[geos-devel] GEOS 2.1.1 sprintf Compile Error
strk at refractions.net
Fri Jan 28 04:56:35 EST 2005
I've substituted most sprintf calls with use of ostringstream.
WKTWriter and (external) MarkupSTL are the only one left.
Could you check if CVS version works fine for you ?
TIA
--strk;
On Fri, Jan 28, 2005 at 08:39:05AM +0100, strk at refractions.net wrote:
> On Fri, Jan 28, 2005 at 12:07:22AM -0500, Frank Warmerdam wrote:
> > Folks,
> > I get the following error building geos 2.1.1 with gcc 2.95.4:
> > /bin/sh ../../libtool --mode=compile g++ -DHAVE_CONFIG_H -I. -I.
> > -I../../source/headers -I../../source/headers/geos -I../../source/headers
> > -DGEOS_VERSION=""2.1.1"" -g -O2 -c -o QuadTreeNodeBase.lo `test -f
> > '../index/quadtree/QuadTreeNodeBase.cpp' || echo
> > './'`../index/quadtree/QuadTreeNodeBase.cpp
> > g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> > -I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.1.1 -g
> > -O2 -c ../index/quadtree/QuadTreeNodeBase.cpp
> > -Wp,-MD,.deps/QuadTreeNodeBase.TPlo -fPIC -DPIC -o .libs/QuadTreeNodeBase.o
> > ../index/quadtree/QuadTreeNodeBase.cpp: In method `class string
> > geos::QuadTreeNodeBase::toString() const':
> > ../index/quadtree/QuadTreeNodeBase.cpp:149: implicit declaration of
> > function `int geos::sprintf(...)'
> > I can work around it by include <stdio.h> at the top of the file. Are there
> > any objections to my committing such a change? I'm not sure if there is any
> > bad karma in doing so, or if we ought to just replace sprintf() with
> > something
> > more modern.
> > Actually, there are a couple other files I ran into with the same problem.
> > Best regards,
> Frank, there are 22 files using sprintf.
> I think they should be replaced with something more modern.
> --strk;
> > I set the clouds in motion - turn up | Frank Warmerdam,
> > warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush | Geospatial Programmer for Rent
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
