 to int?
* a whole pile of C4541 warnings ... (use of /GR- with polymorphic
types) ... is this a problem? I just disabled them
Cheers,
Paul
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
