[geos-devel] MingW build (was: autotools problems)
strk at refractions.net
Wed Dec 7 13:49:59 EST 2005
Ok, thanks to Mark we fixed the MingW issue by:
- Uncommenting AC_LIBTOOL_WIN32_DLL in configure.in
- Adding -no-undefined to LDFLAGS for both C++ and C lib
Additionally we added acsite.m4 to the distribution, so future
users will be able to regenerate build scripts.
This calls for 2.2.1 - see 2.2.1 mail (coming next).
--strk;
On Fri, Dec 02, 2005 at 02:10:03PM +0100, strk at refractions.net wrote:
> Guys, I need some help with the Makefile.am
> under source/capi (the new CAPI thing).
> I'm really unsure of wheter it is constructed
> correctly. As a matter of fact I've hade report
> of failures for MingW builds.
> The point is building a library and a program.
> The library is libgeos_c.
> The program is geostest.
> libgeos_c depends (links against) libgeos.
> geostest depends (links against) libgeos_c.
> Current Makefile.am is as follows:
> ----8<--------------------------------------------------
> prefix=@prefix@
> top_srcdir=@top_srcdir@
> GEOS_CAPI_VERSION="@VERSION at -CAPI-@CAPI_VERSION@"
> noinst_PROGRAMS = geostest
> geostest_SOURCES = geostest.c
> #geostest_LDADD = libgeos_c.la
> geostest_LDADD = $(top_builddir)/source/geom/libgeos.la libgeos_c.la
> geostest_INCLUDES = -I.
> capidir = $(includedir)
> nodist_capi_HEADERS = \
> geos_c.h
> lib_LTLIBRARIES = libgeos_c.la
> LIBS = $(top_builddir)/source/geom/libgeos.la
> DIR_SOURCES = \
> geos_c.cpp
> libgeos_c_la_SOURCES = $(DIR_SOURCES)
> libgeos_c_la_CPPFLAGS = -DGEOS_CAPI_VERSION='$(GEOS_CAPI_VERSION)'
> libgeos_c_la_LDFLAGS = -version-info @CAPI_INTERFACE_CURRENT@:@CAPI_INTERFACE_REVISION@:@CAPI_INTERFACE_AGE@
> dist-local:
> cp -p $(DIST_SOURCES) Makefile.am Makefile.in $(distdir)
> MingW build report show a WARNING at libgeos_c.la build:
> *** Warning: This system can not link to static lib archive ../../source/geom/libgeos.la.
> *** I have the capability to make that library automatically link in when
> *** you link to this library. But I can only do this if you have a
> *** shared version of the library, which you do not appear to have.
> libtool: link: warning: undefined symbols not allowed in i686-pc-mingw32 shared libraries
> And a lots of "undefined reference" error at geostest build, where
> undefined symbols seems the ones in libstdc++.
> Any successful MingW builder here, or does the Makefile.am looks fine ?
> --strk;
> /"\ ASCII Ribbon Campaign
> \ / Respect for open standards
> X No HTML/RTF in email
> / \ No M$ Word docs in email
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
