[geos-devel] Download links on GEOS homepage not extractable
David.Jacques at CCRS.NRCan.gc.ca
Mon Feb 28 09:09:50 EST 2005
Thanks. I guess I was following those instructions too literally. (D'owh)
tar xvfj worked fine.
-----Original Message-----
[mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of Norman Vine
Sent: Monday, March 28, 2005 8:32 AM
To: GEOS Development List
Subject: RE: [geos-devel] Download links on GEOS homepage not extractable ?
David.Jacques writes:
> I've been trying to build a new Postgres/PostGIS system as per the
> Instruction on this web page
> http://postgis.refractions.net/windows/WindowsHowTo.html
> I'd like to incorporate GEOS functionality such as Within(),
> Intersects(), etc.
> However I have been unable to unzip / extract the tar.bz files in the
> links on the GEOS homepage. I get the following at the Cygwin prompt.
> $ bunzip2 geos-2.0.1.tar.bz2
> $ pwd
> $ /usr/src
> $ ls
> geos-2.0.1.tar postgresql-8.0.0cvs.tar.bz2
> postgresql-8.0.0cvs-1-log.tar.bz2 proj-4.4.9
> postgresql-8.0.0cvs-1.sh proj-4.4.9.tar.gz
> postgresql-8.0.0cvs-1.sh.log
> $ tar xvzf geos-2.0.1.tar
> tar: Child returned status 1
> tar: Error exit delayed from previous errors
% tar -- help
< snip >
Archive format selection:
-V, --label=NAME create archive with volume name NAME
PATTERN at list/extract time, a globbing
PATTERN
-o, --old-archive, --portability write a V7 format archive
--posix write a POSIX format archive
-j, --bzip2 filter the archive through bzip2
-z, --gzip, --ungzip filter the archive through gzip
-Z, --compress, --uncompress filter the archive through compress
--use-compress-program=PROG filter through PROG (must accept -d)
HTH
Norman
geos-devel mailing list
geos-devel at geos.refractions.net
http://geos.refractions.net/mailman/listinfo/geos-devel
