[geos-devel] autotools problems
strk at refractions.net strk at refractions.net
Fri Dec 2 08:10:03 EST 2005
Guys, I need some help with the Makefile.am
under source/capi (the new CAPI thing).
I'm really unsure of wheter it is constructed
correctly. As a matter of fact I've hade report
of failures for MingW builds.
The point is building a library and a program.
The library is libgeos_c.
The program is geostest.
libgeos_c depends (links against) libgeos.
geostest depends (links against) libgeos_c.
Current Makefile.am is as follows:
----8<--------------------------------------------------
prefix=@prefix@
top_srcdir=@top_srcdir@
GEOS_CAPI_VERSION="@VERSION at -CAPI-@CAPI_VERSION@"
noinst_PROGRAMS = geostest
geostest_SOURCES = geostest.c
#geostest_LDADD = libgeos_c.la
geostest_LDADD = $(top_builddir)/source/geom/libgeos.la libgeos_c.la
geostest_INCLUDES = -I.
capidir = $(includedir)
nodist_capi_HEADERS = \
        geos_c.h
lib_LTLIBRARIES = libgeos_c.la
LIBS = $(top_builddir)/source/geom/libgeos.la
DIR_SOURCES = \
        geos_c.cpp
libgeos_c_la_SOURCES = $(DIR_SOURCES)
libgeos_c_la_CPPFLAGS = -DGEOS_CAPI_VERSION='$(GEOS_CAPI_VERSION)'
libgeos_c_la_LDFLAGS = -version-info @CAPI_INTERFACE_CURRENT@:@CAPI_INTERFACE_REVISION@:@CAPI_INTERFACE_AGE@
dist-local:
        cp -p $(DIST_SOURCES) Makefile.am Makefile.in $(distdir)
MingW build report show a WARNING at libgeos_c.la build:
*** Warning: This system can not link to static lib archive ../../source/geom/libgeos.la.
*** I have the capability to make that library automatically link in when
*** you link to this library.  But I can only do this if you have a
*** shared version of the library, which you do not appear to have.
libtool: link: warning: undefined symbols not allowed in i686-pc-mingw32 shared libraries
And a lots of "undefined reference" error at geostest build, where
undefined symbols seems the ones in libstdc++.
Any successful MingW builder here, or  does the Makefile.am looks fine ?
--strk;
 /"\    ASCII Ribbon Campaign
 \ /    Respect for open standards
  X     No HTML/RTF in email
 / \    No M$ Word docs in email
